Tinsnips Samba Member
Joined: November 19, 2011 Posts: 65 Location: Filthydelphia
Posted: Fri Apr 06, 2012 1:19 pm Post subject: |
| Holy crap. I salute you. |
hoss Samba Member
Joined: May 01, 2003 Posts: 721 Location: San Jose, CA
Johnnylongtime Samba Member
Joined: October 29, 2004 Posts: 143 Location: South Coast, England
Posted: Fri Apr 13, 2012 11:00 pm Post subject: |
Congratulations on your sweet Bug. All the hard work has paid off for sure, please post up some more pics for those who will not get to see it at Kelly Park.
Top job..
Johnny |
fuscavw Samba Member
Posted: Sat Apr 14, 2012 6:52 am Post subject: |
| Very nice work! If you don't mind, could you share a bit the technique/tools you used to peel back the drip rail? I need to do a roof clip/skin in a double cab and I'm considering this. Thanks! |
Chris Paterson Samba Member
Joined: February 21, 2010 Posts: 698 Location: Thousand Oaks, CA
Posted: Sat Apr 14, 2012 10:37 am Post subject: |
| fuscavw wrote: |
Basically, you cut the existing roof about an inch or so away from where the drip rail joint is. We used a curved chisel to get under it, once you start to get under it, it's easy because you just keep going. When you pull the drip rail away, don't bend it more than 90 degrees, and you won't need to to pull what's left of the roof out. Also the bentley mentions using heat, which is what I wish we did because even though we tried to not bend more than 90 degrees we did get a few splits in the metal, which is what we were trying to avoid. Even if you do get a few splits, you can repair them after you put the new roof on. Once the drip rail was peeled back we popped off the spot welds around the front windshield and rear window. I think a Double Cab roof would be a lot easier, because there's no windows to worry about. _________________ - Chris
58' PG/SG Microbus
63' Ruby Red Notchback |
Offy 220 Samba Member
Posted: Sat Apr 14, 2012 11:12 am Post subject: |
| Chris Paterson wrote: |
| fuscavw wrote: |
Basically, you cut the existing roof about an inch or so away from where the drip rail joint is. We used a curved chisel to get under it, once you start to get under it, it's easy because you just keep going. When you pull the drip rail away, don't bend it more than 90 degrees, and you won't need to to pull what's left of the roof out. Also the bentley mentions using heat, which is what I wish we did because even though we tried to not bend more than 90 degrees we did get a few splits in the metal, which is what we were trying to avoid. Even if you do get a few splits, you can repair them after you put the new roof on. Once the drip rail was peeled back we popped off the spot welds around the front windshield and rear window. I think a Double Cab roof would be a lot easier, because there's no windows to worry about. |
Chris, did you make your curved chisel from an existing one? A few years back Hot VW's had an article using the same procedure you used but they used a air chisel. Could you post a picture of your chisel or how you modified a chisel that breaks the spot welds and lifts up the rail? Excellent work! _________________ 66 Beetle Daily Driver
60 Beetle Ragtop [In pieces/waiting restoration] |
M113 Samba Member
Joined: August 12, 2003 Posts: 306 Location: Santa Clara
Posted: Sat Apr 14, 2012 9:45 pm Post subject: |
to unroll the drip rail use these carefully
http://www.eastwood.com/door-skin-removal-pliers.html
The bus roof does not need to unroll the drip rail. The roof is spot welded to the gutter in the flat spot. The easiest way is to cut the roof off as close to the gutter and air chisel out the valley. Then on the donor roof remove the gutter and plug weld the new roof into the old gutter on the bus. _________________ Joe -----------
63 Sunroof Notch
57 Deluxe |
M113 Samba Member
Posted: Sat Apr 14, 2012 9:49 pm Post subject: |
Also after you unroll the drip rail you can break the spot welds from the roof to the gutter. There are only about 6 spot welds spaced about 12" apart in the section I did on Chris's roof. I am going to do another clip on a 59 I have some day. When I do I will try to remember to take detailed pics for this thread if anyone cares. _________________ Joe -----------
63 Sunroof Notch
57 Deluxe |
mykidsbug Samba Member
Posted: Sat Apr 14, 2012 11:26 pm Post subject: |
| I wish i had the skill to do that!! beautiful! |
Posted: Sun Apr 15, 2012 1:22 am Post subject: |
| M113 wrote: |
| Also after you unroll the drip rail you can break the spot welds from the roof to the gutter. There are only about 6 spot welds spaced about 12" apart in the section I did on Chris's roof. I am going to do another clip on a 59 I have some day. When I do I will try to remember to take detailed pics for this thread if anyone cares. |
It's about time you jumped in Joe! haha, makes it look like I came up with all this stuff. I don't want to take credit, in fact I wasn't so sure about the whole drip-rail-peel-back idea. But I think it was a great idea and worked out really well. Thanks again for your help and mad genius skilz (that's right with a 'z'). _________________ - Chris
58' PG/SG Microbus
Posted: Sun Apr 15, 2012 3:32 am Post subject: |
| M113 wrote: |
It's about time you jumped in Joe! haha, makes it look like I came up with all this stuff. I don't want to take credit, in fact I wasn't so sure about the whole drip-rail-peel-back idea. But I think it was a great idea and worked out really well. Thanks again for your help and mad genius skilz (that's right with a 'z'). |
Joe and Chris - Thanks for the info and the link for the pliers. If you do the 59 please take detailed pics - I have been holding off installing a rag top on my 60 until I saw your installation - great job! _________________ 66 Beetle Daily Driver
Posted: Mon Apr 23, 2012 9:05 pm Post subject: |
Hey Guess what? I took second place at Kelley Park this year! Stoked!
58' PG/SG Microbus
rockpig Samba Member
Posted: Mon Apr 23, 2012 9:21 pm Post subject: |
| Wow, absolutely stunning! What wheel/tire/susp combo are you running? Classic looks with a modern touch. |
estolze Samba Member
Joined: March 29, 2010 Posts: 42 Location: LAKE HAVASU CITY,ARIZONA
Posted: Mon Apr 23, 2012 9:36 pm Post subject: |
| beautiful looking bug!nice work |
| rockpig wrote: |
Thanks! They are 175/65/15 Contis in the rear and 145/65/15 Contis in the front on stock smoothies. The front is a 4" Punch Drunk Customs beam with CB's Wide 5 disc brake with drop spindles. The rear is a little different. I upgraded it to IRS by welding in the pivots and then bought some trailing arms and flipped them to remove the camber when lowering. The rear is also CB's wide 5 disc brake kit (IRS version). Here's a pic of the setup:
58' PG/SG Microbus
Posted: Mon Apr 23, 2012 9:37 pm Post subject: |
| estolze wrote: |
Thanks! _________________ - Chris
58' PG/SG Microbus
Rometsch2880 Samba Member
Joined: August 15, 2004 Posts: 545 Location: st. albans, west virginia
Posted: Mon Apr 23, 2012 9:38 pm Post subject: |
| Where did you get your running board mats and fender beading? |
Posted: Mon Apr 23, 2012 9:41 pm Post subject: |
| Rometsch2880 wrote: |
A guy on here zundapp. I'd PM him, it looks like he took his ads down. He sprayed them matched to originals. _________________ - Chris
58' PG/SG Microbus
Posted: Mon Apr 23, 2012 9:46 pm Post subject: |
| Thanks for the response. I have a beryl green 61, but had to settle for black mats and beading. I would love to find the correct color for my car. |
Posted: Mon Apr 23, 2012 9:55 pm Post subject: |
| rockpig wrote: |
Thanks! They are 175/65/15 Contis in the rear and 145/65/15 Contis in the front on stock smoothies. The front is a 4" Punch Drunk Customs beam with CB's Wide 5 disc brake with drop spindles. The rear is a little different. I upgraded it to IRS by welding in the pivots and then bought some trailing arms and flipped them to remove the camber when lowering. The rear is also CB's wide 5 disc brake kit (IRS version). Here's a pic of the setup: |
I found a better pic:
You have to notch the frame horns too, btw.
58' PG/SG Microbus
