Newbie Fasty owner. Million questions (But only a few now)
First Fasty
First Fasty is offline
PostPosted: Tue Apr 24, 2012 10:18 pm    Post subject: Newbie Fasty owner. Million questions (But only a few now) Reply with quote
Hello TheSamba.com members.
I am a newbie and I really enjoy this site and expect to learn a ton from all of you.
I expect to have a million questions about my car, which I just brought home 3 days ago. I'm going to start by asking a few now.
My Car:
1970 Fastback with an automatic tranny and factory fuel injection. The car appears quite solid and complete. I was told I am the 3rd owner and the first owner was a German VW mechanic.
Questions:
-The car runs on propane and has since the early 70's. Is there any reason to change that? Anything to look for as negative results of that? If I change back to gas, what would that take?
-The brake pedal has 2 shafts that go into the floor. Is this normal or some sign of some kind of alteration? Will this mean I have to do anything different when I order carpet. The slots in the current carpet seem the same as the brake and clutch slots I've seen on standard cars.
-The car has been oversprayed apparently only once from factory orange to blue and is peeling in spots. Is there any way to remove that paint but leave the original colour safe?
-What modern tire size replaces the original tires? Is it 185/65/15? That size was mentioned to me but I'm unsure.
-How tough are the automatic trannies? Do I need to be concerned that it may not work? That is definately something I would not tackle.
-The car sat for over 10 years, what should be done before I try to crank it up?
-How do I post pictures? I would love to get opinions on my purchase. I did manage to post some in the gallery but I'd like to add them to my posts.
Thanks in advance for any help anyone can offer.
Mike
bderewic
bderewic is offline
PostPosted: Tue Apr 24, 2012 10:27 pm    Post subject: Reply with quote
This piece of literature will only help, I recommend buying it, most of the questions you ask and many more future questions can be answered with it, it also will arise some questions too.
http://www.bentleypublishers.com/volkswagen/repair...anual.html
From my experience researching the forums and internet and picking the brains of the gurus, it seems like everyone is doing something a little different the get their type 3 operating correctly.
Enjoy your type 3 and drive the hell out of it Smile
blankmange Premium Member
Type 3 Darksider
blankmange is offline
PostPosted: Wed Apr 25, 2012 2:39 am    Post subject: Re: Newbie Fasty owner. Million questions (But only a few no Reply with quote
My Car:
Questions:
-The car runs on propane and has since the early 70's. Is there any reason to change that? Anything to look for as negative results of that? If I change back to gas, what would that take? no idea on that - when you can, post some pictures of the propane set up
-The brake pedal has 2 shafts that go into the floor. Is this normal or some sign of some kind of alteration? normal Will this mean I have to do anything different when I order carpet. The slots in the current carpet seem the same as the brake and clutch slots I've seen on standard cars. if given the option, be sure to buy carpets for an automatic
-The car has been oversprayed apparently only once from factory orange to blue and is peeling in spots. Is there any way to remove that paint but leave the original colour safe? easy-off oven cleaner in the blue spray bottle is one option; there are several others and most folks have their favorite
-What modern tire size replaces the original tires? Is it 185/65/15? That size was mentioned to me but I'm unsure. 165 R 15 is the original size, but they are difficult to find
-How tough are the automatic trannies? Do I need to be concerned that it may not work? That is definately something I would not tackle. very tough; unless there is something wrong with it, you shouldn't have to do anything except maybe top off the fluid
-The car sat for over 10 years, what should be done before I try to crank it up? replace all the soft lines before starting/driving it, including fuel and brake lines... fuel lines could be interesting, given the propane issue
http://www.thesamba.com/vw/forum/viewtopic.php?p=78844#78844
Mike
19super73 wrote:
You wouldn't understand intelligent humour even if it slapped you upside your SOS pad head.
póg mo thóin
Certified DHS Technician
Samba Member # 24517
ataraxia
ataraxia is offline
PostPosted: Wed Apr 25, 2012 4:38 am    Post subject: Re: Newbie Fasty owner. Million questions (But only a few no Reply with quote
Mike
The tires are in stock at several Discount Tire stores in Illinois-not sure about where you are though. I thought I'd have a tough time finding tires and they're relatively easy to find. Tire Rack didn't show them on their website but when I called, they had 'some stock'...not sure if that means they're running them to zero stock or if they only stock a few dozen.
Keep the transmission, change all of the fluids in your car, replace brake hoses. Make sure all of your cables work. I'd also pull the tires and check the brakes for wear.
http://restoringferris.blogspot.com/
'To argue with a person who has renounced the use of reason is like administering medicine to the dead.'
Slow 1200
Slow 1200 is offline
PostPosted: Wed Apr 25, 2012 6:07 am    Post subject: Reply with quote
when changethe gear oil (use GL5, not GL4) keep a close eye on the oil that comes out of it and see if there's ATF mixed with it, if it does then you will have to take the trans apart to change the seals between the final drive and the auto section or the ring & pinion will die soon
I managed to do it so it can't be that hard Laughing
First Fasty
PostPosted: Wed Apr 25, 2012 8:50 am    Post subject: Reply with quote
Thanks for all the info so quick. You guys are good.
Glad the brake pedal is normal. Just another sign this car is all original. I see some of my pictures made it to this thread, I assume someone did that for me. Not sure why the engine pic turned upside down. Thanks.
Here's a picture of the underside I got while the car was still on the trailer. http://images.thesamba.com/vw/gallery/pix/919780.jpg
Pretty good shape I think for a 42 year old car that spent the last 10+ years sitting in a field in Alberta Canada.
I'm very happy with my $700 purchase so far.
This is gonna be a fun ride building a fun ride.
Thanks again and keep the advice and opinions coming.
Mike
Mike Fisher
Mike Fisher is offline
PostPosted: Wed Apr 25, 2012 8:59 am    Post subject: Reply with quote
There is a 17mm plug on the side of the AT to fill the separate transaxle with 80-90 weight gear oil.
Better get it running/driving with propane before you even think about changing Anything! Wink
http://s169.photobucket.com/albums/u236/mr_bojangles500/
69 FI/AT square Daily Driver
66 sunroof,67,71,71,71 AT,72,72 AT Parts
56 & 57 oval ragtop $2,500
First Fasty
PostPosted: Wed Apr 25, 2012 9:09 am    Post subject: Reply with quote
Hi again.
Not sure I understand the 2 comments about gear oil. Is this something that needs to be done because it deteriorates over time? Does it need to be checked/replaced before starting the car after so long?
Please forgive my ignorance about this.
Mike, I agree. Get it going on propane then see what happens. Who knows maybe I'll leave it that way. Only issue is getting fuel into the tank. Not as easy as a gerry can of gas.
Mike
Type 3 Darksider
PostPosted: Wed Apr 25, 2012 9:47 am    Post subject: Reply with quote
just out of curiosity - why was the car converted to propane?
póg mo thóin
First Fasty
PostPosted: Wed Apr 25, 2012 12:09 pm    Post subject: Reply with quote
Due to gas prices and availability. Propane was extremely cheap and plentiful then while gas was expensive and at times in short supply.
I just wish gas was that "expensive" now.
I was told the original owner was a Vw mechanic so the conversion would have been much cheaper to do for himself.
W1K1
W1K1 is offline
PostPosted: Wed Apr 25, 2012 12:19 pm    Post subject: Reply with quote
as long as it was not driven on the salty roads in winter it should be good.
mine was daily driven till 2007 when it rusted a brake line from the inside out. But they didn't start using salt in Lethbridge till around 2000 that's why we have so many classic cars in good original shape in local garages and fields.
Concept1 in calgary will have stock tires or you can order from CIP in vancouver.
I have a buddy with 3 of 70-71 T3 parts cars sitting in a field if you need parts.
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1961 beetle
1965 squareback 1500E
terrieann
terrieann is offline
PostPosted: Thu Apr 26, 2012 4:38 am    Post subject: Reply with quote
My parents had a Ford Van back in the late 70's early 80's that ran on gas or propane. I'm no expert here, but my dad always worked on our vehicles, including rebuilding the engine on my first Fastback and he said that propane runs really clean. The engine doesn't get all gunked up from stuff that's in the gasoline. I sound really technical, don't I? I'm not the expert, I just have this memory of him talking about the benefits of propane. That van ran forever. It had tons of miles on it and never needed any major work. I even remember when the fuel pump stopped working, dad just ran it on propane and didn't replace the fuel pump for months. Smile
sharkskinman
Lateral Lunatic
sharkskinman is offline
PostPosted: Thu Apr 26, 2012 10:50 pm    Post subject: Reply with quote
AAAWwwww shit its on a F.I. engine
ME WANTY Twisted Evil
i would love to get into this LPG thing!
wonder how easy it would be!
altho it seems expensive at first
PLEASE post all kinds of pics on your set up!!!
4/71 ~311 "Bettie" (F.I./Auto)
Supaninja wrote:
BTW none of us are "buggin" here, we roll something far superior to a bug
Ward Cleaver wrote:
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards
PS3 Black Ops "NKOGNEATO"
First Fasty
PostPosted: Sat Apr 28, 2012 11:14 pm    Post subject: Reply with quote
So people are thinking I should leave it on propane?
I'm kinda leaning that way when I look into all the things that go with switching it back. I'm planning to build a fun daily driver type car and propane is plentiful where I am.
Just be interesting to see if I can manage to get the system re-certified. Getting it filled is going to be tough now and in future if I don't get that.
Anyone have any idea which parts I can eliminate (read sell) because they aren't needed in a propane system. I don't have much knowledge on propane systems and I haven't researched it yet.
Thanks for any help.
Tram Premium Member
Samba Socialist
Tram is online now
PostPosted: Sun Apr 29, 2012 12:51 am    Post subject: Reply with quote
Engines that run on propane stay brand- new clean inside and don't wear as fast as gasoline- not as many combustion by- products. I'd keep the propane! Very Happy
Give A Pal a Hand!
www.happytrailsfarm.org
May 4, 1970... Never Forget.
RIPRW
"Hell is- other people."- Jean- Paul Sartre
