Linda Grunthaner  Samba Member
Joined: March 18, 2007 Posts: 2709 Location: East Coast
Posted: Sat Apr 21, 2012 9:27 am Post subject: hand held media blaster not doing a thing |
I have a hand held media blaster similar to the one shown here, I hooked it up to my air compressor set at 90 psi then tried 100 psi and using walnut shell media. I tried to remove some paint off a set of magnesium wheels and it doesn't do anything to the paint. Before I head out to the local hardware shop to get some sand are the walnut media just a poor media for removing paint or is it because I'm using a portable 110 compressor? My compressor is a oil less with a 25 gallon tank capable of higher psi.
I also tried to clean up some unpainted sections on the wheels and it didn't do anything either.
 _________________ If you would like to make a donation to the Greg Contreras recovery fund, you can do so via paypal to: [email protected]
Greg's thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=351135&postdays=0&postorder=asc&start=0
67 Westfalia Pop-Top www.oacdp.org, http://www.vintagebus.com/techinfo/index.html
"Pay It Forward Club" in memory of Frank Clarici III |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 12437 Location: Eugene, OR
Posted: Sat Apr 21, 2012 9:55 am Post subject: |
All i have ever used is Good #30 screen Home Depot sand or a glass bead machine. I'd forget about all the fancy medias unless they were close/cheap. _________________ http://s169.photobucket.com/albums/u236/mr_bojangles500/
69 FI/AT square Daily Driver
66 sunroof,67,71,71,71 AT,72,72 AT Parts
56 & 57 oval ragtop $2,500 |
eshan2 Samba Member
Joined: July 10, 2002 Posts: 247 Location: Denver North Carolina
Posted: Sun Apr 22, 2012 1:58 pm Post subject: |
walnut shell is for doing really fine work like electrical say an armature or fuse block. _________________ I love the smell of nitro in the morning.
1963 Beetle currently under reconstruction.
Ernest. |
footdoc Samba Member
Joined: November 01, 2010 Posts: 140 Location: Pittsburgh, PA
Posted: Sun Apr 22, 2012 3:49 pm Post subject: |
| Walnut shells are also good for polishing up used brass for reloading ammo. |
volksgroove Samba Member
Joined: October 19, 2010 Posts: 188 Location: Eustis, FL
Posted: Mon Apr 23, 2012 7:07 pm Post subject: |
I use sand on everything we restore... you just can't use it to remove all the paint and material from say a door skin... the sand will heat and warp the thin, unsupported door skin... for this scenario you would machine strip the paint/bondo first, then lightly etch the metal with the sand from a distance...
your hand blaster is a great tool... I recommend you put an inline screw on filter at the base of the gun to remove moisture from the line... any water in your line makes sandblasting more like constant gun disassembly and unclogging... _________________ 64 Type 3 Notch
67 Double Cab
please join my page: www.facebook.com/the.dub.lab
here's some pics of some of my work: https://www.facebook.com/media/set/?set=a.171915406233895.41758.162893870469382&type=3
and here's the.dub.lab thread:
http://www.thesamba.com/vw/forum/viewtopic.php?p=6210134#6210134 |
Posted: Wed Apr 25, 2012 10:59 am Post subject: |
volksgroove
Interesting I'm using it on mag ARE wheels and used play sand to remove the paint, it started working well then it started to stop and go. I bet the moisture clogged it. I'll get a small inline filter to remove the moisture but I think I need to buy glass media because the sand is leaving the metal bumpy. So do you think I won't need to purchase a blast out of bucket type gun?
http://www.eastwood.com/blast-out-of-a-bucket-abrasive-gun.html
Interesting note on the warpage of thin metal. I didn't know this thanks a TON!
I'll post pictures.
| volksgroove wrote: | I use sand on everything we restore... you just can't use it to remove all the paint and material from say a door skin... the sand will heat and warp the thin, unsupported door skin... for this scenario you would machine strip the paint/bondo first, then lightly etch the metal with the sand from a distance...
your hand blaster is a great tool... I recommend you put an inline screw on filter at the base of the gun to remove moisture from the line... any water in your line makes sandblasting more like constant gun disassembly and unclogging... |
DocOctane Samba Member
Posted: Wed Apr 25, 2012 1:07 pm Post subject: |
Wait a second here... You mean I don't have to purchase a several hundred dollar sandblaster with a gigantic tank?
Reeeeeeeally......interesting. |
Posted: Wed Apr 25, 2012 1:49 pm Post subject: |
I believe the discussion began with sandblasting wheels... A pistol blaster with a decent 220 compressor behind it will be adequate... Not ideal, but adequate... I sandblasted my steel wheels at home with a tired and well used 60 gallon Campbell Hausfeld compressor and a pistol blaster... Put a regulator and filter at the gun and turned the pressure down as low as I could with it still removing paint... This keeps compressor from constantly running, and helps keep your pressure at the gun from dropping.
I now have a body shop with a bad ass 3-phase compressor and a pressure pot blaster that is a huge improvement for larger jobs... Bu I still use the pistol almost daily for smaller stuff... Just keep the air clean...
And as far as the pitting, that's what sandblasting does... Back off pressure and distance from wheels to minimize... Rule of thumb is always use minimal psi and distance that do the job... You may need to apply a DTM filling primer first and sand smooth with 150 and finish in 320-400 before top coating... _________________ 64 Type 3 Notch
67 Double Cab
Posted: Thu Apr 26, 2012 3:28 am Post subject: |
Yea just small jobs with this cheap setup my problem is the wheels are magnesium and I can't use chemicals to remove the paint that I'm aware of. Anyone ever hear of chemical paint remover for magnesium? If I were to spend a few grand on some large equipment I'd wait till I relocate to a much larger garage which would mean moving.
I want to keep the wheels with the magnesium look no paint at all but not happy with the pitting and not sure if I send them out if they will do any better at the media blaster shop. Sanding seems like it will be a problem too. I'm going to buy some glass beads and see it that is any better. That's why I wanted to try the walnut media to avoid that pitting but walnut did nothing and I suspect my compressor isn't strong enough but pressure is pressure so now I think your comment on moisture is the problem with the walnut not working as the walnut soaks up all the moisture like a sponge. Your thoughts?
Volksgroove I found this inexpensive filter but read the review and the guy said he also bought the oilier what is he talking about? And thanks for your help
http://www.harborfreight.com/air-tools/air-tool-accessories/38-compact-air-filter-68230.html
This is what my wheels look like in this comparison chart link. As you can see they will be OK if I just blast them even with a little pitting. Note I will tape off the smooth outer ring as it needs to stay smooth. I wonder if I should think about soda blasting? I'll check with our chemistry teachers here at school (I teach technology) and see what that will do although I suspect that is a very bad idea. Our VW motors are magnesium right? What do you guys use for cleaning up the blocks?
http://www.zparts.com/zptech/comparisons/wheels/pages/are_vs_noname_back.html
| volksgroove wrote: | I believe the discussion began with sandblasting wheels... A pistol blaster with a decent 220 compressor behind it will be adequate... Not ideal, but adequate... I sandblasted my steel wheels at home with a tired and well used 60 gallon Campbell Hausfeld compressor and a pistol blaster... Put a regulator and filter at the gun and turned the pressure down as low as I could with it still removing paint... This keeps compressor from constantly running, and helps keep your pressure at the gun from dropping.
And as far as the pitting, that's what sandblasting does... Back off pressure and distance from wheels to minimize... Rule of thumb is always use minimal psi and distance that do the job... You may need to apply a DTM filling primer first and sand smooth with 150 and finish in 320-400 before top coating... |
Posted: Thu Apr 26, 2012 4:48 am Post subject: |
Those wheels are aluminum. You can use paint stripper on them and then your walnut shells. _________________ http://s169.photobucket.com/albums/u236/mr_bojangles500/
Posted: Thu Apr 26, 2012 7:21 am Post subject: |
I don't think American Racing ever made that wheel in magnesium. Magnesium wheels are a lot darker/different color. _________________ http://s169.photobucket.com/albums/u236/mr_bojangles500/
Posted: Thu Apr 26, 2012 9:17 am Post subject: |
Quick lesson on air pressure... Pressure is pressure, but volume is what dictates available air to maintain pressure... My upright 60 gallon compressor puts out 10.3 scfm supposedly, but she is tired... Anything smaller than that will not produce enough volume of air to sandblast much... Regardless of media... Also watch how worn out your ceramic tip gets... The smaller hole 3/32 or so will help keep pressure up with limited volume... But clogs even easier... If its worn and the opening is much larger, it will require much more volume to maintain pressure...
As far as filters, you need to contact a paint and body supply store in your are and ask for an inline filter that goes at the base of your sandblast gun... They are usually orange, made of plastic, and screw into the threads your air fitting screws into at base of gun... Also you need a regulator inline with it as well... A paint store will know what you are talking about, as many painters use this combo at base of their pai t guns... The separator you show in the link is nice as well, but not instead of... If you cans swing bothe, you will have much cleaner air supply for all air tools... _________________ 64 Type 3 Notch
67 Double Cab
mark tucker Samba Member
Joined: April 08, 2009 Posts: 8529 Location: SHALIMAR ,FLORIDA
Posted: Fri Apr 27, 2012 7:14 am Post subject: |
| those hand held units most of the time dont have a big enough feed hole from the hopper to the sucksion side.so the wallnuts wont flow through there. |
Lidpainter Samba Anti-Hero
Joined: January 21, 2004 Posts: 1835 Location: 41.77 | -83.56
Posted: Fri Apr 27, 2012 11:10 am Post subject: |
| mark tucker wrote: | | those hand held units most of the time dont have a big enough feed hole from the hopper to the sucksion side.so the wallnuts wont flow through there. |
If you're using whole walnuts that might be the problem.  _________________
| SuperSamba wrote: | | Let's move forward with more abortions and less arguing. |
Posted: Fri Apr 27, 2012 11:47 am Post subject: |
Linda sounds like a "Nervous Nelly" Post a picture of the wheels & you will get some opinions.  _________________ http://s169.photobucket.com/albums/u236/mr_bojangles500/
68IHscout  Samba Member
Joined: March 10, 2010 Posts: 1885 Location: santa ana ca
Posted: Fri Apr 27, 2012 12:22 pm Post subject: |
| My experience with the lil blaster is less preassure seems to work better 100lbs is way too much for the one I have ...just my 2cents worth |
