how do I put a pyramid trans in a bug pan?
joemama
joemama is offline
PostPosted: Wed Apr 25, 2012 10:42 am    Post subject: how do I put a pyramid trans in a bug pan? Reply with quote
Need information as to what I need to put a pyramid trans in a fiberglass buggy with a 1967 pan. I want to keep the shifter in the tunnel and use the stock vw shifter. I also have some 3 x 3 arms that I would like to use, but dont know if there is room, The buggy is a very close clone of a Manx, with the battery tray and spare tire well just like the Manx. I do have a 2" body lift I installed. The motor is a type 1.
shred625
shred625 is offline
PostPosted: Wed Apr 25, 2012 11:58 am    Post subject: Reply with quote
OK I gotta ask... what is a pyramid trans? I think you are talking about a bus box and there is a 10 degree kit you can put in that will keep the shifter in the tunnel.
“It takes a big man to cry, but it takes a bigger man to laugh at that man.”
~ Jack Handey
63single
63single is offline
PostPosted: Wed Apr 25, 2012 2:55 pm    Post subject: Reply with quote
Joe,
It will cost you quite a few dollars to do the conversion correctly. You would need to buy a intermediate housing to convert the bus box to a sedan nose cone, then buy or build some mounts... this of course is after you make your pan IRS.
http://www.thesamba.com/vw/classifieds/detail.php?id=1177198
hope that helps you..
joemama
joemama is offline
PostPosted: Wed Apr 25, 2012 3:26 pm    Post subject: Reply with quote
Pyramid is also called a 5 rib? Anyhow. How does the 10 degree mount work? Any links to the procedure
darkflaw
darkflaw is offline
PostPosted: Wed Apr 25, 2012 4:34 pm    Post subject: Reply with quote
Basically the 10 degree kit lowers the shift rod into the tunnel so you can use the standard shift linkage without having to move it to the top of the tunnel, also moves the motor up slightly for better ground clearance.
Berrien 295 Build Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=482673
Fred1214
Fred1214 is offline
PostPosted: Tue May 01, 2012 9:06 pm    Post subject: Pyramid Trans in a bug Reply with quote
If you want to drop into the valley, I can show you an example.
Fred
'69 Baja(Project)
