What size engine and HP/torque do I need??
trailblazr81
trailblazr81 is offline
PostPosted: Sat Apr 28, 2012 11:28 am    Post subject: What size engine and HP/torque do I need?? Reply with quote
OK, so Ive owned a pretty mild baja bug before but most of my experience is with big american V8 cars n trucks so my knowledge of small air cooled engines is limited. I want a Type 1 that I can drive on a regular basis, go on trips, go up into the mountains, explore back roads, and occasionally attack a windy 2 lane road. I also want decent mileage, something that will last, and be reliable for long drives. Some of the freeways are 70MPH speed limits so I will need to cruise at 70-75. Im thinking of also going with a freeway flyer. Now I dont plan on whooping on Mustangs, Camaro's, Evo's, and Bimmers. But I would rather not have my doors blown off by some soccer mom in her minivan or small SUV. Being able to keep up with fart can imports would be nice but not needed. Just something fun, that can pull out of corners on a twisty back road, be able to pass grandma in her cadillac and big trucks going up grades is wanted. If possible I would like it to be able to run off of cheap gas or mid grade. Do I want 100hp or 130hp, or??? A 1776 or 1915cc motor?? Cost is an issue so no built 23000cc monsters. Thanks guys.
Searching for my next air cooled.
mark tucker
mark tucker is offline
PostPosted: Sat Apr 28, 2012 11:55 am    Post subject: Reply with quote
the cost of a 1915 isant much different that the 2332.go with the big mild motor & duel 40-44 hpmx crabs.build it right build it once and have fun.
DarthWeber
DarthWeber is offline
PostPosted: Sat Apr 28, 2012 12:18 pm    Post subject: Reply with quote
mark tucker wrote:
& duel crabs
Absolutely go with duel crabs! Very Happy
I'd go with an 82mm crank and 90.5mm or thick wall 92mm P/C set. This will give you 2110 or 2180cc. In a light Baja Bug anything over 2 liters will be fast.
Have you read this:
http://www.aircooled.net/vw-performance-engines/
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
modok
modok is offline
PostPosted: Sat Apr 28, 2012 12:31 pm    Post subject: Reply with quote
my choice would depend mostly on gearing(trans and tire size), and how important is offroad VS highway?
trailblazr81
PostPosted: Sat Apr 28, 2012 12:50 pm    Post subject: Reply with quote
Im sorry I guess I didnt write this right. I meant Ive had a Baja Bug in the past. But now I want a street Bug. Lower it a little, disc brakes, purdy wheels, and wide tires.
MURZI
MURZI is offline
PostPosted: Sat Apr 28, 2012 12:53 pm    Post subject: Reply with quote
My basic 1835 w110 combo in my baja is very very fun. Mid 15's in qtr which is in line with many civics, etc. Cheap combo, easy to build and fun. 1915 would be better choice but it is what i had.
62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
modok
modok is offline
PostPosted: Sat Apr 28, 2012 12:57 pm    Post subject: Reply with quote
ah, I see
well, that does narrow it down some
if you keep it stock stroke then you should also keep the gearing no higher than factory late model
If you stroke it then maybe you want higher gears
trailblazr81
PostPosted: Sat Apr 28, 2012 1:14 pm    Post subject: Reply with quote
Is there much difference in mileage between engine sizes? My V8 cars have gotten as good as 23MPG cruising at around 80 MPH full tank all hiway. None of those were stock either. If I kept my cruising speed at 65-70 MPH depending on posted speed limit, what kind of MPG's can I get? I would like high 20's if not 30 but really dont know what to expect.
[email protected]
john@aircooled.net is offline
PostPosted: Sat Apr 28, 2012 1:52 pm    Post subject: Reply with quote
a stock 1600dp will go 85mph all day if it's in decent shape.
http://www.aircooled.net/1800cc-vw-engine-no-machine-combo/
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
Last edited by [email protected] on Sat Apr 28, 2012 1:53 pm; edited 1 time in total
mark tucker
PostPosted: Sat Apr 28, 2012 1:53 pm    Post subject: Reply with quote
my 1874 got the worst mpg the 2332 the best, the 2028 is a little less than the 2332. 30-36 mpg combined in town&highway. a biger motor has to work a lot less and will push a bug just fine just barly opening the throttels so the crabs dont get out&bite the camarows&stanger's
Woody Gee
Woody Gee is offline
PostPosted: Sat Apr 28, 2012 1:57 pm    Post subject: Reply with quote
There is a saying that the only thing that will beat cubic inches is cubic dollars. If your going to punch a hole in the case might as well make it a big hole. If your putting a stroker crank in the case, go big....it's the same money. Put some heads on it.....as much as you can afford and then a cam to compliment the package. Tuned properly you will get decent mileage. It takes less than 50hp to go 70mph even if you have 150 available. The other 100 hp is for fun and you can't put a price on fun. IMO.
At least half of the expense will be the mods to make the car able to handle the power.
There is some very good reading at http://www.aircooled.net/vw-technical-articles/ and here on the "sticky's".
His: 74 standard bug, 2332 squishie, FK46, L7,
currently installing CB gen 4 Turbo/FI
Hers: 67 bug project, 2332 in boxes, FK44, L6
theirs: 62 2110 turbo drag car
floor sweep motor 12.98 @107
In my research I have discovered that senility is painless.
trailblazr81
PostPosted: Sat Apr 28, 2012 2:19 pm    Post subject: Reply with quote
36 MPG out of a 2332cc motor?? Thats insane!! That aircooled.net 1800cc no machine work motor looks interesting.
[email protected]
PostPosted: Sat Apr 28, 2012 2:24 pm    Post subject: Reply with quote
the one thing you must never EVER forget is no matter what power output you wind up with, you only have a 80hp cooling system.
vwracerdave
vwracerdave is offline
PostPosted: Sat Apr 28, 2012 5:14 pm    Post subject: Reply with quote
Let u know what you now have to start with and give us a fair estimate of how much you are really willing to spend and we can make a suggestion.
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
rgdedge
rgdedge is offline
PostPosted: Sat Apr 28, 2012 6:33 pm    Post subject: Reply with quote
My 1850 will run 75 on the interstate for hours ( 10 hours last November to Daytona) , run low 15's maybe high 14,s if the traction's good and still get 30+ MPG. Had been doing it for years.
Tim
gt1953
gt1953 is offline
PostPosted: Sat Apr 28, 2012 7:59 pm    Post subject: Reply with quote
rgdedge What is the combo to get 1850cc's?
72 type 1
72 Squareback
trailblazr81
PostPosted: Sat Apr 28, 2012 9:06 pm    Post subject: Reply with quote
Thanks. Thats good to know. I'll have to look into cooling setups.
rgdedge
rgdedge is offline
PostPosted: Sun Apr 29, 2012 5:32 am    Post subject: Reply with quote
76x88. 041 heads I ported, 36mm Dells, FK-8 cam ( I know, needs smaller cam but pulls good to 7000) thunder bird large flange header with heater boxes. Orignally built in late 80's, rebuilt about 8 years ago.
Tim
