Piston ring order and direction
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
myrddin
myrddin is offline
PostPosted: Sat Apr 28, 2012 3:50 pm    Post subject: Piston ring order and direction Reply with quote
Hi guys, just got around to setting the deck height on my buggy motor... I have had the rings off so long I forget which direction the rings face. there is a grove on the inside edge of the first ring and then a grove on th outside edge on the second...e
Do they bothe face each other, or to the head or to the crank?
Also this order good enough?
Top ring at 1:00, second ring at 7:00,top oil ring at 11:00,bottom oil ring at 5:00
there 94mm mahle pistons... (if that even matters)
modok
modok is offline
PostPosted: Sat Apr 28, 2012 3:54 pm    Post subject: Reply with quote
inside bevel is top ring, bevel goes up
outside dovetail corner is scraper ring, this goes down
by up I mean towards the head
myrddin
myrddin is offline
PostPosted: Sat Apr 28, 2012 3:59 pm    Post subject: Reply with quote
Bro. you rock... thanks for quick response...
modok
modok is offline
PostPosted: Sat Apr 28, 2012 5:06 pm    Post subject: Reply with quote
Very Happy thanks
your gap spacing is ok, just make sure no gaps are in the gap of your ring compressor
myrddin
myrddin is offline
PostPosted: Sat Apr 28, 2012 5:23 pm    Post subject: Reply with quote
OK I have sealed the spacers and slid on cyl 3&4 and snugged up the head... How long you recomend waiting to torque the head down so sealant is OK (used ThreeBond 1211)...
Been so long I need to locate the parts... I will be looking for the rest to do tonight... will be nice to see the heads back on... been working on the DH for a loooooong time Evil or Very Mad
modok
modok is offline
PostPosted: Sat Apr 28, 2012 5:27 pm    Post subject: Reply with quote
If it is fairly humid and you spread the sealant out some then it has probably already absorbed enough moisture to cure, torque er down! Don't forget the air deflectors and pushrod tubes Wink
myrddin
myrddin is offline
PostPosted: Sat Apr 28, 2012 5:31 pm    Post subject: Reply with quote
I have the air deflector on (small one is all I have on bottom) I am not going to do the crush tubes... waiting on a set of those jaycee tubes... with the spring I sould be able to add them after..
thanks man... owe you a beer
off to get the other side done...
gorbur
gorbur is offline
PostPosted: Sun Apr 29, 2012 3:54 am    Post subject: Reply with quote
Just in the process of doing exactly the same. My understanding was that it isn't too critical but if you can:
Top ring at 3:00, second ring at 9:00,top oil ring at 11:00,bottom oil ring at 1:00. I'm assuming the point is the gaps on the oil control rings are to be up.
73 - Ghia Cabriolet
75 - Type1:
1776, cb crank, Scat C35 cam
Mofoco big heads, 1.25 rockers
2x Weber 34ict, Pertronix flame thrower 1,
4 in 1 exhaust
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
