Oil cooler foam insulation
68IHscout Premium Member
68IHscout is offline
PostPosted: Sat Apr 28, 2012 9:14 am    Post subject: Oil cooler foam insulation Reply with quote
I know I can get it at any hardware store ,...what is the ideal one to get 1 x1....1/2x1/2?????
Eric&Barb
Eric&Barb is offline
PostPosted: Sat Apr 28, 2012 10:38 am    Post subject: Reply with quote
Been a few years since buying some of that. The wider the better for over the cooler. Have installed it in several rows over the cooler. 3/8" thick is best.
Then for the DH exhaust shell you can cut down the width of the foam seal to work in that area.
In Stereo, Where Available!
PostPosted: Sat Apr 28, 2012 11:53 am    Post subject: Reply with quote
Tanks
Eric&Barb
PostPosted: Sat Apr 28, 2012 12:25 pm    Post subject: Reply with quote
Glad to help.
When you pull the foam seal over the top of the cooler, back up the tape just a tad at the corners. If you just pull it over the foam seal will have more rounded outer corners and not seal quite as well. You want more of squared off outer corners to really seal against the inside of the shroud.
ryans
ryans is offline
PostPosted: Sat Apr 28, 2012 5:49 pm    Post subject: Reply with quote
What exactly is this product? Can you post a picture?
I need this, but don't know what to look for..
Eric&Barb
PostPosted: Sat Apr 28, 2012 5:54 pm    Post subject: Reply with quote
http://search.yahoo.com/search?fr=mcafee&p=foam+adhesive+tape
johnnypan
johnnypan is offline
PostPosted: Sat Apr 28, 2012 5:57 pm    Post subject: Reply with quote
ryans
ryans is offline
PostPosted: Sat Apr 28, 2012 6:14 pm    Post subject: Reply with quote
thank you, that is what I thought, after looking at a hardware store website.
