Arthur's street buggy build
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
Forum Index -> Kit Car/Fiberglass Buggy Share: Facebook Twitter
streetbuggy8804
streetbuggy8804 is offline
PostPosted: Mon Feb 27, 2012 9:17 am    Post subject: Reply with quote
I had to cut away at the bulk head to accommodate what is the equivalent of the pit man arm. I was worried about compromising the structure but after cutting into it I realized how thin the metal was. Boxed it in with 3/16 plate steel.
Tie rods, u joints, tie rod ends all in the mail.
BuggyFaron
BuggyFaron is offline
PostPosted: Sat Mar 17, 2012 11:13 pm    Post subject: Reply with quote
I know I asked what size wheels you are using a while back, what is the tire side wall that you are using. My wheels are 18" by 9" for the rear, and 16" by 8" for the front. I was thinking about using a 45 for the sidewall for both front and back, but I am not sure so.....
Come join us at the Buggy Blast in Marble Falls.
streetbuggy8804
PostPosted: Sun Mar 25, 2012 9:29 pm    Post subject: Reply with quote
Starting to plan my cage
streetbuggy8804
PostPosted: Wed Apr 11, 2012 12:14 pm    Post subject: Reply with quote
Entry up the main hoops. Will try and get them connected this weekend
CBDZ_CBDZ
CBDZ_CBDZ is offline
PostPosted: Wed Apr 11, 2012 4:56 pm    Post subject: Reply with quote
Wow. This was a build that I closely followed.
The cage is coming together nicely, and thanks for your business.
Tube Bender Rental in So. Cal.
http://www.rentabender.com
streetbuggy8804
PostPosted: Sun Apr 29, 2012 9:17 am    Post subject: Reply with quote
Exhaust system all tacked in place. Also have all the fuel components. Just need to get a filler neck welded into an aluminum pipe and we are in business.
Love carbon fiber
Kreelak
Kreelak is offline
PostPosted: Sun Apr 29, 2012 1:10 pm    Post subject: Reply with quote
ok that looks sweet i want to hear a sound clip when you fire it up Smile
JiI
JiI is offline
PostPosted: Sun Apr 29, 2012 10:08 pm    Post subject: Reply with quote
What size tubing are you using for the cage? I'll want to talk to you about hooking up the stinger to the Subie; I'll be running one in my Coyote.
Jeff
streetbuggy8804
PostPosted: Sun Apr 29, 2012 10:15 pm    Post subject: Reply with quote
Cage is 1.5". The exhaust tubing is 2.5". Subi is that way to go.
JiI
JiI is offline
PostPosted: Sun Apr 29, 2012 10:34 pm    Post subject: Reply with quote
1.5? It looks really fat...I like it! Cool
I'll have to swap out my electronic throttle body on the Subie since the stinger doesn't support the electronic accel. pedal. I need to figure out what tubing to run for the radiator too.
Jeff
73SpeedBuggy
73SpeedBuggy is offline
PostPosted: Mon Apr 30, 2012 3:44 am    Post subject: Reply with quote
Lookin' good. Which Subie engine is that? It looks a good bit different from mine.
Manxter #39 on a 1971 Pan
Turbo-charged Subaru EJ25D (DOHC)
http://www.cardomain.com/ride/3923620/1971-volkswagen-beetle#
-Adam
Baja68
Baja68 is offline
PostPosted: Mon Apr 30, 2012 6:21 am    Post subject: Reply with quote
thats awesome good job, I had some thing very similar in mind.
I think he has a 2.5 SOHC engine.
My Build Page http://www.thesamba.com/vw/forum/viewtopic.php?p=3852984&highlight=#3852984
JiI
JiI is offline
PostPosted: Mon Apr 30, 2012 7:42 am    Post subject: Reply with quote
EJ25 is a 2.5 liter and by the shape of the timing belt cover, it is SOHC.
Jeff
streetbuggy8804
PostPosted: Mon Apr 30, 2012 8:44 am    Post subject: Reply with quote
2.5 sohc is right.
didget69
didget69 is offline
PostPosted: Mon Apr 30, 2012 1:34 pm    Post subject: Reply with quote
Jeff
Don't use galvanized fence pipe like some installs I've seen... That said, you might want to look into the water piping from under a Toyota MR2, Fiero, Porsche Boxster, Vanagon, etc., as a source for coolant hard lines - especially if you front mount the radiator.
bnc
Internet listed credentials impress no one but Mom...
streetbuggy8804
PostPosted: Mon Apr 30, 2012 3:18 pm    Post subject: Reply with quote
I used aluminum pipe for the radiator plumbing. It's more work when it comes to welding but I figured it's just better to stick with aluminum all the way.
JiI
JiI is offline
PostPosted: Mon Apr 30, 2012 3:49 pm    Post subject: Reply with quote
What diameter and wall thickness do you think would work the best for the aluminum coolant lines? I'll be running the lines under the pan to the front.
Jeff
streetbuggy8804
PostPosted: Mon Apr 30, 2012 6:47 pm    Post subject: Reply with quote
The be I got was to thick. Couldn't be bead rolled.
Baja68
Baja68 is offline
PostPosted: Tue May 01, 2012 8:58 am    Post subject: Reply with quote
What are you doing for your Temp guage.
On my car I can not tie into the ecm for the read out. The factory has it set up to go from the coolant temp sensor to the ECM out the ECM to the BIU from the BIU to the combination meter.
But the ecm needs that data from that sensor so I am going to run a line from my sensor to my guage out side the factory set up.
So I plan to get an adapter to mount the temp sensor that I bought for the VDO guage to the back side of the head where the coolant plug is.
Here is a pic of the back of a SOHC where the plug I am going to pull and put the sensor in.
streetbuggy8804
PostPosted: Tue May 01, 2012 10:07 am    Post subject: Reply with quote
The stinger has a connector that runs to the temp sensor in the water manifold. I believe that this one controlled the fans. From the water manifold I will a " universal water temp sensor adapter ( use that for e-bay search)." the stinger ecu also has a dedicated wire to run to a temp sensor and on that is dedicated to go back to a gage. I believe that this system is integrated so that those two are connected. Can anyone with experience confirm that? I am trying to figure out the whole radiator setup/ plumbing rigt now. I am having a radiator filler neck welded into a piece of aluminum pipe. I plan on running the outlet of the filler to a overflow tank (filler will be the highest point). Anyone have any feedback on this design?
Reply to topic    Forum Index -> Kit Car/Fiberglass Buggy All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 5 of 7
