JPunt Samba Member
Joined: September 11, 2011 Posts: 147 Location: West Michigan
Posted: Wed May 02, 2012 7:25 pm Post subject: Cylinder Heads back from machine shop |
I finally got my cylinder heads back from the machine shop (Little over a month) but anyways I had the heads flycut for the new 1.8 P&C since they were 1.7 heads for the 914 case. My gasket set came today, and I think I am finally ready to get the ball rolling. BUT.... the machine shop bead blasted the heads which is nice, although he left the valves, rocker assembly, and etc on the head. So now I get to clean everything. I borrowed a valve spring compressor from a buddy to take all the valves and springs etc to clean. And when I went to take out the first valve you can hear the glass beads "tearing" everything up so it sounds like. I stopped there, Any advice or anything? I will try to get some pictures tomorrow after work.
Sorry for the novel  |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 23839 Location: Surrey B.C. Canada, Land of the giant flying moose!
Posted: Wed May 02, 2012 7:38 pm Post subject: |
Wow!, sounds like some real high end work, sure you want to take a chance installing those on an engine?
The only answer I can offer is lots of lube to wash the beads away as you attempt to remove the valve (WD-40 is cheap and conveniently packaged for this job), so did the valves ever get removed for any measuring or machining? or did they just bead the heads and flycut them? _________________ Rust NEVER sleeps and stock never goes out of style.
Wanted, 68-73 westy OG plaid curtains, singles OK. |
JPunt Samba Member
Posted: Wed May 02, 2012 7:42 pm Post subject: |
Yeah exactly, major disappointment. Valves were never removed, like you said just a simple flycut and bead blast. And I am being sure to clean everything possible to the extreme. Kitchen sink with dish soap and streams of water and soap through every hole, then to the garage with air, then back in the kitchen again lol  |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 7127 Location: All Across The Country
Posted: Wed May 02, 2012 8:12 pm Post subject: |
| JPunt wrote: | Yeah exactly, major disappointment. Valves were never removed, like you said just a simple flycut and bead blast. And I am being sure to clean everything possible to the extreme. Kitchen sink with dish soap and streams of water and soap through every hole, then to the garage with air, then back in the kitchen again lol  |
I am so sorry you are dealing with idiots. A complete disassembly and a couple of runs through the dishwasher. What were they thinking? You need to index every valve and keeper set and spring and rocker, everything! to go back exactly where it came from when you are reassembling used parts.
Heck, make sure the heads were not cut too deep.
Colin _________________ www.itinerant-air-cooled.com
Helping You Keep It Alive For Ten Years Now |
SGKent Samba Member
Joined: October 30, 2007 Posts: 17488 Location: State Capitol CA (Sacramento)
Posted: Wed May 02, 2012 9:06 pm Post subject: |
You do know don't you that your heads were not rebuilt. They simply made them look shiny and flycut them. Right?
You need to drill a yard stick or something and mark it with the # of each valve. DO NOT MIX them up as you take it apart and put them in the holes on that yardstick. Lay the springs in a row, do not scratch them to mark them lest the break at the scratch, and any low may be bad. If you have access to a spring tester test all of them. Inspect each keeper, retainer and valve for excessive wear. Inspect each seat for pitting. Wiggle each valve in the seat about 1/2 way up and it should be firm and not rock more than maybe the thickness of a piece of paper. Inspect the edge of each valve and the stem for abnormal wear, excessive scoring or stretching. Hand lap each valve to be sure it seats. Don't over do it. Run the heads, valves and springs etc through the dishwasher, take them out hot and blow them dry. Clean the rocker arms and rocker shafts the same. pull the screws as there will be oil trapped in the holes. Once everything is clean oil it liberally when putting it back together. I use oil and assembly lube. Some people use oil and STP mixed together. Don't forget to check the heads for cracks - including the roofs of the ports. Good luck. All the stems should be about the same height when you are done. Be sure the valves go back in the same holes as each one was ground separate for that seat. _________________ Steve aka Merlin the Wrench
formerly Steve's Racing and Engine Blueprinting. Wrenching since 1967.
bdamico on GF wrote | Quote: | | "When I was your age I'd plan out all sorts of stuff for the future and almost none of them came true. Just wonder if it's worth trying to be a crystal ball. " |
bwiencek Samba Member
Joined: January 24, 2012 Posts: 101 Location: Kansas City
Posted: Thu May 03, 2012 6:45 am Post subject: |
^^^^ That's great advice - the only thing I can add is I'd use a pressure washer on the heads once they're disassembled - being sure to pay good attention to the chamber area and intake& exhaust port/guides - those are the 2 main areas where if there is blasting media embedded in there and it comes loose it can cause wear and damage - if there is any on the external surfaces it's not going to "hurt" the engine if it comes loose...
Hopefully you knew what you were getting or told them to do exactly what they did and the shop didn't say they completely rebuilt the heads... Plus I wouldn't ever go back there and warn everyone that you know of on the quality of their work - if they did that to your parts what's to say if someone brought them a complete engine they wouldn't do the same and slap it together and in 5k miles the guides and rings are shot and someone is looking at pulling the engine again for another rebuild. _________________ 73 bay window - brought home in boxes - work in process.
previous VW Busses: 69 with crank open sunroof, 70 standard, 71 westfalia camper |
Desertbusman Samba Member
Posted: Thu May 03, 2012 11:56 am Post subject: |
You took it to a shop for machining in the chambers and didn't even remove the rocker shafts? Did they ask if you also wanted it torn down for a potential valve and valve guide job? Possibly you ended up with exactly what you had asked them for. _________________ The best thing that anyone can do for their Bay is get the Volkswagen of America Official Service Manual published by Robert Bentley. Without it the bus is pretty much doomed.
| 73kombi wrote: | | when that red light goes on, you have to make a choice. | | Amskeptic wrote: | I am not answering that.
Respectfully,
GoBuyABentley |
71 Superbug
71 Westy |
JPunt Samba Member
Posted: Thu May 03, 2012 4:47 pm Post subject: |
Thanks for all the great advice everyone. I'm gonna start again maybe tonight or tomorrow. I'm taking one apart at a time, and I clean then put the valves, springs, retainers, etc in a zip lock and label 1,2,3 and so on.
I took it there told them I wanted them cut, and everything checked over. Which obviously that did not happen. I'm debating on calling there and complaining but that never does any good so who knows. And the valves do have some movement so now I'm thinking if I have to get new valves, guides, springs, and everything. I might as well just got all new heads (but I don't want to, neither does my wallet) |
udidwht Samba Member
Joined: March 06, 2005 Posts: 1552 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Thu May 03, 2012 9:23 pm Post subject: |
What specifically does it show/list on your receipt from them? Since you have your heads back by all means complain to them if they did not actually rebuild the heads.
What was the charge?
Only a few reliable T-4 head builders I know of...take a guess on who they are? |
Posted: Fri May 04, 2012 4:15 am Post subject: |
I can't believe a shop would bead blast a head with all the hardware and especially the rockers still installed. Never seen or heard of such a thing before.
The cost of sending your heads to a Type 4 head specialist shouldn't be all that high if the castings are actually serviceable. Just to have them rebuilt with stock size components doesn't cost all that much. |
SGKent Samba Member
Posted: Fri May 04, 2012 8:07 am Post subject: |
| Wildthings wrote: | I can't believe a shop would bead blast a head with all the hardware and especially the rockers still installed. Never seen or heard of such a thing before.
I was thinking the same. I can't imagine a shop doing that unless the owner told them to. I also would never hand a machine shop my VW heads with the rockers on it. _________________ Steve aka Merlin the Wrench
bugger101 Samba Member
Joined: September 04, 2010 Posts: 1437 Location: orlando
Posted: Fri May 04, 2012 9:47 am Post subject: |
You have any pics of the heads let's see there work. hope they cut it right did you check it with the cylinders. _________________ 75 west deluxe http://www.thesamba.com/vw/forum/viewtopic.php?p=5270450#5270450
2010 ford focus
1949 ford f-1
2006 Lincoln navigator
automotive student
ford line tech |
JPunt Samba Member
Posted: Sat May 05, 2012 10:05 am Post subject: |
| I sent them everything since I wanted everything checked. But yeah the cylinders fit great. And ill try to get some pictures when I get home |
JPunt Samba Member
Posted: Sat May 05, 2012 11:17 am Post subject: |
Here's some pictures, there kinda crappy quality.
Everything seems to be cleaning up real nice. There wasn't as much debris left over as I thought there was at first. Still have to do the other head. Then reassemble
Sorry there so big. I don't know how to make them smaller |
SGKent Samba Member
Posted: Sat May 05, 2012 1:07 pm Post subject: |
| Quote: | | There wasn't as much debris left over as I thought there was at first. |
huh? Those heads are loaded with beads. I can see debris all in that photo. Throw them in the dishwasher for a couple heavy duty cycles. _________________ Steve aka Merlin the Wrench
Westfabulous Samba Member
Joined: January 07, 2007 Posts: 4083 Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Posted: Sat May 05, 2012 1:11 pm Post subject: |
| SGKent wrote: | | Quote: | | There wasn't as much debris left over as I thought there was at first. |
huh? Those heads are loaded with beads. I can see debris all in that photo. Throw them in the dishwasher for a couple heavy duty cycles. |
Agreed. They are full of crap still. I can't believe that anyone would do what they did to those heads. Secondly, your retaining wire is going to be irreparably damaged if you don't get it out from under the rocker and install it precisely the way it is meant to be. Do not rough it in; there is a very specific way that the retainer needs to go in, and pinched under the rocker is not it. Good luck with that project. _________________ *****************
"I will gladly pay you Tuesday for a hamburger today." |
SGKent Samba Member
Posted: Sat May 05, 2012 1:22 pm Post subject: |
better check this area to be sure it will seal up. Also you have what looks like a heli-coil, time-sert or threaded insert in one of the plug holes. Be sure that the plug goes into that hole correctly before going too far with these.
JPunt Samba Member
Posted: Sat May 05, 2012 2:28 pm Post subject: |
Yeah, I did already check with that cutting, its just the way my phone's camera took it there all cut good. I am going to lap them with valve grinding compound to be sure. And yeah the first thing I did was check that plug hole lol.
But with using the lapping compound you mix it with water to create a paste correct? Also it would probably be a good idea to do the same with the valves too? |
bigbore Samba Member
Joined: December 19, 2003 Posts: 2701 Location: Wasilla Alaska
Posted: Sat May 05, 2012 2:49 pm Post subject: |
They didn't have the right fly cutter at all those were cut with a end mill bit that is wrong and from the looks of them they may not seal they are way ruff. _________________ where its cold and snowy |
JPunt Samba Member
Posted: Sat May 05, 2012 5:44 pm Post subject: |
Well this sucks
What do you guys think I should say if I call there? |
