welder opinions UPDATE!!!!!!
Goto page 1, 2  Next
DaVonZip
DaVonZip is offline
PostPosted: Wed May 02, 2012 12:48 pm    Post subject: welder opinions UPDATE!!!!!! Reply with quote
http://memphis.craigslist.org/tls/2920145645.html
what should i offer? 250. unreasonable ? what should i ask? how old, everything working, and ?
im on the hunt for a welder, will be my first one and i will be in learning mode, have been reading alot of posts about it and itching to start on my recent fat chick i found for 500 bucks...
i may post some more as i find them...tell me what you think
RICK
Mommy, who is that Gorilla in the window?
71 Stand Bug
64 under construction
beetlenut
beetlenut is offline
PostPosted: Wed May 02, 2012 1:11 pm    Post subject: Reply with quote
Does it have the gas set-up, or can that be added to it later? How old is it, how much use has it had, why are you selling it... Does it come with any extras (spools of wire, helmet, tools etc...) I'm pretty sure that's a 110 volt unit, although you might ask about the amperage of the circuit breaker it requires (25 amps would be my guess). They usually go for around $500+ new so unless it's beat, I would think around $300 would be a good offer.
scrapyards are for quitters
DesertBob wrote:
Get a well rebuilt German Solex 34 PICT 3 carb and a new SVDA distributor and you will think you died and went to heaven.
Stuff I'm looking for: http://www.thesamba.com/vw/classifieds/detail.php?id=1460168
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104
gfw1985
gfw1985 is offline
PostPosted: Wed May 02, 2012 1:35 pm    Post subject: Reply with quote
I've been reading good reviews on the Eastwood welders. They sell their MIG 135w/ reg. and hose for gas. Infinitely adjustable heat and wire speed, all for $300 NEW and a three year warranty. But, I have no personal experience with it.
HarryFD
HarryFD is offline
PostPosted: Wed May 02, 2012 6:02 pm    Post subject: Reply with quote
Hobarts are known to be good units but you can go to Lowes or Home Depot and get a new 110v Lincoln for about the same money and add a few bucks to get shielding gas.
http://www.lowes.com/pd_366784-1703-K2185-1_0__?pr...facetInfo=
http://www.homedepot.com/h_d1/N-25ecodZ5yc1v/R-100...reId=10051
1970 Sunroof Bay
1973.5 911 Targa
2006 Ford Focus
2009 MB C300
legotech7
legotech7 is offline
PostPosted: Thu May 03, 2012 6:38 pm    Post subject: Lincoln Hany Mig Reply with quote
I saw this welder at Home depot and the price seemed pretty good. But is this welder capable welding jobs, for instance; I plan on putting air bags on my bug. Would I feel confidante on using this particular welder to weld the pieces of hardware I'm going to need to accomplish this? The amp rating is only 35 to 80. Or will I need something with a little more higher amp rating?
I plan on getting the weld on kit for IRS from airkewld and I want to make sure that a welder like this one from Lincoln could handle it. It says it can weld steel up to an 1/8 of an inch. I talked to some people who do welding on cars and such and they say a lot of the brackets on vw's and other vehicles are no more than an 1/8 of an inch thick anayways, and this welder can handle the work with no problems. They say you can't go wrong with Lincoln quality.
Any comment?
Thanks
gfw1985
gfw1985 is offline
PostPosted: Fri May 04, 2012 4:23 am    Post subject: Reply with quote
I have no problem with Lincoln welders. However, the ones sold at Lowes and Home Depot are not the same as the ones from a welding supply store. There are different parts in them that a Lincoln dealer can't/won't order and usually refuse to work on them. Sold my Lincoln for this reason. Hobart Handler 140 is a fine welder. I did step up to a MillerMatic 211 when they first came out, but it is pricey for someone only planning on doing one vehicle.
legotech7
PostPosted: Fri May 04, 2012 5:14 am    Post subject: Reply with quote
I understand that the other welders may be of better quality, but from the research I've been doing those little Lincolns are very good for the tasks I previously mentioned. I've seen the work those Harbor Freight welders do and even those small 90amp welders from Freight do a decent job for some one who knows how to weld. But the Lincolns I think are better.
I talked to the guy at Home Depot where they sell them and he told me if anything were to go bad that they would just give me another one in replacement. Good for me I don't have to mail anything back since they are local, just a 10 min. drive. Not to mention all the other kudos I received from people I know who do auto welding. I think for the bucks its a good bang.
Further comments welcome........
beetlenut
PostPosted: Fri May 04, 2012 5:40 am    Post subject: Reply with quote
I have a Lincoln welder that I bought from Home Depot in 1999 with the gas set-up. I've welded everything on my car with it from 1/4 inch to 22 gauge without a problem. Great machine for the money! Parts are also readly available if something does go.
legotech7
PostPosted: Fri May 04, 2012 6:12 am    Post subject: Reply with quote
Yes I'm pretty confidant With the small Lincoln welder, especially when Home Depot reassured me if anything went wrong they would replace it.
I think its a done deal.
Thanks to all.....
WestyMan1971
WestyMan1971 is offline
PostPosted: Fri May 04, 2012 6:58 am    Post subject: Reply with quote
I recently bought this and I'm pretty happy with it:
http://www.tractorsupply.com/auto-arc-130-mig-welder-value-package-1048051
It does both fluxcore and MIG, plus it comes with everything you need, including a gas regulator. Hobart is a reputable brand and I've heard many say in online welding forums this is just a re-branded Miller-Matic.
If you have a Tractor Supply near you, they can ship it to the store free, making this a screaming deal.
WEST COASTERS! PERSON MISSING SINCE 4/4! PLEASE KEEP AN EYE OUT!
'71 Westy "Maggie" - M-Plate
'62 Notchback "Pearl"
My VW Blog
Granite State Aircooleds
Parts for sale!
legotech7
PostPosted: Fri May 04, 2012 7:02 am    Post subject: Reply with quote
Hobarts are great, just a tad over my budget, but I know they work great.
WestyMan1971
PostPosted: Fri May 04, 2012 7:09 am    Post subject: Reply with quote
One other thing I would recommend is an auto-darkening helmet. I got the blue-flame one from Harbor Freight for $35 with a coupon and it works well. Sold the helmet that came with the welder on eBay for $20.
My VW Blog
Parts for sale!
DaVonZip
DaVonZip is offline
PostPosted: Fri May 04, 2012 7:22 am    Post subject: Reply with quote
agree with getting a new one (Lincoln) from home depot and forgetting the used Hobart....for a few dollars more its new with warranty....i am just 'itching' to get one so i almost jumped the gun, glad i asked my fello dubbers first. Rick
71 Stand Bug
marklaken
marklaken is offline
PostPosted: Fri May 04, 2012 7:30 am    Post subject: Reply with quote
I have a hobart handler 135 - I bought it new (as a discontinued item) with a welding cart. It came packaged with the gas connections (so this one should have those, but double check). I paid $450 for the setup. I love it. I would think a used one would be worth no more than $300...
Also, Home Depot's Lincoln weldpak 140 (comparable to the Handler 135) goes for $524 at my local HD) - so it's twice as expensive (after tax) as the used welder if you can get it for $275...
Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO
beetlenut
PostPosted: Fri May 04, 2012 7:52 am    Post subject: Reply with quote
As far as welding accessories go, I think this is the best thing to come along since sliced bread! $28 bucks at Eastwood!
DaVonZip
DaVonZip is offline
PostPosted: Fri May 04, 2012 8:13 am    Post subject: Reply with quote
http://memphis.craigslist.org/tls/2930663567.html
http://memphis.craigslist.org/tls/2992073621.html
just for kicks...here are a few more that recently popped up...talked with both guys...they wont move from price...what do you think
71 Stand Bug
marklaken
PostPosted: Fri May 04, 2012 8:56 am    Post subject: Reply with quote
I like the Hobart. One other thing to think about, the Hobarts have a less adjustable range of settings (1 thru 4) and then make internal adjustments for the wire speed to ensure you get proper penetration.
At first I thought it was a setback since I had less manual control of the machine (not "infinite" settings), but now I realize that my welds have always had proper penetration and I have spent less time trying to figure out the "sweet spot" for my welding.
Wish List:
Mark Laken
Fort Collins, CO
DaVonZip
DaVonZip is offline
PostPosted: Fri May 04, 2012 9:14 am    Post subject: Reply with quote
also, after more investigation...found out the Hobart Handler 135 is discontinued, so thats another reason i will stay away...Going for something new...thanks guys RICK
71 Stand Bug
DaVonZip
DaVonZip is offline
PostPosted: Fri May 04, 2012 2:29 pm    Post subject: Reply with quote
http://memphis.craigslist.org/tls/2996294117.html
http://www.homedepot.com/webapp/wcs/stores/servlet...d100670934
this lincoln just came up on craigslist today...the guy is coming over ..he wants 400 bucks...what do you think? anyone have one of these...seems like a good deal RICK
71 Stand Bug
beetlenut
PostPosted: Fri May 04, 2012 3:35 pm    Post subject: Reply with quote
I'd buy it for that price! New and $125 dollars off list is a good deal that doesn't come along that often.
Goto page 1, 2  Next
