Mark Shutt Samba Member
Joined: February 10, 2012 Posts: 364 Location: Doncaster UK.
Posted: Sun May 06, 2012 1:07 am Post subject: fitting dash top and clocks on a 68.. |
ok, a very noob question but this is giving me a headache, I bought the car in pieces and I suspect it has a later dash top as it doesn't have the forward tabs. my clocks fit in but don't "lock" in place with the tabs and I also have the 3 plastic rings but these don't make any sense either!
Mark. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 12434 Location: Eugene, OR
Posted: Sun May 06, 2012 5:07 am Post subject: |
Retrovan in South Africa is selling LHD & RHD reproduction dashes. You might need one from him to successfully get your dash put together? _________________ http://s169.photobucket.com/albums/u236/mr_bojangles500/
69 FI/AT square Daily Driver
66 sunroof,67,71,71,71 AT,72,72 AT Parts
56 & 57 oval ragtop $2,500 |
Posted: Sun May 06, 2012 7:07 am Post subject: |
| Mike Fisher wrote: | | Retrovan in South Africa is selling LHD & RHD reproduction dashes. You might need one from him to successfully get your dash put together? |
I need to find out what's what but before I waste money on a repro dash! my RHD dash is in very good condition except a very small crack so would like to stay with this one if I can help it!
do you know how the clock fit in the dash? do the clocks go in 1st then dash top over them?
Mark. |
Posted: Sun May 06, 2012 7:14 am Post subject: |
I think this answers my question some what, I'm trying to fit early clocks into a later dash top and the clocks just aren't deep enough to "click" into place..
where do I go from here? modify the dash or clocks?
MOCHABILL Samba Member
Joined: June 12, 2008 Posts: 526 Location: BY THE BAY
Posted: Sun May 06, 2012 8:15 am Post subject: |
Its my understanding that there are two sizes of clips to hold the instruments in place,The later versions are shorter in length,perhaps there is your problem!
Regards,Bill _________________ '71 Squareback FI
'07 Passat wagon 2.0
'03 Ranger 4door 4.0 |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 10630 Location: Kimball, Mi
Posted: Sun May 06, 2012 10:09 am Post subject: |
| MOCHABILL wrote: | Its my understanding that there are two sizes of clips to hold the instruments in place,The later versions are shorter in length,perhaps there is your problem!
Regards,Bill |
Yup, up to 70 used 1 style (with the longer clips), and 72 to 73 used the other style with the short clips. Also, 71 used a different clock, in that it used short mounting legs (like the late style), but with a gray face (like the early style). You can change the mounting legs though. _________________ Bob 65 Notch S with Sunroof
71 Notch ...aka Krunchy; build pics here; http://www.thesamba.com/vw/forum/viewtopic.php?t=240540 -tear down
64 T-34 Ghia...aka Wolfie, under construction... http://www.thesamba.com/vw/forum/viewtopic.php?t=412120 |
Yeti69 Samba Member
Posted: Sun May 06, 2012 10:36 am Post subject: |
| Bobnotch wrote: | | I forgot to mention this; the dash pad goes on first, the the gauges go in. If you don't have the tabs for the front, do you have a curved channel that the front of the dash fits into? |
thanks for the info! no I don't have a curved channel, what does it look like? I was thinking of just painting that area matt black to hide it a little, thought it was strange and some how not right..
can I just cut my mounting tabs down? and does anybody know the difference in length I would need to cut off?
@ Yeti69, thanks for posting that link! |
Posted: Tue May 08, 2012 4:40 am Post subject: |
Where do the three plastic rings fit into the equation? No idea where or how they attatch.. I'm thinking of cutting the clips down to suit but only have one shot at getting it tight!
Mark. |
Posted: Tue May 08, 2012 4:56 am Post subject: |
You haven't shown us any pictures of what you have, but we are supposed to identify/assemble it for you! _________________ http://s169.photobucket.com/albums/u236/mr_bojangles500/
Posted: Tue May 08, 2012 6:26 am Post subject: |
| Mike Fisher wrote: | | You haven't shown us any pictures of what you have, but we are supposed to identify/assemble it for you! |
sorry, will get some pics up later.. I just assumed you'd know what those pladtic rings were!
Mark. |
Brent Samba Member
Joined: April 28, 2010 Posts: 996 Location: Yokosuka, Japan
Posted: Tue May 08, 2012 7:28 am Post subject: |
| Mark Shutt wrote: | Where do the three plastic rings fit into the equation? No idea where or how they attatch.. I'm thinking of cutting the clips down to suit but only have one shot at getting it tight!
Mark. |
They fit into the back side of the dash pad. _________________ 69 Fastback Build (Doris) |
Posted: Tue May 08, 2012 8:14 am Post subject: |
I do have one speedometer out of eight that has a loose black plastic ring slipped on it. I don't think it is used in addition to the plastic rings molded into the dash itself? _________________ http://s169.photobucket.com/albums/u236/mr_bojangles500/
Posted: Tue May 08, 2012 8:59 am Post subject: |
OK, this is what I have, what appears to be a later dash top (doesn't have the mounting tabs at front), early clocks and the plastic rings! looks like I'm missing the spring from the speedo too..
the dash pad looks like it has some plastic rings bonded in from the factory..
Brent Samba Member
Posted: Tue May 08, 2012 9:05 am Post subject: |
Looks like you have an extra set. They are in the dash properly.
You're missing the wave spring on the speedo though.
Shouldn't ALL dashes have the mounting tabs? _________________ 69 Fastback Build (Doris) |
Posted: Tue May 08, 2012 9:12 am Post subject: |
Try the speedometer without a spring. The late dashes don't have/need mounting tabs in front. _________________ http://s169.photobucket.com/albums/u236/mr_bojangles500/
Brent Samba Member
Posted: Tue May 08, 2012 9:22 am Post subject: |
| Mike Fisher wrote: | | Try the speedometer without a spring. The late dashes don't have/need mounting tabs in front. |
I didn't know that. What holds it in place? Is that the curved piece Bob mentioned?
A bit of image searching and I found an early car with a late dash.
Posted: Tue May 08, 2012 9:33 am Post subject: |
thanks guys, so I can forget those plastic rings I have! if you look at the lower mounting tab on the speedo you can just about make out where I put a marker pen line from behind when it was in the dash, works out about 5mm difference.
regarding the dash tabs, that's another obstacle I have to get past as my early dash metal doesn't have the metal mounting channel, I found this out yesterday when I looked at another guys late fastback.. any suggestions how to secure it a little bit better? or will it be just fine? |
Posted: Tue May 08, 2012 9:44 am Post subject: |
| Brent wrote: | | Mike Fisher wrote: | | Try the speedometer without a spring. The late dashes don't have/need mounting tabs in front. |
Yup, what he has is an early car with a late style (like the crappy repops) dash pad. That style (the 71 on) uses a "C" channel to hold the front of the dash pad in place. If you still have the glass out, and can source the "C" channel from a 71 and later car, then you could install the "C" channel in the early car to hold the front of the dash pad in place (I did that on my 65 Notch way back in 2001).
Or you could use liquid nails to glue the pad to the dash. I've seen that done before too.  _________________ Bob 65 Notch S with Sunroof
