Rivets loose on Kennedy stage 1 pressure plate
Goto page 1, 2  Next
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
superbtl
superbtl is offline
PostPosted: Fri May 04, 2012 4:56 pm    Post subject: Rivets loose on Kennedy stage 1 pressure plate Reply with quote
I put a clutch in last summer and when I took the car out of winter storage , the clutch was slipping. Upon inspection I noticed all the rivets on the pressure plate was loose. So I purchased a new pressure plate and disc last week. I drove the car for 3 days. On the 3 rd day I wasn't able to put it into gear when the engine was running. I pulled the clutch out again and all the rivets are loose on this pressure plate. Is any one else having this issue?? Tis is my 2 nd new clutch within a year. I have not beat on the car or abused it in any way.
modok
modok is offline
PostPosted: Fri May 04, 2012 5:19 pm    Post subject: Reply with quote
Return it to Kennedy, they claim to stand behind their product.
superbtl
superbtl is offline
PostPosted: Fri May 04, 2012 5:35 pm    Post subject: Reply with quote
Are there any other pressure plates I could go with? I would rather avoid Kennedy since I have put in 2 within a year and not even 200 miles combined.
c.ruber
c.ruber is offline
PostPosted: Fri May 04, 2012 7:51 pm    Post subject: Reply with quote
Really????? More Kennedy issues???? I've had one die in less than 200 miles recently! Will someone please stop in Palmdale and slap these people into shape.... Unfortunately, to my knowledge there are no other options, besides Empi. I so want to drive my car, but I'm not willing to drop another penny on a Kennedy.
...and progress is not intelligently planned...
jfats808
jfats808 is offline
PostPosted: Fri May 04, 2012 8:19 pm    Post subject: Reply with quote
Sounds like you got one of the bad ones from that latest bad batch. I'm told that KEP will replace a defective one. Alternative is an Empi stage 1. Heard they're ok. Empi though....
2276 IDA's 86C 11-1 DD !
2017 48DRLA's W125
Check your oil levels routinely!
SRP1
SRP1 is offline
PostPosted: Fri May 04, 2012 9:45 pm    Post subject: Reply with quote
I recently went through this very issue. New Kennedy pressure plate, disc, etc
Clutch worked perfect for about 40 miles or so, then would not disengage fully, so no gear shifting was possible with the engine running.
Long story short, I sent the PP back to Kennedy they "reworked" it an sent it back free of charge. Seems there was an error in the making of the friction suface on the PP, it was a little to thick. I would be willing to bet that mine was not the only one in error, when these types of errors happen they usually in batches.
Anyway botton line is no ones perfect, mistakes happen, what makes a manufacturer good is consistancy, and the ability to stand up and make things right if they go wrong.
I have used and been using kennedy clutches for over 20 years and that was my first issue which they promptly took care of.
Propts to Kennedy for doing such a stand up job all these years, and their willingness to handle issues on an individual basis.
Call them up, and give them the opertunity to fix it.
www.srpengines.com
Performance Plumbing- AN fittings, Braided hoses, Fire Sleeve....
c.ruber
c.ruber is offline
PostPosted: Sat May 05, 2012 5:37 am    Post subject: Reply with quote
I apologize, This is the second PP that I've had with this problem. I'll send mine back if it comes back free of charge and able to perform then I'm ok.
SRP1
SRP1 is offline
PostPosted: Sat May 05, 2012 7:46 am    Post subject: Reply with quote
c.ruber wrote:
I apologize, This is the second P.P that I've had with this problem. I'll send mine back if it comes back free of charge and able to perform then I'm ok.
Have a close look at the thickness of the disc also, could be to thick causing the clutch to hang. Another area of error thats commonly made is over adjusting the pedal causing the PP to over cycle and become damaged.
I recommend adjusting the clutch so there is just enough pedal to get a good clean shift.
Typically that means following kennedys directions of 1/8" freeplay at the clutch arm on the transmission to the "T". If you adjust the clutch by pedal feel, 9 times out of 10 it's possible to overcycle the PP, damage it, and cause the very issue your fighting now.
One more thing, it's critical the PP is kept level when installing and removing it from the flywheel. In other words tighten and loosen equally.
I'm not saying you did or didn't do any of the above, just trying to throw out ideas to help.
Let know what you find.
www.srpengines.com
mark tucker
mark tucker is offline
PostPosted: Sat May 05, 2012 8:01 am    Post subject: Reply with quote
and make sure it seats in the resess fully. there are not many companys that will do what they are doing.I will spend my money with them again as I always have.
Chris659
Chris659 is offline
PostPosted: Sat May 05, 2012 12:23 pm    Post subject: Reply with quote
I just got a stage 1 kit from Kennedy not too long ago. Since mine is still new in box I am wondering if they keep batch numbers to the defective ones and would swap it before I run into problems and have to take it out... Assuming mine is one within the batch numbers they have reported problems with I guess
SRP1
SRP1 is offline
PostPosted: Sat May 05, 2012 12:40 pm    Post subject: Reply with quote
I would not assume anything, good or bad.
I would not light fires that don't need to be lit either. Kennedy never said they had a bad batch, I just used that term as a typical scenario found in manufacturing.
I would compare notes with the one your are replacing, if you find something to be off or odd, then give them a call.
Otherwise, Run it!
www.srpengines.com
Chris659
Chris659 is offline
PostPosted: Sat May 05, 2012 2:04 pm    Post subject: Reply with quote
Yeah I will. I got it from berg so who knows if they had them sitting on thshelf for a while or what. I don't want to start anything either but also thought if I could avoid a problem it would be nice
superbtl
superbtl is offline
PostPosted: Sun May 06, 2012 6:04 am    Post subject: Reply with quote
Are there any other options other than Kennedy?
vwracerdave
vwracerdave is offline
PostPosted: Sun May 06, 2012 8:07 am    Post subject: Reply with quote
Yes, you can get a 'Made in China" copy of the Kennedy. They are painted blue and about $20 cheaper. Try the EMPI dealer nearest you.
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
SRP1
SRP1 is offline
PostPosted: Sun May 06, 2012 11:55 am    Post subject: Reply with quote
I don't recommend it!
Kennedy's the only real game in town for clutches, unless you step out and go big with a custom set up, which is out the $$ range for most folks and not needed either.
With Kennedy being the only real game, supporting any other manufacturer (in this case Chinese stuff) would be like shooting yourself in the foot at this point. If Kennedy goes away whats left? Nothing in my book, I won't run a Chinese clutch.
Let's support what we have, Kennedy makes a great product.
www.srpengines.com
[email protected]
john@aircooled.net is online now
PostPosted: Sun May 06, 2012 12:03 pm    Post subject: Reply with quote
http://vwparts.aircooled.net/200mm-Racing-Pressure-Plates-Economy-1700lb-p/big-blue-stage-1.htm
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON THE NEW WEBSITE, vwparts.aircooled.net
Boolean
Boolean is offline
PostPosted: Sun May 06, 2012 12:06 pm    Post subject: Reply with quote
Have done some looking around, and there are alternatives. Nothing as cheap as the KEP, but there are others - Tilton, Sachs, and other high quality products are out there.
How about a 250 dollar carbon clutch?
No, no, that should have read 2500....
superbtl
superbtl is offline
PostPosted: Mon May 07, 2012 4:10 pm    Post subject: Reply with quote
Kennedy confirmed a problem with a batch of p/p. They are stand up guys and are taking care of the problem. I'm glad I called them .
Muffler Mike
Muffler Mike is offline
PostPosted: Mon May 07, 2012 4:18 pm    Post subject: Reply with quote
Funny this came up. Friend brought his PP by and wanted me to take a look. Rivits/diaphram pins loose, loosing adjustment. But clearly see it was over traveled. Inside, you can see where diaphram was hitting the pins causing them to come loose.
Muffler Mike
http://MufflerMike.com
c.ruber
c.ruber is offline
PostPosted: Tue May 08, 2012 4:48 pm    Post subject: Reply with quote
So how do we keep from over centering the diaphragm? I personally adhered to the directions provided by KEP, and have the same problem... I had clutch engagement streight when the pedal left the floor I used to be able to engage the clutch somewhere at the end of the pedal travel. I had always adjusted per the Bentley manual. Now It seems that with the directions provided and the Bently are not providing the proper way to adjust.
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
Goto page 1, 2  Next
