WBX lifter clatter
Goto page Previous  1, 2, 3, 4, 5, 6  Next
Forum Index -> Vanagon/Eurovan Share: Facebook Twitter
theDrew
theDrew is offline
PostPosted: Fri May 04, 2012 10:52 am    Post subject: Reply with quote
and how much should I put in my 1.9?
1985 Vanagon Campmobile w/ 2005 EJ253 SOHC
1974 Super Beetle
kamzcab86
kamzcab86 is offline
PostPosted: Fri May 04, 2012 11:36 am    Post subject: Reply with quote
theDrew wrote:
Can some one spell out to me exactly what I do with MMO? When, how long, etc?
Put it in a run it for a bit BEFORE the oil change? Or put it in after with fresh oil?
I put in between 4-8 oz. of MMO with every oil change (i.e. it goes in with fresh oil). Two years now and rarely a clatter from my 2.1.
Edit: Had wrong amount (forgot there are two sizes of MMO bottles).
~Kamz Anxious
2000 Jetta VR6
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Fri May 04, 2012 11:50 am    Post subject: Lifter (not oil) thread update Reply with quote
Tick came back on my off brand car, but then again it's a diesel with a whole different lifter arrangement--more akin to inline VW lifters. Fired up the van and it ticked for like one full revolution and then silenced.
--Casey
'89 Bluestar
"Omnia Extares"
Terry Kay
Terry Kay is offline
PostPosted: Fri May 04, 2012 12:48 pm    Post subject: Reply with quote
Seeing as how your not driving the Van every day the lifter's are bleeding off.
Do the Van a favor and drive it more,& the lifter's won't be clacking on start up.
It's a major design flaw, and the best you can do is run a quart of MMO in the oil 24/7/365.
It'll improve the weak lifter arragement as much as possible---other than having some non-draining lifter's manufactured.
T.K.
http://community.webtv.net/VanStuff/VanagonWestfalia
http://community.webtv.net/VanagonUsedParts/VanagonParts
"Ingorance Is A Powerful Tool If applied at The Right Time, Even Usually Surpassing Knowledge"
(E.J. Potter)
riceye
riceye is offline
PostPosted: Fri May 04, 2012 6:41 pm    Post subject: Reply with quote
On the upside, STP adds ZDDP to the oil. I add it to top up when changing the filter after the first 5000 miles on my 8-10,000 (annual) Mobil1 15w-50 oil change interval. Good for the next 3-5000 miles.
MMO a hundred miles or so before an oil change. Happy lifters.
'87 Westy Weekender - daily driver on salt-free roads
'96 4runner-latest winter beater. The '98 Tacoma 4x4 rusted out!
There's gonna be some changes made.
nemobuscaptain
nemobuscaptain is offline
PostPosted: Fri May 04, 2012 6:44 pm    Post subject: Re: WBX lifter clatter Reply with quote
Zeitgeist 13 wrote:
My van isn't a daily driver by any stretch, and is really more of a weekend warrior intended for hauling all manner of hardware and junk as required. Because it sits for extended periods of time, it can frequently experience the annoying lifter bleed-down syndrome. Based upon some recommendations I'd received from reputable folks, I bought some STP to address this condition. I poured the stuff in and let it sit overnight. When I started it up in the morning, there was not one hint of lifter tick to be found. I also poured a jar in my other off-brand vehicle which has roughly the same amount of miles and a slight lifter tick. The result of both applications: No ticks.
YMMV
What weight oil were you running before you put the sludge in?
Nemo, 91 Multivan, Cincy
www.Fullmoonbusclub.com
http://autos.groups.yahoo.com/group/ohiovalleytribe/
My favorite youtube site these days for learning auto body basics: https://www.youtube.com/user/ButlerCollision?feature=watch
Zeitgeist 13
PostPosted: Fri May 04, 2012 7:23 pm    Post subject: Reply with quote
I run Delo 15w40 in all my rigs...ugh, we're talking about oil again.
--Casey
'89 Bluestar
"Omnia Extares"
Wildthings
Wildthings is offline
PostPosted: Fri May 04, 2012 8:12 pm    Post subject: Reply with quote
Guess what??? There are directions on the bottle. Wink
Wildthings
PostPosted: Fri May 04, 2012 8:15 pm    Post subject: Reply with quote
As far as I am concerned the best long term solution is to run synthetic oils. It is all the broken down burned up additives that create the slug and varnish that coats engine parts. Since synthetics require far fewer additives you get far less crud building up in your oil.
Wildthings
PostPosted: Fri May 04, 2012 8:17 pm    Post subject: Reply with quote
Have you checked the amount of ZDDP in STP lately? The last time I checked (which was 3-4 years ago) it was about the same as SN save the catalyst motor oils.
morymob
morymob is offline
PostPosted: Sat May 05, 2012 3:53 am    Post subject: Reply with quote
I put a pint in each change and leave it there, oil change due so i'm leaving the MMO out and see, also T.K. i agree about no STP in oil, only rod brng i ever spun had that in the oil,??, never again,not a vw eng tho.
Zeitgeist 13
PostPosted: Mon May 07, 2012 11:16 am    Post subject: Update on the update Reply with quote
The van's sat for the last few days. I just fired it up and the clattah is back.
Soooo...
Snake oil #1: fail
I like what some folks mentioned about trying Snake oil #2, in order to remove the build up of varnish, so I may try that during my next oil change.
--Casey
'89 Bluestar
"Omnia Extares"
RicoS
RicoS is offline
PostPosted: Mon May 07, 2012 11:20 am    Post subject: Reply with quote
insyncro wrote:
. . . I use straight K1 to clean the internals....essentially MMO without the red dye.
OK, I give. What in the hell is K1?
Richie
Zeitgeist 13
PostPosted: Mon May 07, 2012 11:22 am    Post subject: Reply with quote
kerosene
--Casey
'89 Bluestar
"Omnia Extares"
dhaavers
dhaavers is offline
PostPosted: Mon May 07, 2012 11:23 am    Post subject: Reply with quote
K1 = highly refined low sulfur kerosene (like super clean diesel fuel)
86 White Westy Weekender
"The WonderVan"
Terry Kay
PostPosted: Mon May 07, 2012 11:55 am    Post subject: Reply with quote
Get the oil out of it, fill it with K-1, K-2, K-3 --who cares?
Clean the crap out a the engine, re-load wih the right oil--short yourself one quart so the Marvel will fit--and run the hell outa it.
Then cross yor finger's that whoever, wherever you got the thing from did't flog it to death & never serviced it.
These engines are known to rattle afer sitting awhile anyway.
The lifter's will bleed down, compounded by ( now ) glue in the crankcase.
Clean it out, run marvel all the time in the oil & the possibilites of the lifter's rattling will lessen--maybe it will go bye-bye.
Clean is good, gluing it up is bad.
T.K.
(E.J. Potter)
Zeitgeist 13
PostPosted: Mon May 07, 2012 12:05 pm    Post subject: Reply with quote
I've owned the van since '04 and purchased it from the original owners. It just needs to hang on until I have time/money to drop the Audi V6 in there.
--Casey
'89 Bluestar
"Omnia Extares"
Terry Kay
PostPosted: Mon May 07, 2012 1:33 pm    Post subject: Reply with quote
Get the glue outa it--flush it all out--and get some fresh oil & MMO in it.
You just might be suprised.
T.K.
(E.J. Potter)
nemobuscaptain
PostPosted: Mon May 07, 2012 6:05 pm    Post subject: Reply with quote
Well, there are basically two potential problems, crud or wear. When those lifters wear you get to the point of needing heavier oil. I had a WB that would clatter unless I ran SAE30, despite numerous attempts at cleaning it with MMO/CD2/ATF and all that other stuff. Only switching to a thicker oil worked.
When you are talking about hyd lifters, it's hard to avoid talking about oil. There are plenty of people out there running 5w30 or 0w20 (because that's what they ran in their Honda) who can't figure out while their lifters clatter in their 30 year old VW bus.
Wildthings
PostPosted: Mon May 07, 2012 6:25 pm    Post subject: Reply with quote
There are plenty of people that run 20w50 and can't figure out why their lifters clatter in the 30 year old VW either.
Reply to topic    Forum Index -> Vanagon/Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 2 of 6
