My 1964 air ride basketcase
Goto page Previous  1, 2, 3, 4  Next
super72beetle
super72beetle is offline
PostPosted: Sat Apr 28, 2012 8:42 pm    Post subject: Reply with quote
wow those colors look great together
sportin-wood
sportin-wood is offline
PostPosted: Sun Apr 29, 2012 12:16 am    Post subject: Reply with quote
Coming along nicely, looking good!
Click here to see my 66 project bug.
"Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it." --- Jeff Spicoli
windsoreight
windsoreight is offline
PostPosted: Sun Apr 29, 2012 11:08 am    Post subject: Reply with quote
Some daylight shots. I also started getting the dash together.
windsoreight
PostPosted: Sun Apr 29, 2012 8:34 pm    Post subject: Reply with quote
Here is some as a roller:
Just need some real tires and a boat load of parts. I have spent $3000 in parts in the last 2 weeks and I am not done. I figure another 2k in parts if I am lucky. It is the small stuff that hurts. It dosen't help that I went all out on a 2110 stroker.
windsoreight
PostPosted: Mon May 07, 2012 4:55 am    Post subject: Reply with quote
Here are some updates:
I have started working on the case and going through some of the parts I have. Having to decide on what I am using and what is getting tossed:
I rebuilt and painted the steering column, I still need the firewall grommet:
Wetsanding and buffing the paint, I hate this process:
I have the passenger fender bolted with all the fixins:
I recieved some of my new Scat interior:
Fabiandiaz1234
Fabiandiaz1234 is offline
PostPosted: Mon May 07, 2012 7:49 pm    Post subject: Reply with quote
What size tire are you running?
windsoreight
PostPosted: Tue May 08, 2012 4:34 am    Post subject: Reply with quote
I plan on running a 165/80/15. When I bought the car the guy had put Temp spare tires on the stock wheels.
windsoreight
PostPosted: Fri May 11, 2012 9:31 am    Post subject: Reply with quote
I have a few updates.
I recieved most of my engine parts from Scat. This included a 2110 stroker kit with forged crank. I had Scat balance everything, including the lightened flywheel and pressure plate. I have a set of Steve Tims stage 2 heads on the way:
I also got a welded fan and complete tin set from Scat. I painted the bare tins with VHT high temp wrinkle paint:
I also drilled the tapped the block for full flow. I decied to paint the block. I know lots of people frown on this but I have done a bunch of reading on this. I went with a satin black but it looks shiney in the pics:
I also insulated the car. I have carpet and a new headliner on the way:
I will finish up the interior in the next week. I am still missing pieces but that will take time. I will then start on the engine build.
sportin-wood
PostPosted: Fri May 11, 2012 9:43 am    Post subject: Reply with quote
Looking good! What product did you use to insulate the inside? Was it easy to work with? Any idea on how many square feet are needed for the inside (assuming roof, luggage area, floors, kick panels, even doors and quarter panels are done)?? Thanks
windsoreight
PostPosted: Sat May 12, 2012 4:36 am    Post subject: Reply with quote
I bought the stuff from Lowes. It is a heavy mylar insulation with air bubbles in it. I used 2 rolls that were 15" x 25', they cost about $15 a roll. I used 3m spray adhesive and a razor blade. It is real easy to install. I was going to go with dynamat but to do the whole car would be a fortune. I also did the doors and the area under the rear door panels.
windsoreight
PostPosted: Sat May 12, 2012 5:22 pm    Post subject: Reply with quote
I finally got my headliner and carpet. I was able to get the carpet in today. I also put all the seats in. I will have to pull the rear seat to do the headliner but wanted to see how it looks.
I also have the Clarion head unit installed. It is new and I already had it on the shelf. I was able to make it fit the console.
windsoreight
PostPosted: Fri May 18, 2012 6:38 am    Post subject: Reply with quote
Another update. I finally have the headliner in. I hate how it turned out. I got the 1 piece and I regret it. It could have done way better with the standard one. I have decided once I get the engine in I will make my own headliner. Until then I will keep putting the car together. I tinted the rear glass and have installed them. I need to get new vent windows to complete the doors. I also washed the car. I think I will polish it one more time once all the glass is in.
I am waiting on a few more parts to start on the engine build. I recieved my Steve Tims stage 2 heads and they look great. So soon the engine build will start. I am also getting tired on looking at it with the stupid donut tires on it. I have to get a set of real tires.
pfcmooney
pfcmooney is offline
PostPosted: Fri May 18, 2012 8:03 am    Post subject: Reply with quote
Looks friggin sweet dude! Have fun with that front window...geez. Just got through with that mess!
windsoreight
PostPosted: Fri May 18, 2012 12:29 pm    Post subject: Reply with quote
Thanks man. I am looking forward to it. I still have to buy a windshield. I will rounding the last remaining needed parts this weekend.
windsoreight
PostPosted: Fri May 25, 2012 9:13 am    Post subject: Reply with quote
Another small update. I rebuilt the stock wiper assembly. I had to go through the motor. I also rebuilt the stock horn and was able to get it working again. I picked up a leather Grant steering wheel off Ebay. So no mor vice grips. I have a new turn signal switch coming. I also rebuilt the fuel gauge and made a new cable for it.
Here in the wiper assembly painted with wrinkle paint and installed:
Some dash views:
I also picked up a set of Steve Tims stage 2 heads. They have 1500 miles on them and need some clean-up:
I am waiting on $60 worth of parts to get started on the motor. I can't wait to get going on it.
BugMan114
BugMan114 is offline
PostPosted: Wed Jun 06, 2012 9:46 pm    Post subject: Reply with quote
Nice work man. can't wait to see it finished Cool
1974 Super Beetle: Custom resto in progress
1972 Super Beetle: Daily Driver
1971 Std. Beetle w/ 1929 Mercedes Benz Gazelle kit
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Why the hell do they call it a gland nut. its obviously a big fat bolt!!!
windsoreight
PostPosted: Thu Jun 07, 2012 9:58 am    Post subject: Reply with quote
Thanks man. I have made baby steps on the bug. I have been screwed around by 3 vendors on the crank gears I need to start on my motor. I did get the doors together. I found a clean used fuel tank and painted it up. I also finished up the interior. My windshield is on the way.
windsoreight
PostPosted: Sat Jun 09, 2012 10:28 am    Post subject: Reply with quote
I now have a windshield and running boards.
JDGas
JDGas is offline
PostPosted: Sun Jun 10, 2012 12:10 am    Post subject: Reply with quote
windsoreight wrote:
I love that wrinkle paint. Your tins look awesome!
I just did a bunch of wrinkle paint myself today for my '69.
1959 Ragtop Beetle
1958 Danish Beetle
1967 SO-42 West. - sold
1961 Sunroof Beetle - sold
http://58stripper.blogspot.com
windsoreight
PostPosted: Sun Jun 10, 2012 6:53 am    Post subject: Reply with quote
I love it to. The gas tank had lots of dings and with the wrinkle paint it is hard to notice them.
Page 2 of 4
