wehrbüchse Samba Member
Joined: January 04, 2010 Posts: 229 Location: Seattle, WA (temporarily Lake County, CA)
Posted: Wed Apr 25, 2012 11:47 am Post subject: No compatible speedometers from other 1980s VWs? |
I took my 1.9 speedo apart the other day to get it working again. It seemed very simple at first: the top bar had simply edged its way over to the right (looking at it from behind), such that the gear wasn't engaging the worm gear. The far (left) end had a wimpy crimp to keep it from doing this. So I pushed it over. Speedo was back! ...for about 200 miles. It happened again, so I used some heavy duty vise-grips to flatten the far end of the bar so it couldn't get back through the wall. Problem solved! ...for a mile. I took it apart and used a drill to simulate the input drive. I could not for the life of me see what was going wrong, but it's farther down in the works.
I'd like to just swap from some other VW at the junkyard. No-go?
Thanks bros.
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 5331 Location: Syracuse, NY
Posted: Wed Apr 25, 2012 12:04 pm Post subject: |
I doubt it,
most 80s (watercooled) vws used the speedo driven from the transaxle.
and the little numbers in the lower middle of the speedo are around 1500 where your 2wd vanagon is around 850 I think.. that's the Rev's/mile
the differance that the 2wd van is driven from the front wheels like a classic beetle.
there's a few good threads here on speedo revival, and then i believe Van cafe sells/refurbishes vanagon speedos
best of luck.. I haven't had my Odo for alittle while.
and yes I tried to fix it once already too. _________________ VW Club of Central New York SPRING VW GTG
Upstate NY 2013 VWCCNY events
NY State VW Camping 2013 season events |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 3318 Location: Orbiting San Diego
Posted: Wed Apr 25, 2012 12:07 pm Post subject: Re: No compatible speedometers from other 1980s VWs? |
That is right, no go. All of the VW cars speedo cables spin about twice as fast at the same driving speed as 2wd Vanagon speedo cables. The speedo reading would be way off, half what it should be.
On the other hand Vanagon Syncro speedo cable speeds are close to the same as some VW cars.
Mark
| wehrbüchse wrote: | ??
Kinda surprising if not.
Thanks bros. |
Posted: Wed Apr 25, 2012 12:13 pm Post subject: |
| Bummer. Thanks guys. |
One more islander... Samba Member
Joined: May 14, 2010 Posts: 346 Location: Sunshine Coast, B.C.
Posted: Wed Apr 25, 2012 1:12 pm Post subject: |
The guys at VanCafe do a great job!
We bought our Westy with a non-functioning speedo, and had it fixed in Santa Cruz as a treat enroute down the West Coast--Vancouver to San Diego.
A well-spent $100 or so with a couple of hours to wander Santa Cruz. Done in fall 2010 and working great since then.
Kathy |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2190 Location: preskitt az
Posted: Thu Apr 26, 2012 7:31 am Post subject: |
are you interested in running a kph speedo _________________ (o\!/o)
58' pg/sg sub hatch westy
90' doka 1.6td jx import from germany |
rcook52459 Samba Member
Joined: August 24, 2011 Posts: 249 Location: PORTLAND ORE
Posted: Thu Apr 26, 2012 8:34 am Post subject: |
contact ashely at always-v-dub here in portland.he proably has one that will fit your van.503-235-2757 _________________ 85 westy tiico conversion.auto trans |
insyncro  Samba Member
Joined: March 07, 2002 Posts: 6533 Location: New York
Posted: Thu Apr 26, 2012 10:09 am Post subject: |
| I posted a good used 2wd speedo in the classifieds yesterday for short money. |
Posted: Tue May 08, 2012 2:57 pm Post subject: |
| insyncro wrote: | | I posted a good used 2wd speedo in the classifieds yesterday for short money. |
I'm interested, but two things:
(1) your speedometer is within 110 miles of mine! That's kinda weird.
(2) How long for this world can your speedo be with so many miles on it?
Edit:
Another way to put it is that my speedo went out less than 110 miles after the number of miles yours is at!  |
