55veedub Samba Member
Joined: May 12, 2008 Posts: 562 Location: North Bay, Ontario, Canada
Posted: Wed Apr 25, 2012 6:05 pm Post subject: 62 Electrical issues |
62 single cab with dual port 1600, 009 Dist, 34 pict3.
I did not do the 12V conversion. I am having the following issue and am unsure where to start.
Engine fires up and idles fine...after a minute or so it bogs down as if the alt is charging and if the headlights are turned on and you rev it up the lights will get brighter and as the RPM falls back down to bogging idle they dim down a bit...
Where should i start looking for the problem and what could it be?
Any help would be great!
Thanks!
Mike _________________ '62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
'70 Canadian standard bug. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 9655 Location: Olympia Wash Rinse & Repeat
Posted: Wed Apr 25, 2012 8:06 pm Post subject: |
Full tune up. _________________ In Stereo, Where Available! |
Posted: Thu Apr 26, 2012 7:07 am Post subject: |
I just did a complete tune up, carb rebuild, points, condenser, plugs, cap, rotor, wires, oil, air filter.
It just seems the alternator (or something else) is drawing power and setting the alt to charge...
Is there a way to test the alt or regulator?
Another issue was that the gauge lights will come on and the taillights with the switch in the off position...but this is intermittent. _________________ '62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
Posted: Thu Apr 26, 2012 6:03 pm Post subject: |
Ok so I did more investigating and its almost like the system is being back fed.
With the alternator connected and engine running, the fuel gauge reads 1/2. with the alternator charge wire disconnected the fuel gauge reads R (which is where it should be, theres less than 5gal of fuel in it)
any ideas?? _________________ '62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
quartermilecamel  Samba Member
Posted: Thu Apr 26, 2012 6:40 pm Post subject: |
Im kinda lost here, as usuall , but how can you not do a 12v conversion, yet have an alternator? Bad ground at the fuel guage? _________________ Looking for the U shaped swing arm for sliding door split. Left hand drive. Baywindow arms are 1/2 inch longer. |
Posted: Thu Apr 26, 2012 6:42 pm Post subject: |
I personally did not do the 12V conversion...so i dont know what was done. it is 12V though.
Its also effecting the park/gauge lamps aswell as the fuel gauge... _________________ '62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
Posted: Thu Apr 26, 2012 6:55 pm Post subject: |
Sounds like you need to fix grounds and go through the wiring cleaning, tightening and checking for voltage drops as you go. _________________ In Stereo, Where Available! |
Posted: Fri Apr 27, 2012 7:02 am Post subject: |
So would bad grounds cause this? _________________ '62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
Posted: Fri Apr 27, 2012 7:16 am Post subject: |
Park and gauge lights yes.
Headlights getting dim/bright with engine revs more likely is wiring voltage drops. Need to check voltage at battery and how much of that is getting to various places in the wiring. Have found 2 or more volts drop, and have been able to reduce that to less than 1/10 of a volt. _________________ In Stereo, Where Available! |
Posted: Fri Apr 27, 2012 3:15 pm Post subject: |
How hot does the headlight switch shaft get when you turn on the headlights? If it gets hot at all, or warmer, then its time to get it rebuilt with soldered internal connections, or get a replacement. Thats one major voltage drop right there. _________________ Looking for the U shaped swing arm for sliding door split. Left hand drive. Baywindow arms are 1/2 inch longer. |
IN2RUST  Samba Member
Joined: October 30, 2005 Posts: 1869 Location: Folsom Prison.
Posted: Fri Apr 27, 2012 4:53 pm Post subject: |
That is an open circuit as well. _________________ Dawerks wrote "the heat is too much for the shaft"
$$ Wanted, Original Paint 15 or 23 window Deluxe Bus.
RUSTFARMER....I like anything old and rusty (Aged).
I'm stuck in Folsom Prison.... and time keeps Dragging On.......... |
Posted: Fri Apr 27, 2012 8:21 pm Post subject: |
Ok so heres the scoop. I went through the under dash wiring... what a mess. I rewired it back to stock configuration. There were lots of strange wiring with the light bulbs, and such and wires not going where they were supposed to.
Results:
-So far the park lights and gauge lights do not come on.
-With headlights on I am now able to dim the gauge lights, I was not able to before, they were always on.
One more issue i cant figure out.
My fuel gauge still reads 1/2 when i know it should be at R. When i disconnect it, it drops to E.
I read alot about bad grounds and gauges being stuck at full or E. But what would make it stay at 1/2? _________________ '62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
olliehank47 Samba Member
Posted: Sat Apr 28, 2012 8:04 am Post subject: |
| 55veedub wrote: |
Results:
I read alot about bad grounds and gauges being stuck at full or E. But what would make it stay at 1/2? |
Don't understand one thing from above. You said the gauge lights do not come on but then you say, "I am now able to dim the gauge lights..." Can you clarify?
The gas gauge can act very strangely if the body of the gauge is not well grounded to the dash, via the clamp that holds it in. If the ground is poor, the gauge will read incorrectly as soon as the light switch (which controls the gauge light) is turned on. Try polishing up the rear of the dash where the clamp teeth bite and securely tighten the thumb nuts for the gauge. |
Posted: Sat Apr 28, 2012 9:21 am Post subject: |
Yes before I went through the wiring, with the engine running the park lights would stay on full with the switch in off position (gauge lights were wire to the same circuit) and i was unable to dim them, they were just on full..
After rewiring, the park light havent come back on with the switch off and the gauge lights aswell. With the light switch on the park lights and the gauge lights are now on and the gauge lights are now dimmable.
Ill try to ground the gauge better and see what happens. _________________ '62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
Posted: Sat Apr 28, 2012 9:23 am Post subject: |
There also should be a ground wire going from the fuel sender to the body, but that is kind of hard to get to with engine in. _________________ In Stereo, Where Available! |
Posted: Tue May 08, 2012 5:47 pm Post subject: |
Ok so heres the status.
I rewired the dash, switches, and gauges.
Added ground wire to the fuel gauge.
Re did gorund on fuel tank sender.
The back feeding problem was from a wire from drivers taillight that was connected to fused side of fuse panel (so it was being powered with fuses pulled.) Which in turn went through the improperly wired gauge lights keeping them on full.
SO my only issue now is that the fuel gauge still reads half full when empty. as the tank is filled, it goes up from there. _________________ '62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
Posted: Tue May 08, 2012 6:29 pm Post subject: |
Darn! Sounds like you will have to pull the fuel tank sender and either fix it or replace. _________________ In Stereo, Where Available! |
BenTen Samba Member
Joined: May 27, 2011 Posts: 133 Location: Anderson, SC
| Have you tested your fuel sender? Sounds like it may either be shorted or the float isn't sliding all the way down in the tube. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 24136 Location: Surrey B.C. Canada, Land of the giant flying moose!
Posted: Tue May 08, 2012 6:39 pm Post subject: |
| 55veedub wrote: |
| My fuel gauge still reads 1/2 when i know it should be at R. When i disconnect it, it drops to E. |
Where are you disconnecting it?, at the gauge or at the tank? _________________ Rust NEVER sleeps and stock never goes out of style.
Wanted, 68-73 westy OG plaid curtains, singles OK. |
Posted: Wed May 09, 2012 7:07 am Post subject: |
If i disconnect it at the gauge it reads Empty
If i pull the ground on the sender, it reads full. I think..... cant remember exactly. _________________ '62 Single Cab
'68 Bug eye Baja.
'69 Volksrod
