bugmanNDsun Samba Member
Joined: June 23, 2004 Posts: 31 Location: Norfolk Virginia
Posted: Mon Feb 28, 2011 6:19 pm Post subject: Speed Sensor for Trike |
| Any body done this? I want to put a sensor off the rear axle or off the flywheel some how. Do not want any cables on my front fork. Any ideals? Thanks, Kent |
The dark angel Samba Member
Posted: Tue Mar 15, 2011 1:24 pm Post subject: Re: Speed Sensor for Trike |
| bugmanNDsun wrote: | | Any body done this? I want to put a sensor off the rear axle or off the flywheel some how. Do not want any cables on my front fork. Any ideals? Thanks, Kent |
A GOOD SITE TO JOIN UP ON FOR THIS IS Triketalk.com lots of people there can help.. I am also doing a vw trike. I have seen this done before you have to drill the tin behind the hub and be careful of placement check out the other site prolly can help better. |
didget69 Samba Member
Joined: July 22, 2004 Posts: 2806 Location: Capital, North Carolina
Posted: Mon May 07, 2012 12:07 pm Post subject: Speed sensor |
I've seen solutions like this used to provide a signal for an aftermarket electronic speedometer...
http://www.lindseyracing.com/LR/Parts/968SPEDO.html
This application is too large for a T1 CV, but similar sized chopper wheels are available for T1 CV's.
bryan _________________ Internet listed credentials impress no one but Mom... |
Posted: Mon May 07, 2012 1:12 pm Post subject: |
| Thanks...thats really along the lines for what I am looking to do.... |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 4357 Location: Northern California
Posted: Tue May 08, 2012 10:09 pm Post subject: |
I think this would actually be easier than a chopper wheel(a lot easier if you have a swingaxle and no CVs) and probably just as cheap and accurate
http://quicksincgps.com/ |
Posted: Fri May 11, 2012 7:58 am Post subject: |
Another chopper wheel/pulse generating ring source -
http://www.pacificcustoms.com/pulse-generators-for-speedometers.html
The Quick Sync GPS was an option that I wasn't aware of... how does it do in mountainous terrain/cities with high-rise buildings, etc? Any tales of satellite 'line of sight' issues? _________________ Internet listed credentials impress no one but Mom... |
Posted: Fri May 11, 2012 12:01 pm Post subject: |
| I'm sure there are interruptions in areas like you mention, but its probably rare unless you live in a city like NY and if you stay moving its probably brief. |
