Patricks 21-Window Resto
Page: Previous  1, 2, 3 ... 5, 6, 7 ... 27, 28, 29  Next
exciter
exciter is offline
PostPosted: Wed May 09, 2012 5:03 pm    Post subject: Reply with quote
[img]
[/img]
Joe
419-236-9781
zuggbug
zuggbug is offline
PostPosted: Wed May 09, 2012 5:19 pm    Post subject: Reply with quote
Great job on the jack point, I do not think it was welded that good from the factory.
SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy
Iozzio
Iozzio is offline
PostPosted: Sun May 13, 2012 8:25 am    Post subject: Reply with quote
Looking good brother!
Paul Iozzio
www.iozziowheels.com
tlambert
tlambert is offline
PostPosted: Tue May 15, 2012 7:17 pm    Post subject: Reply with quote
Joe, where are you hiding?
Progress pics?
exciter
exciter is offline
PostPosted: Fri Jun 08, 2012 4:40 pm    Post subject: Reply with quote
Okay, Patrick has been paitiently waiting as we finished up a couple other customer cars. and now its all him till the end. I finished welding in the under side structure including crossmembers, outriggers, jack points and top hats etc. Then I sand blasted the belly side and epoxy primed the entire area. I also got his long rocker welded into place and the inner structure bottome along with the lower B pillar section., I then ren a wire reammer down each cable tube under neath to make sure all of them were clear. and then prepped and installed his new belly pans!!!!!
I also finised up the frame repair sections as well. We should be ready to trial fit his over the top and one of a kind suspension/tire combo by the end of next week to see if we need to make any wheel well mods beofre painting the underside!!!!! Very Happy Patrick does have his under side color picked out but i think i will hold out telling it till I bring it out of the paint booth!!!!! Its going to be a Killer color combination for sure!!!!!
[img]
Joe
419-236-9781
flemcadiddlehopper
flemcadiddlehopper is offline
PostPosted: Fri Jun 08, 2012 8:03 pm    Post subject: Reply with quote
Wow, very nice work...this will be a sweet Bus in the end.
One question, the cross member that is the centre seat belt mounting points. Did you save / use the original one, or purchase a new one? I was unable to source one out for my restoration (but was able to save it).
gordo.
ducatis
ducatis is offline
PostPosted: Fri Jun 08, 2012 11:12 pm    Post subject: Reply with quote
Joe
That really is better than new!
Rename your sign in as bussurgeon Smile
Be sure to 'Like' my Facebook page Wink
www.facebook.com/vwsambavan
exciter
exciter is offline
PostPosted: Sat Jun 09, 2012 1:09 pm    Post subject: Reply with quote
Thanks for the kind words gentlemen!!! Cool
Gordo, we were able to save Patricks middle crossmember fortunatly. However i would THINK Gerson probably offers that section if needed but dont know for sure. Also If he didnt and we needed one we would take a regular crossmember and with a little fabrication and welding we would have one to install. You would just need some measurements to go off of. If you need measuremenst give me a shout and I will get you some.
Thanks and Good Luck.
Joe
419-236-9781
BuglessInGrimsby
BuglessInGrimsby is offline
PostPosted: Mon Jun 11, 2012 10:31 am    Post subject: Reply with quote
Patrick,
Very jealous. Hope I catch you at Jitterbug and you can tell me more about the plans..
Matt
tlambert
tlambert is offline
PostPosted: Mon Jun 11, 2012 8:53 pm    Post subject: Reply with quote
Joe, glad to see you back at it.
That is a shit load of welding. Shocked
exciter
exciter is offline
PostPosted: Wed Jun 13, 2012 6:58 am    Post subject: Reply with quote
Patrick,
I didnt get a chance to update your thread last night so I figured i would take a minute and get you caught up this morning/
I got your front lower nose skin all welded up and ground down and shaved your old antena holes and other misc who knows what holes that were drilled in to her??. I then moved to the rear of your bus and got your frame straightened the rest of the way and welded back up from the previous wreck damage. I then installed your new battery tray and right side engine sheet metal then welded the rear corner skin back into place. And aligned your decklid opening and apron fitting area. MOst all of the large welding and rust repair is pretty much complete. and Now theres just a bunch of smalltedious spots of rust that we need to get rid of next. And then it will be go time for bodywork!!!!!!!
[/img]
Joe
419-236-9781
exciter
exciter is offline
PostPosted: Wed Jun 13, 2012 7:27 pm    Post subject: Reply with quote
Another good day of welding on this beast!!!!!! Not a whole lot for pics but another day closer to completion. I spent most ofthe day welding up small pinholes and small misc rust areas. I also got the rear underside heat duct welded in place and then pre fit the safaris and got the brackets welded onto the front pillars!
Joe
419-236-9781
earlywesty
earlywesty is offline
PostPosted: Thu Jun 14, 2012 3:37 pm    Post subject: Reply with quote
East Coast Cornerstore has them in stock, in Canada. I was looking at the shelves of metal today when I picked up my order, quality is amazing.
http://www.thesamba.com/vw/classifieds/detail.php?id=1318909
Vintagespeed
Vintagespeed is offline
PostPosted: Thu Jun 14, 2012 4:07 pm    Post subject: Reply with quote
that is going to be one SWEET bus!
those custom rims are also supernice.
makes me want to detail my own bus even more too Very Happy it's these kind of threads that trigger these energetic emotions
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
Jerry
Jerry is offline
PostPosted: Thu Jun 14, 2012 5:02 pm    Post subject: Reply with quote
Lookin real good Joe!
This one looked a little tougher than others.
Looking for SO34 parts.
thevwcompound *instagram*
exciter
exciter is offline
PostPosted: Fri Jun 15, 2012 6:32 pm    Post subject: Reply with quote
Thanks guys!!!! Yeah Jerry this ole girl has seen better days but fortunatley theres guys out there saving these girls because once there gone there gone!!! Very Happy
I ve been welding away on all the misc rust spoyts on this beast. I wrapped up the right front wheel well rust repair and then just about have both rear wells repaired. About a day or two away from prepping the bottom for paint i believe! Cool I also layed out your donor parcel tray and got the old swiss cheese cut out and the donor section welded in . Then i cut out your acess hole so that you have plenty of access room to fine tune that Killer type 4 motor your putting in her! Very Happy Cool I then started fabricating the channel for the cover to sit in. I was lucky to find a type 3 engine cover local however the guy wouldnt let me cut out teh surrounding metal for the channel it sits in so I said to hell with it and started fabbing you one up!!!!!
[img]
[/img]
Joe
419-236-9781
tlambert
tlambert is offline
PostPosted: Fri Jun 15, 2012 9:37 pm    Post subject: Reply with quote
Nice work Joe!
cjsmitty
cjsmitty is offline
PostPosted: Sat Jun 16, 2012 7:27 am    Post subject: Reply with quote
Hell yeah Joe Applause Applause
Corey
https://www.facebook.com/pages/Smittys-Auto-Body-Collision-Repair-Restoration/394733633959825
http://instagram.com/smittys_auto_body
tlambert
tlambert is offline
PostPosted: Sun Jun 24, 2012 6:48 pm    Post subject: Reply with quote
Joe where are you hiding?
Haven't heard from you lately!
exciter
exciter is offline
PostPosted: Mon Jun 25, 2012 8:02 pm    Post subject: Reply with quote
Im still here guys. Ive been grinding and welding away at all the little reas that were rusty!!! Not a lot to see but a lot of progress none the less! I did locate a heater log and sandblasted it then got it welded in place. I also got both right side wheel wells all done and just about done with the left side. So the bottom is just about wrapped up! Hopefully by the end of the week i will have some good photo worthy progress for you Patrick!!!
Joe
419-236-9781
Page 6 of 29
