exciter Samba Member
Posted: Wed May 09, 2012 5:03 pm Post subject: |
[img][/img] _________________ Joe
419-236-9781 |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Wed May 09, 2012 5:19 pm Post subject: |
Great job on the jack point, I do not think it was welded that good from the factory. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Iozzio Samba Member
Joined: March 10, 2005 Posts: 354 Location: Molalla Oregon
Posted: Sun May 13, 2012 8:25 am Post subject: |
Looking good brother! _________________ Paul Iozzio
www.iozziowheels.com |
tlambert Samba Member
Posted: Tue May 15, 2012 7:17 pm Post subject: |
Joe, where are you hiding?
Progress pics? |
Posted: Fri Jun 08, 2012 4:40 pm Post subject: |
Okay, Patrick has been paitiently waiting as we finished up a couple other customer cars. and now its all him till the end. I finished welding in the under side structure including crossmembers, outriggers, jack points and top hats etc. Then I sand blasted the belly side and epoxy primed the entire area. I also got his long rocker welded into place and the inner structure bottome along with the lower B pillar section., I then ren a wire reammer down each cable tube under neath to make sure all of them were clear. and then prepped and installed his new belly pans!!!!!
I also finised up the frame repair sections as well. We should be ready to trial fit his over the top and one of a kind suspension/tire combo by the end of next week to see if we need to make any wheel well mods beofre painting the underside!!!!! Patrick does have his under side color picked out but i think i will hold out telling it till I bring it out of the paint booth!!!!! Its going to be a Killer color combination for sure!!!!!
[img]
419-236-9781 |
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2332 Location: Kelowna, BC. Canada.
Posted: Fri Jun 08, 2012 8:03 pm Post subject: |
Wow, very nice work...this will be a sweet Bus in the end.
One question, the cross member that is the centre seat belt mounting points. Did you save / use the original one, or purchase a new one? I was unable to source one out for my restoration (but was able to save it).
gordo. |
ducatis Samba Member
Joined: August 24, 2009 Posts: 96 Location: Doing the Samba (Sometimes the panel)
Posted: Fri Jun 08, 2012 11:12 pm Post subject: |
Joe
That really is better than new!
Rename your sign in as bussurgeon _________________ Be sure to 'Like' my Facebook page
www.facebook.com/vwsambavan |
Posted: Sat Jun 09, 2012 1:09 pm Post subject: |
Thanks for the kind words gentlemen!!!
Gordo, we were able to save Patricks middle crossmember fortunatly. However i would THINK Gerson probably offers that section if needed but dont know for sure. Also If he didnt and we needed one we would take a regular crossmember and with a little fabrication and welding we would have one to install. You would just need some measurements to go off of. If you need measuremenst give me a shout and I will get you some.
Thanks and Good Luck. _________________ Joe
419-236-9781 |
BuglessInGrimsby Samba Member
Posted: Mon Jun 11, 2012 10:31 am Post subject: |
Patrick,
Very jealous. Hope I catch you at Jitterbug and you can tell me more about the plans..
Matt |
Posted: Mon Jun 11, 2012 8:53 pm Post subject: |
Joe, glad to see you back at it.
That is a shit load of welding. |
Posted: Wed Jun 13, 2012 6:58 am Post subject: |
Patrick,
I didnt get a chance to update your thread last night so I figured i would take a minute and get you caught up this morning/
I got your front lower nose skin all welded up and ground down and shaved your old antena holes and other misc who knows what holes that were drilled in to her??. I then moved to the rear of your bus and got your frame straightened the rest of the way and welded back up from the previous wreck damage. I then installed your new battery tray and right side engine sheet metal then welded the rear corner skin back into place. And aligned your decklid opening and apron fitting area. MOst all of the large welding and rust repair is pretty much complete. and Now theres just a bunch of smalltedious spots of rust that we need to get rid of next. And then it will be go time for bodywork!!!!!!!
419-236-9781 |
Posted: Wed Jun 13, 2012 7:27 pm Post subject: |
Another good day of welding on this beast!!!!!! Not a whole lot for pics but another day closer to completion. I spent most ofthe day welding up small pinholes and small misc rust areas. I also got the rear underside heat duct welded in place and then pre fit the safaris and got the brackets welded onto the front pillars!
419-236-9781 |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2356 Location: In the woods, Ontario
Posted: Thu Jun 14, 2012 3:37 pm Post subject: |
exciter wrote: |
Thanks and Good Luck. |
East Coast Cornerstore has them in stock, in Canada. I was looking at the shelves of metal today when I picked up my order, quality is amazing.
http://www.thesamba.com/vw/classifieds/detail.php?id=1318909 |
Vintagespeed Samba Member
Joined: October 01, 2005 Posts: 579 Location: Westerlo (Belgium)
Posted: Thu Jun 14, 2012 4:07 pm Post subject: |
that is going to be one SWEET bus!
those custom rims are also supernice.
makes me want to detail my own bus even more too it's these kind of threads that trigger these energetic emotions |
Jerry Samba Member
Posted: Thu Jun 14, 2012 5:02 pm Post subject: |
Lookin real good Joe!
This one looked a little tougher than others. _________________ Looking for SO34 parts.
thevwcompound *instagram* |
Posted: Fri Jun 15, 2012 6:32 pm Post subject: |
Thanks guys!!!! Yeah Jerry this ole girl has seen better days but fortunatley theres guys out there saving these girls because once there gone there gone!!!
I ve been welding away on all the misc rust spoyts on this beast. I wrapped up the right front wheel well rust repair and then just about have both rear wells repaired. About a day or two away from prepping the bottom for paint i believe! I also layed out your donor parcel tray and got the old swiss cheese cut out and the donor section welded in . Then i cut out your acess hole so that you have plenty of access room to fine tune that Killer type 4 motor your putting in her! I then started fabricating the channel for the cover to sit in. I was lucky to find a type 3 engine cover local however the guy wouldnt let me cut out teh surrounding metal for the channel it sits in so I said to hell with it and started fabbing you one up!!!!!
[img]
419-236-9781 |
Posted: Fri Jun 15, 2012 9:37 pm Post subject: |
Nice work Joe! |
cjsmitty Samba Member
Joined: November 12, 2006 Posts: 811 Location: Meadow Vista CA
Posted: Sun Jun 24, 2012 6:48 pm Post subject: |
Joe where are you hiding?
Haven't heard from you lately! |
Posted: Mon Jun 25, 2012 8:02 pm Post subject: |
Im still here guys. Ive been grinding and welding away at all the little reas that were rusty!!! Not a lot to see but a lot of progress none the less! I did locate a heater log and sandblasted it then got it welded in place. I also got both right side wheel wells all done and just about done with the left side. So the bottom is just about wrapped up! Hopefully by the end of the week i will have some good photo worthy progress for you Patrick!!!
419-236-9781 |
