912 engine in a 356
MMW
MMW is offline
PostPosted: Fri May 11, 2012 3:51 am    Post subject: 912 engine in a 356 Reply with quote
My 356 has an engine # that is from a 1968 912. When looking for parts or tech info such as valve clearance etc. do I use the 912 # or are these engines the same engine just different years? I know mine is not a stock engine & has been modified but other than that I don't know what's in it.
Mic McWilliams
1959 356 coupe
Missing the original engine 72488
Anybody have it?
Bub
Bub is offline
PostPosted: Fri May 11, 2012 10:45 am    Post subject: Reply with quote
Go with the 912 specs when ordering parts- the engines are very similar, but a huge amount of sensitive parts are different and NOT interchangeable. Also, 356 parts are about 5X the price!
hitest wrote:
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was...
MMW
MMW is offline
PostPosted: Sat May 12, 2012 3:57 am    Post subject: Reply with quote
Next question, is it possible to use a 912 case with 356 parts? Can the heads be 356's. Do the heads have #'s I can look up? Sorry for what is most likely dumb questions but I'm trying to learn as much as possible about what I have & I'm new to working on air-cooled engines.
A little background on my motor. It was built sometime in the late seventies & stored until the mid ninties when it was installed. No one remembers what went into it just rumors. Supposedly it had the "best" stuff. Rumors say it has a roller crank, big pistons, custom cam, possible head work. On the outside it has a pair of 48ida's & a header set up. It runs really well.
Mic McWilliams
1959 356 coupe
Anybody have it?
Bub
Bub is offline
PostPosted: Sat May 12, 2012 12:55 pm    Post subject: Reply with quote
Yep, you can easily use a 912 case with a 356 setup, and it's not uncommon.
The heads will interchange also, but the rocker arms were changed a few times, along with the nuts that hold the heads on, etc..there are different length pushrods and some have different ends specific to early/late rock feet or lifters. The heads have part #'s cast into them under the rocker arm assemblies.
As far as your engine-- you'll never know what in it until you look, and why bother if it runs great. if it runs REALLY good then it's probably stock, since those special internals are hard to set up and cost a HUGE amount of money. There are really only a handful of people left that are really educated and qualified to build a roller bearing 912 engine- and I think they rarely advise people do that. It's no more reliable (probably the opposite) and very very expensive with not much benefit. There are a variety of cam grinds and pistons etc..
ensys
ensys is offline
PostPosted: Sat May 12, 2012 10:22 pm    Post subject: Reply with quote
MMW:
Unless you are an incredibly lucky person by nature, you really ought to open it up some to see what kind of pig is in that poke.
At the very least, you should verify that they were lying about the roller crank, because if they were'nt and if it isn't shot already, it soon will be in road car use.
Give yourself a big break and start some investigative work. Pulling the sump plate is an small and easy start and will let you id the crank and rods and the conditions inside the case (including the gunk in the bottom and around the magnet). Of course, it will not tell you if the rods match or the weight is the same. And you will not be able to check the type or condition of the cam or lifters...
Pull the valve covers and you can see which lifter rig and pushrod type is present. Its not much, but its better than nothing.
You won't want to hear this but the smart thing is to gird your grid and pull that puppy apart and rebuild it. Its the only way you can be certain of anything.
The lesson here is that the wise fellow always figures a rebuild into the price he pays for a "mystery motor".
Good luck.
Keep 'em flying...
S.J.Szabo
MMW
MMW is offline
PostPosted: Sun May 13, 2012 4:51 pm    Post subject: Reply with quote
Thanks for the info. I had the sump plate off not long ago & did look inside & it was spotless. Didn't know what else to look for. I've since read that a plain bearing crank should look rough & dark like a casting. A roller crank would look shiny like machined. I'll definitely look next time I pull the sump cover.
I plan on checking the valve adjustment in the near future as it sounds like it might have a loose one. At least if it was a small block chevy that is the sound I hear. Not bad just a slight tap. When I do that I'll look for numbers & take a few pics.
Mic McWilliams
1959 356 coupe
Anybody have it?
r39o
Samba Polizei
r39o is offline
PostPosted: Sun May 13, 2012 7:26 pm    Post subject: Reply with quote
I have done this 912 616/xx engine in a 356 trick.
Nothing to get excited about.
The ONLY truly custom part is the cover behind the engine pulley. It needs a two more dimples in it to cover the engine case cover. That is because of the mounts for the 912 engine bar.
What your REALLY need is the little Porsche specs book which tells you the dimensions of the internal parts.
You build it by the spec book not by what some one tells you.
So your BEST bet is to yank it apart and mark things as you go.
Then assemble and measure just like any other Porsche engine build.
Now in my youth when I basically built engines from parts we had laying around I could only go by inspection. You have to measure and remeasure all the time anyways.
If you feel afraid of this, then let some one with knowledge do it.
I never was afraid, we had too much of the junk laying around.
Times are different and that old junk is gold now, so some people think it is some sort of magic.
No magic.....
MMW
MMW is offline
PostPosted: Mon Jun 04, 2012 4:21 pm    Post subject: Reply with quote
There is a number cast into the heads in between the intake pushrods. It is 101/7 & then under it is an H. Does this help identify anything?
Mic McWilliams
1959 356 coupe
Anybody have it?
ensys
ensys is offline
PostPosted: Mon Jun 04, 2012 6:36 pm    Post subject: Reply with quote
Mr. McWilliams:
I gotta say that this initial probe does not bode well for the validity of the "rumors" that came with the engine.
First, those are the older, cast iron, rocker assemblies. Of the two possibilities, this is not the best.
From here on out its a crapshoot as to what parts the engine was actually built with.... and how.....
Do what you feel comfortable with, but realize that if its just "dump some oil in it and its down the road", the wisest course would be to treat it like it was built with crap by monkeys.
The casting date is usually (on these early heads) in the format of number/dots in a circle, probably under the rockers.
I mean this: If you don't crack it open; Good Luck.
Or...... you could take the time to educate yourself a bit with Elfrink or Mr. Pellow's "Secrets".....
Keep 'em flying...
S.J.Szabo
Jon Schmid
Jon Schmid is offline
PostPosted: Mon Jun 04, 2012 8:15 pm    Post subject: 912 engine in a 356 Reply with quote
"...roller bearing 912 engine"? Since when? Just curious. Confused
Jon
MMW
MMW is offline
PostPosted: Tue Jun 05, 2012 3:06 am    Post subject: Re: 912 engine in a 356 Reply with quote
Jon
Like I said earlier all I know is rumors from the mid seventies. I was maybe 12-14 years old at the time & my Dad is now in his early eighties & doesn't remember. He never did much in the way of work on the car anyway & I never paid much attention at the time. I don't know much about 356's but am on a crash course now. Don't be to hard on me.
Since the engine has been in the car running since the mid-ninties until the dowel pins broke recently I don't think I'll pull it apart just to satisfy my curiousity. I trust it was built correctly.
Thank you for your help. I have ordered the Elfrinks manual & will be reading through it.
Mic McWilliams
1959 356 coupe
Anybody have it?
356JAEGER
356JAEGER is offline
PostPosted: Tue Jun 05, 2012 7:45 am    Post subject: Reply with quote
The cost of 912 engine parts and 356 engine parts are the same since they are for the most part.
Regards,
Joel Jensen
When in doubt, think about it..
The outcome of a project is directly proportional to its preparation.
ensys
ensys is offline
PostPosted: Tue Jun 05, 2012 9:37 pm    Post subject: Reply with quote
Mr. McWilliams:
I can see your point. Still, unknown conditions can lead to surprising results, as the dowels have demonstrated (which remains a most peculiar incident). I would still council gentle demand and a low rev limit.... It'll improve the odds of a longer life.
Keep 'em flying...
S.J.Szabo
