Fuel Pump Wires? Help
Vintage Man
Vintage Man is offline
PostPosted: Sat May 12, 2012 11:24 am    Post subject: Fuel Pump Wires? Help Reply with quote
I recently rebuilt the wires for my fuel pump but forgot where they go.. Its a 66 Squareback electric pump, two wires.. one is ground but i dont know where the power wire hooks into?
Would love some help.
Thanks! Very Happy
blankmange Premium Member
Type 3 Darksider
blankmange is online now
PostPosted: Sat May 12, 2012 11:40 am    Post subject: Re: Fuel Pump Wires? Help Reply with quote
Thanks! Very Happy
we'll need a bit more info, since a '66 square would have had carburetors and a manual pump...
perhaps a pic or two?
19super73 wrote:
You wouldn't understand intelligent humour even if it slapped you upside your SOS pad head.
póg mo thóin
Certified DHS Technician
Samba Member # 24517
Vintage Man
PostPosted: Sat May 12, 2012 11:43 am    Post subject: Re: Fuel Pump Wires? Help Reply with quote
Thanks! Very Happy
All i can say is that it has an electric pump. It was converted to 12v and that it does have dual dellorto carburetors. I know the brand of the pump.. http://vwparts.aircooled.net/Facet-Electric-Fuel-Pump-3psi-p/1008.htm
Sorry, i dont know too much about it.
Tram Premium Member
Samba Socialist
Tram is offline
PostPosted: Sat May 12, 2012 11:52 am    Post subject: Reply with quote
Where on the car is the pump located?
Give A Pal a Hand!
www.happytrailsfarm.org
May 4, 1970... Never Forget.
RIPRW
"Hell is- other people."- Jean- Paul Sartre
Vintage Man
PostPosted: Sat May 12, 2012 12:22 pm    Post subject: Reply with quote
Under the tank, attached to the front end. Im just trying to figure out where the wires go. there are only two.
Tram Premium Member
Samba Socialist
Tram is offline
PostPosted: Sat May 12, 2012 12:45 pm    Post subject: Reply with quote
Right. The ground should attach to the body, and the best place for your + would be off of the key switched portion on the bottom of fuses 9-10 (where they're bridged at the rear bottom of the fuse box). Be sure to put an inline 16 amp (red) fuse to your electric pump.
Give A Pal a Hand!
RIPRW
Vintage Man
PostPosted: Sat May 12, 2012 12:59 pm    Post subject: Reply with quote
GREAT!! thank you kindly! Very Happy
Vintage Man
PostPosted: Sun May 13, 2012 4:54 pm    Post subject: Reply with quote
Can you specify which side on this photo? http://www.thesamba.com/vw/archives/info/wiring/66type3fuses.jpg
Thanks.
Tram Premium Member
Samba Socialist
Tram is offline
PostPosted: Sun May 13, 2012 5:15 pm    Post subject: Reply with quote
Thanks.
Last two fuses on the right- Wipers, stop lights, turn signals, warning lights, gauges- the key- activated stuff.
Give A Pal a Hand!
RIPRW
Bobnotch
Bobnotch is offline
PostPosted: Sun May 13, 2012 5:20 pm    Post subject: Reply with quote
Tram wrote:
Thanks.
You should also add an impact switch to turn the pump off in case of an accident (and you can't turn off the key). Ford makes a nice one that can be found in a bunch of their cars (usually in the left rear corner section of the trunk), or get a new 1 from the dealer for around 10 bucks.
Bob 65 Notch S with Sunroof
71 Notch ...aka Krunchy; build pics here; http://www.thesamba.com/vw/forum/viewtopic.php?t=240540 -tear down
Vintage Man
PostPosted: Sun May 13, 2012 5:35 pm    Post subject: Reply with quote
Tram wrote:
Thanks.
THANKS!
Vintage Man
Bobnotch wrote:
Tram wrote:
Thanks.
There is a ford dealer near my home.. ill go check it out.
