Are all vw oil Drain gasket the same?
Goto page 1, 2  Next
beebeecivic
beebeecivic is offline
PostPosted: Sat May 12, 2012 1:39 pm    Post subject: Are all vw oil Drain gasket the same? Reply with quote
I am in the proccess of changing the oil on the beetle. I want to to know whether if all the gaskets are the same? I'm trying to buy from either pepboys or autozone.
Thanks!
Bruce
Bruce is offline
PostPosted: Sat May 12, 2012 3:11 pm    Post subject: Reply with quote
They're all the same from 61 and later.
Take your magnet with you to test the "copper" sealing washers.
Glenn wrote:
..... and like them better than Bosch.
beebeecivic
PostPosted: Sat May 12, 2012 8:31 pm    Post subject: Reply with quote
Hey Bruce thanks for the reply. I went and got the felpro gasket set and it works great!
- bee
Bruce
Bruce is offline
PostPosted: Sun May 13, 2012 2:11 am    Post subject: Reply with quote
I didn't know they made those gaskets. What type of material was it?
Did the copper washers pass the magnet test?
slik
slik is offline
PostPosted: Sun May 13, 2012 8:08 am    Post subject: Reply with quote
Ok. I'm new to all of this. What's the copper and magnet test? Thanks
beebeecivic
PostPosted: Sun May 13, 2012 9:16 am    Post subject: Reply with quote
http://www.amazon.com/Fel-Pro-OS21625-Oil-Pan-Gasket/dp/B000C2EE3K
Exactly What I got at Autozone
vwsteve
vwsteve is offline
PostPosted: Sun May 13, 2012 9:25 am    Post subject: Reply with quote
If you mean quality, then no. At $6.10, they ought to be gold instead of copper.
beebeecivic
PostPosted: Sun May 13, 2012 9:47 am    Post subject: Reply with quote
At Pepboys its 2.99 and Autozone has it for 3.99
I dont understand why Amazon has it for 6.10
-Bee
dantrefethen
dantrefethen is offline
PostPosted: Sun May 13, 2012 12:45 pm    Post subject: Reply with quote
It's because of the "FREE" shipping
Dan
Bruce
Bruce is offline
PostPosted: Sun May 13, 2012 4:51 pm    Post subject: Reply with quote
Copper is soft enough that it can conform to any irregular surface and provide a good seal. That's why VW used copper washers.
In an attempt to save .1¢, the aftermarket makers of the gasket sets usually provide steel washers that DON'T seal. Then to try to hide their deceit, they get them copper plated to look right.
Test them with a magnet. Copper is non-magnetic so the washers won't stick to the magnet. Steel will.
slik
slik is offline
PostPosted: Sun May 13, 2012 6:44 pm    Post subject: Reply with quote
That's an awesome and super helpful explanation thanks n I'm right on it! The new 63 I bought is caked with oil under the engine. Like black gooey dirt. Tons of it. Maybe the PO use a non copper gasket and it has a slow leak. Thanks again! This sites awesome
Bruce
Bruce is offline
PostPosted: Mon May 14, 2012 1:04 am    Post subject: Reply with quote
I was just looking under my engine earlier. All 6 acorn nuts are dry. Two months since the last oil change when they were last touched. That's what copper washers will do for you.
Helfen
Helfen is offline
PostPosted: Mon May 14, 2012 9:49 am    Post subject: Reply with quote
They are not all the same. Deluxe 1200 40 hp through the 70's single and dual port are the same.
Standard , sedan "A" , 1200 " A", and Canadian 1200 Customs use the small strainer gaskets found on all 36hp engines built until August of 1965. Those later up to Aug. 65 36hp engines also have the drain hole in the strainer cover instead of the drain being threaded into the engine case.
D.
fred69vert
Location: Home of the US Navy Atlantic Fleet, Norfolk, VA
fred69vert is offline
PostPosted: Mon May 14, 2012 11:38 am    Post subject: Reply with quote
I do a trick to help prevent the strainer plate oil drip. I coat both gaskets liberally with grease. It seems to prevent any oil from seeping out. And if the grease gets into the engine it won't do any harm.
I'm not losing my hair, it's just retired and relocating further south.
1969 VW convertible, "Heidi"
Bruce
Bruce is offline
PostPosted: Mon May 14, 2012 11:53 pm    Post subject: Reply with quote
Canadian Standards from 61 onward had 40hp engines, not 36hp.
Helfen
Helfen is offline
PostPosted: Tue May 15, 2012 12:29 am    Post subject: Reply with quote
No, 1200 Customs have 36 hp engines to Aug of 65. They and all Type 111's of 1965 are also the last year of bolt down,stud through the floor claw and wing nut hold down for the seats.
All 1200 A cars or type 111 get the 1200 40hp for the first time beginning in the 1966 model year, and will keep that engine and swing axle until the the end of Beetle production in Germany Jan 1978.
Bruce
Bruce is offline
PostPosted: Tue May 15, 2012 12:43 am    Post subject: Reply with quote
You're wrong.
PostPosted: Tue May 15, 2012 9:44 am    Post subject: Reply with quote
You're wrong.
Here's a 1961 Canadian Brochure
http://www.thesamba.com/vw/archives/lit/61beetle_canada.php
Page 4 says 40hp:
How to: Post Photos | Search
Everett Barnes - [email protected] | My VWs | My wanted ads
HRVW
HRVW is offline
PostPosted: Tue May 15, 2012 10:47 am    Post subject: Reply with quote
Idea As a VW engine builder have done them all from the early 25hp up to the 2.0 engines over a 28 yr span.
VW did introduce a different HP engines over time. Largest mkt was the US.
As I recall VW had the 1st 40hp in the 59-60 T2 van before coming out with the engine in the 61 bug...a two yr trial period in Europe.
Having built over 1000 engimes cpuld give a small lecture on the small diffeerences but will not bore anyone here.
VW made a lot of small changes in design over the yrs....some good and others BAD.
bruce jones Premium Member
bruce jones is offline
PostPosted: Tue May 15, 2012 2:28 pm    Post subject: Reply with quote
And the aftermarket finds yet another way to screw up the simplest things.
Driving in the slow lane since 1969.
Goto page 1, 2  Next
