75 Rat Rabbit Resurrection thread.
Goto page Previous  1, 2, 3, 4  Next
Forum Index -> Water-cooled VW Share: Facebook Twitter
driverlost
driverlost is offline
PostPosted: Mon May 14, 2012 7:33 pm    Post subject: Reply with quote
Well SOWO is this coming weekend and its not looking good on making it. Too strapped for cash to finish the loose ends and have the gas/food money to make the quest.
I did take her out for a 40 foot roll to snap a few pics before it got dark. I hope you enjoy. Eh?
Rob
May the war on Air vs Water end in my lifetime that we may all come together and enjoy the hobby.
Type1xperience
Type1xperience is offline
PostPosted: Wed May 16, 2012 3:40 am    Post subject: Reply with quote
Nice looking Rabbit!
What kind of carb are you running here and how difficult is the Super Beetle master cylinder conversion? TIA.
(o\!/o) Fweem! Fweem!
1963 Type 1 Deluxe sedan
1972 Type 1 Deluxe sedan
1978 Scirocco
1978 Passat
driverlost
PostPosted: Wed May 16, 2012 8:40 pm    Post subject: Reply with quote
Thanks. The carb is a Weber progressive. They work great on these unlike the air cooled engines. Decent MPG and they give a pretty nice pull when you get into the "progressive" section.
So far I'm real happy with the brakes. Did a little test panic stop from 60 MPH but so far that's it. It was an easy fit except for the reservoir fittings that go into the master. Beetle is a larger size then the Rabbit but I'm sure a little more research on different grommets and/or tanks could come up with something and make this mod real simple. I'll try to get some pics of what I'm talking about to clarify. Other then that I drilled out the threads for the mount to fit the Rabbit studs and cut down the pedal pin. Really all there was too it.
Rob
driverlost
PostPosted: Sun May 20, 2012 12:48 pm    Post subject: Reply with quote
Took the Rat out to get a decent exhaust done at a local muffler shop. Had him run 2.5 all the way from the down pipe with a new flex joint. Went with a Thrush muffler and it worked out pretty nice not having the stock gas tank.
Spent a little more time with the barn wood too.
Then took her for her first car wash Think Not talking Liar Embarassed Laughing
Rob
djghia
djghia is offline
PostPosted: Tue May 22, 2012 3:40 pm    Post subject: Reply with quote
Please bring this delightful jewel to the JBJ all VW show in Springfield, MO on June 9th!!! Check out the info on groovevws.com. I want another old Rabbit at our show so the "Bunny Turd" isn't the only one!! Dave J
1962 Ghia vert
1964 Ghia coupe
driverlost
PostPosted: Tue May 22, 2012 10:13 pm    Post subject: Reply with quote
Thank you. I will try to stop by with my daughter. She showed at your event in 2010. Her & my son's pics are on the first page about in the middle.
Rob
PostPosted: Tue May 22, 2012 11:41 pm    Post subject: Reply with quote
Awesome, I love it.
Thanks for keeping us updated.
How to: Post Photos | Search
Everett Barnes - [email protected] | My VWs | My wanted ads
driverlost
PostPosted: Wed May 23, 2012 7:42 am    Post subject: Reply with quote
Thanks a lot. Glad too.
Rob
jsvr6nsd
jsvr6nsd is offline
PostPosted: Fri Jun 01, 2012 1:50 pm    Post subject: Reply with quote
So I'm guessing you made it to SoWo... If not why no updates?
driverlost
PostPosted: Sat Jun 02, 2012 5:30 am    Post subject: Reply with quote
No I didn't make it but my 2 kids did go in their VW's. I ran out of money to finish the loose ends.
Rob
driverlost
PostPosted: Sun Jul 15, 2012 1:42 pm    Post subject: Reply with quote
Made it out to a car show for the first time a few weeks ago and got a lot of great responses and a few offers. By far the most fun I am having with a car in a long time. I recommend a long hard look at everything before making the trip to the salvage yard.
Found this on facebook and snagged a copy Wink
Now my 60 panel cry's for attention, or should I say howls Sad Sounds like a reduction bearing or worse the pinion bearing. So I'm off to work on that. I may do a little more interior work on the rat and post up some pics.
Rob
floridabmx
floridabmx is offline
PostPosted: Fri Jul 20, 2012 9:18 pm    Post subject: Reply with quote
cash in hand for you as soon as your ready to sell. And if you trust in it making the drive to florida Laughing
driverlost
PostPosted: Sat Jul 21, 2012 8:38 pm    Post subject: Reply with quote
Thanks. I get a lot of offers on this, more than any other car I've owned. It's crazy.
I just got fresh tires and changed up the look of the Momo wheels. Pics coming soon.
So what would this cash in hand consist of Question I ignored the last guy, I just wasn't ready to hear it Laughing It's just too new, fresh, and fun to consider selling it, but as time marches on you never know. I may show it a bit more and see what the general reactions are. Non VW people absolutely love it but not sure how the VW crowd will react.
Oh and no question on the trip. I made this bad boy simple and reliable. I daily drive it now and love it.
Rob
driverlost
PostPosted: Thu Jul 26, 2012 9:15 pm    Post subject: Reply with quote
Changed up the look a bit with the rims and got some fresh road rubber. Center caps need to go on still.....
and after the oil pan hammered a good sized rock in the middle of the road that the every other car just straddled I went to work on an oil pan saver.
Its mounted 100% to the body and has 2 large bolts with plates a few milometers away from the block and trans case...
so a hard blow will use the block for added strength and spacing it away keeps the vibration down.
Sorry it looks too crude for a nice lowered MK1 but this may help get some ideas going for others to consider. The oil pan is just too close to the ground when you slam one of these and I haven't found a good solution yet.
Rob
norcalmike
norcalmike is offline
PostPosted: Thu Sep 27, 2012 11:42 pm    Post subject: Reply with quote
Holy Crap! thats awesome!
73 Thing
61 Double Cab
WANTED: Howe Motors Plate Frames
al-staire
al-staire is offline
PostPosted: Wed Oct 03, 2012 11:54 am    Post subject: Reply with quote
Very nice example of an early Golf/Rabbit.I mean,this thing aged good!
If you could bring this beauty to 'our' show down south, it would be quite an eye catcher... Cool
Good work and greetings from Austria !
driverlost
PostPosted: Tue Oct 09, 2012 5:56 am    Post subject: Reply with quote
Thanks Mike!
Laughing Thanks a lot! I would love to bring it to Austria! But the sea air on the trip may be all it needs to push her over the edge Wink
I have to say it has been real fun but mostly funny showing this car. Some people don't get it and take offence to it. It's sad. A few got down right angry about it like one of the show judges at the Tulsa VW show. Another judge and I gave up explaining it when he went off on how bad the car was. He never did get it we just gave up Laughing Then I had a paint vendor stop and give me his card and said come see me when you're ready for paint. Rolling Eyes Over all people dig it and when they understand the story behind saving its life they like it more. I could never intentionally rust a car, especially an old swallow tail.
Anyway I promise not to spam this thread with anymore pics after this batch, unless something radical changes.
Rob
floridabmx
PostPosted: Thu Oct 11, 2012 1:34 pm    Post subject: Reply with quote
I still want it!
wbrown45
wbrown45 is offline
PostPosted: Sat Oct 13, 2012 12:09 pm    Post subject: Reply with quote
Keep on spamming on us! I love it Very Happy
OK Thang
driverlost
PostPosted: Sun Oct 21, 2012 8:28 pm    Post subject: Reply with quote
floridabmx wrote:
I still want it!
Thanks Neutral You never know, interests change, life changes. I got your info but passed up a few offers already.
She's getting new hub bearings, output shaft seals and half shafts this week on both sides. Little rumble started on the left side so it will be all new and fresh.
Thanks! Very Happy Some of the reactions I've been getting from people have me pulling into my shell a little bit. It's good to know I have a fan or two Laughing
Guess a crew put together a couple cool videos of the meet from a few weeks ago and the rat made both cuts.
Rob
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 2 of 4
