carb rebuild
SGKent
SGKent is offline
PostPosted: Sat May 12, 2012 7:43 pm    Post subject: carb rebuild Reply with quote
Just doing some thinking out loud since we lost our carb rebuilder. There are so many people here who have carb problems.
What would you pay to have your progressive rebuilt? What turn around time would you expect?
What would you pay to have your 34-pict-3 rebuilt? What turn around time would you expect?
Steve aka Merlin the Wrench
formerly Steve's Racing and Engine Blueprinting. Wrenching since 1967.
bdamico on GF wrote
"When I was your age I'd plan out all sorts of stuff for the future and almost none of them came true. Just wonder if it's worth trying to be a crystal ball. "
Wildthings
Wildthings is offline
PostPosted: Sat May 12, 2012 9:35 pm    Post subject: Reply with quote
I wouldn't pay much to have a progressive rebuilt as I can find a new one on eBay for cheap. The 34pict3 would be a different story. I am of the opinion that the original carbs were probably better than the replacements and are therefore worth paying replacement cost for one that have been thoroughly gone thru and will give service equal to or better than what it did the first time around.
I guess if someone were to rebuild progressives and set them up so they ran absolutely A-1 and gave good gas mileage to boot, that service would be worth a lot.
69rulz
69rulz is offline
PostPosted: Mon May 14, 2012 9:32 am    Post subject: Reply with quote
Ill find the guys name on here, i wanted my german 34pict 4 rebuilt instead of a shitty new one and he did an AMAZING job, ill b back
Id rather die on my feet than live a life on my knees Right turn clyde
69rulz
69rulz is offline
PostPosted: Mon May 14, 2012 9:34 am    Post subject: Reply with quote
Oh yeah his name is Tim, if you just put 34 pict 4 in the classified search box, he ll be about halfway down on the ad that says 34 pict and 30 pic cores wanted, he does amazing work like wonderful man
ccpalmer Premium Member
ccpalmer is offline
PostPosted: Mon May 14, 2012 2:24 pm    Post subject: Reply with quote
What about mharney? I've heard good things...
I'd happily pay $150 for a perfect rebuild on a 34PICT. A few weeks seems right.
'71 Westy
'77 Bay/rusty shed on wheels
Chris Palmer
Cocobolo Co., LLC
ccpalmer.com
OB Bus
OB Bus is offline
PostPosted: Mon May 14, 2012 5:54 pm    Post subject: Reply with quote
I paid Keifernet around $135 (exchange) for a rebuilt German 34PICT about 3? 4? years ago. At that time the price was good. The turn around time (from memory) was several weeks which was too much.
Larry in OB.
1969 Westy - 1600 DP
Strictly Vintage 2s
San Diego Air Cooled Syndicate
West Coast Bays
borninabus
Samba R&D Dept.
borninabus is offline
PostPosted: Mon May 14, 2012 7:23 pm    Post subject: Reply with quote
there is this other dude, his name is mark harney.
and unlike the former "carb guy" he seems to know his way around ALL types of carbs.
'71 - 1600DP, C/W - 32NDIX - o19
VW Logo Air Cooleds Only VW Logo
BAY PRIDE
SGKent
SGKent is offline
PostPosted: Mon May 14, 2012 8:57 pm    Post subject: Reply with quote
Sounds like we have some folks here who have it covered and I am off the hook again at having to revisit things left in the 1980's. I was concerned because we have all these posts from people having carb issues but now that I see there is someone else than former Keifernet, they have someone to go to.
Wildthings - 34 pict 3 is easier than a progressive. You'd have no trouble.
Wildthings
PostPosted: Mon May 14, 2012 9:09 pm    Post subject: Reply with quote
You haven't seen the 34PICT3 on my Thing. There is nothing that moves on it that isn't worn out I have done a decent enough fix on the throttle shaft bushing, but the choke butterfly shaft is sloppy in its bore and causes the choke to stick and the pivot for the accelerator pump arm is worn badly and as a result the pump doesn't give as much fuel per stroke as it should. I have welded up and redrilled several wallowed out holes in the various levers where springs and linkages attach and even welded up one end of accelerator pump linkage where it was worn almost in two.
Still needs to come apart at least one more time until I will be satisfied with it.
Contrast this with getting a brand new Holley progressive off eBay for $50.
SGKent
SGKent is offline
PostPosted: Mon May 14, 2012 9:29 pm    Post subject: Reply with quote
I'd keep my eyes open for a replacement 34-pict-3. Wink That kind of wear is typical. We used to see it in progressives on Fiats too. I'd keep a bucket full from every wreck I found in the yards and rob parts to make a good one.
borninabus
Samba R&D Dept.
PostPosted: Mon May 14, 2012 10:08 pm    Post subject: Reply with quote
mark's prices might surprise you.
check him out Wink
BAY PRIDE
skid
skid is offline
PostPosted: Tue May 15, 2012 2:01 pm    Post subject: Reply with quote
His Samba username is VolkzBitz and his website is http://volkzbitz.com/
'71 Westfalia
Wildthings
PostPosted: Tue May 15, 2012 2:31 pm    Post subject: Reply with quote
check him out Wink
As I said earlier in this thread I would be willing to pay "new" prices for a high quality Solex 34pict3 rebuild, but for the progressive it is just cheaper to buy a completely new one off eBay. When you start with a core as crappy as mine, an individual probably can not easily do a rebuild that returns the carb back to new condition.
aryue
aryue is offline
PostPosted: Tue May 15, 2012 2:49 pm    Post subject: Reply with quote
I'm using one of his carburetors. I'm definitely happy with it. Like you said, "amazing work".
- Andrew in Austin, TX -
OldandSlow - but still chuggin.
http://www.ph.utexas.edu/~yue/VW/VWBus.html
Wildthings
PostPosted: Wed May 23, 2012 2:50 pm    Post subject: Reply with quote
Just picked up a 34-PICT4 off of eBay and am planning on giving it a try. Way less mileage than my existing 34-PICT3, can barely detect that it has been used at all. I think they are jetted pretty much the same as the 34-3, and just have a larger more complicated accelerator pump system.
