riddle me this, wiper no shut off!!
chubby53
chubby53 is offline
PostPosted: Mon May 14, 2012 11:03 pm    Post subject: riddle me this, wiper no shut off!! Reply with quote
So i have two 12v two speed wiper motors i dug out of my drawer 'O' wiper stuff. had to tinker with them both to get them to work properly. one of them is good, the other won't shut off when i turn the switch off. it will go to the rest position, pause, then go through one cycle, then pause, one cylce and keeps repeating. if i pull the metal motor cover off it will stop. it's like it's shorting out through the covernsome how to make it cycle, messed with it for an hour, couldn't figure out what the deal is.
any help?? thanks
My build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=385100
Bajabugman1970
Bajabugman1970 is offline
PostPosted: Tue May 15, 2012 3:29 am    Post subject: Reply with quote
Is there any chance one of the wires is makeing cross contact, or a bad switch? I had to go over mine several times while looking at the motor manual wireing diagram to get mine to finaly work. A couple of crossed wires made mine do funny things also.
pafree
pafree is offline
PostPosted: Tue May 15, 2012 5:04 am    Post subject: Reply with quote
here is the diagrams i used with mine if it helps:
1972 vw hunting truggy
sand it, fill it, paint it, throw some mud on it and then baja it.
adams77
adams77 is offline
PostPosted: Tue May 15, 2012 5:34 am    Post subject: Reply with quote
I has one do the same thing. It turned out to be the park switch, make sure its aligned properly.
If Stupidity got us into this mess, then why can't it get us out? ....Will Rogers
chubby53
chubby53 is offline
PostPosted: Tue May 15, 2012 6:54 am    Post subject: Reply with quote
i'll look into it tonight more(hopefully). after i put everything back together it all looked to operate correctly. If i just used direct power it would still contiue with the problem, so i know it's not the wiper switch. Inside where the parck position contacts are everything seemed to work good, there are two points, one with the hot wire that puts it in the park position and the other which goes to 31b. so when the motor is in park, there is juice going to 31b from the motor. what is this terminal for? I was wondering if i could wire up a small momentary button that could be used for a one cycle swipe? just thinking outloud.
Back to my issue... Like i said, it keeps cycling until i pull the metal motor cover off then no errors?? I'll let you guys know what i come up with. Thanks
My build:
