Grounding Oil temp sender?
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
rrcade
rrcade is offline
PostPosted: Mon May 14, 2012 9:50 pm    Post subject: Grounding Oil temp sender? Reply with quote
I've seen some mounted in an external oil filter housing and others in a tee at the same spot, I'm just wondering if any additional ground wire is necessary because the external oil filter housing is aluminum? I wouldn't think so but thought I'd ask.
mxracer
mxracer is offline
PostPosted: Tue May 15, 2012 2:52 am    Post subject: Reply with quote
Not as long as the filter housing is grounded. Aluminum is actually a better conductor than steel.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue May 15, 2012 3:38 am    Post subject: Reply with quote
I didn't need any ground wire.
Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club
Dale M.
Dale M. is online now
PostPosted: Tue May 15, 2012 6:39 am    Post subject: Reply with quote
So not use TEFLON tape as a sealant on sender.... Its a Insulator...
Dale
Lives his life vicariously through his own self...
1970 "Kellison Sand Piper Roadster" For Street & Show.
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
