pitterpat Samba Member
Joined: September 10, 2003 Posts: 558 Location: Inianapolis, IN
Posted: Wed May 16, 2012 3:25 pm Post subject: |
WOW! Thanks....I will probably try more sandpaper, did not use 220 & 400, will have to find it. If that doesn't work I will ice pack and heat it up...Don't think I had to do all that with the other alum, but can't remember. Probably should just order the SCAT!
Thanks again! |
candymustang66 Samba Member
Posted: Wed May 16, 2012 3:35 pm Post subject: |
you will find the OG crank is precision.
and the clone crap is not.
try 20 pulleys, some fit others don't. same crank.
some are crap. this will not be your first discovery of china crap.
as og parts get hard to find , more...
i like mine to fit pefect, nothing less. that way if i need to serivce my
pump or my AN-8 fullflow fittings i dont need to do as the video heres shows.
large HOOK and a SLAM HAMMER.
way to off the tins and use a vw puller, impossible to find.
a small gear puller might fit and work.
or , rope to pulley, rope to tree , push vw fast and bang off it comes
it may hit you and it will probably hurt bad.
or use another car to snatch it off.
or .....? some of the videos are very funny. but work.... _________________ back to jeeps, my true love... I-6's
finding vw parts that are not junk (even new) , is way too hard!
mines done, and selling 68T1 with no paint. (primer) |
torsionbar Samba Member
Posted: Wed May 16, 2012 3:56 pm Post subject: |
| pitterpat wrote: | | Probably should just order the SCAT! |
no. the stock pulley works perfectly fine. if you want a high quality aftermarket pulley, get a gene berg. it isn't expensive, and it is top quality. i wouldn't bother with anything else. _________________
| Max Welton wrote: |
[air cooled vw's] are no longer suitable for the general public. The owner has to be be able to maintain the car. And that is after fixing all the deferred maintenance items and ill-conceived modifications. If you can't do those things you are pretty much screwed. |
Posted: Wed May 16, 2012 4:40 pm Post subject: |
| torsionbar wrote: | | pitterpat wrote: | | Probably should just order the SCAT! |
no. the stock pulley works perfectly fine. if you want a high quality aftermarket pulley, get a gene berg. it isn't expensive, and it is top quality. i wouldn't bother with anything else. |
Right now the Berg is not in my budget.....at least a month, don't want the bug to be down that long. Do not know where the stock pulley is, took it off 3-4 yrs ago. We will see. |
Posted: Wed May 16, 2012 4:54 pm Post subject: |
If I do a Berg pulley which one? Achiever or Equalizer? |
scratchs68 Samba Member
Joined: May 28, 2009 Posts: 324 Location: hamilton, new jersey
Posted: Wed May 16, 2012 5:52 pm Post subject: |
| I had one on my car that was super tight. I took a steel wire wheel in a power drill and worked it back and forth a few times. It when on perfect. Don't slow down your drillmkeepmit running fast. Also make sure the wheel is larger then the pulley opening. As you push it threw it will close up and run smooth threw. |
volksnhousin Samba Member
Joined: July 18, 2006 Posts: 181 Location: Ellerslie, GA
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 55666 Location: Long Island, New York, USA
johnnypan Samba Member
Joined: October 24, 2007 Posts: 5465 Location: sackamenna
Posted: Wed May 16, 2012 8:03 pm Post subject: |
| Glenn wrote: | Gotta love "making" aftermarket parts fit.  |
its so you can fully experience the quality and precision of chinese manufacturing,not to mention the necksnapping performance increase the special "lightweight" pulley yields. |
b1pig Samba Member
Joined: March 06, 2012 Posts: 282 Location: Ray City, Ga
Posted: Wed May 16, 2012 10:01 pm Post subject: |
| my empi went on with the same resistance that the stocker came off. just make sure the key is lined up. |
ach60  Samba Member
Posted: Thu May 17, 2012 4:24 am Post subject: |
Steel crank, and Aluminum pulleys have different CTE,
so sanding is going to make it loose when it gets hot, so it needs to be tight when cold.
But you guys are going to flame the crap out of me for this one.
I took the pulley inside turned on the HOT water and let it run in the sink while I took a piss, and got a beer.
Came back, wiped the pulley dry, and went outside and slid it right on the crank, put the bolt on, and torqued it per the book.
That was at least 13 years ago. _________________ Good Luck
Al |
Glenn  Mr. 010
Posted: Thu May 17, 2012 4:32 am Post subject: |
| ach60 wrote: | Steel crank, and Aluminum pulleys have different CTE,
That was at least 13 years ago. |
I use a heat gun with the same results.
I have a Berg steel pulley and they need some heat to R&R them. They should be tight. _________________ Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club |
Posted: Thu May 17, 2012 6:11 am Post subject: |
it is not supposed to be an interference fit, but a slip fit.
but how you pound it on and off, only you care about that.
id never allow it. my HD pulley fits perfect , if it didnt , id have
my machine shop fit it.
mike the crank. first.
pounding it, with a sand seal tail or full flow kit, while not make your day
down the road. (points to consider too) _________________ back to jeeps, my true love... I-6's
Last edited by candymustang66 on Wed May 23, 2012 4:27 am; edited 2 times in total |
Posted: Thu May 17, 2012 6:25 am Post subject: |
Last edited by candymustang66 on Wed May 23, 2012 4:21 am; edited 1 time in total |
Bruce Samba Member
Posted: Thu May 17, 2012 10:59 pm Post subject: |
so sanding is going to make it loose when it gets hot, so it needs to be tight when cold. |
It is true that the Al pulley expands more than the crank. However, my current 30 year long experiment has proven there is no detrimental effect in having a "loose" pulley. _________________
| Glenn wrote: | | ..... and like them better than Bosch. |
Posted: Fri May 18, 2012 5:38 am Post subject: |
honing a pulley is art.
one guy does great. the other guy gets and egg.
ymmv
get the big steel pulley
and
cut down on those bad crank vib's , (large in 4cyl motors it is.)
and get free extra torque , while launching from red lights (more flywheel effect) _________________ back to jeeps, my true love... I-6's
Posted: Fri May 18, 2012 8:20 am Post subject: |
| pitterpat wrote: |
buy another stock pulley if you lost yours and you can't afford the berg. right here in the classifieds for as little as 5 bucks.
| pitterpat wrote: |
i have the achiever. _________________
| Max Welton wrote: |
Posted: Mon May 21, 2012 4:38 pm Post subject: Got it on |
| Finally had time to work on it today and got it on. 1st I sanded w/ 220 & 400, no luck. So I put it in the oven on 300 and put ice on the crank. Took it out of the oven w/ welding gloves and walked out to the car. Put it on then took 2 x4 and rubber mallet and tapped it on more. Letting it cool down now then will chg the oil, then put the belt back on and ck the valves then start it up. |
JerryMCarter1 Samba Member
Joined: January 07, 2007 Posts: 6244 Location: N.W. Phoenix
Posted: Mon May 21, 2012 10:50 pm Post subject: |
how are you ever going to get it off? _________________ Experience always triumphs over hearsay and You get to select which theory to believe |
Posted: Tue May 22, 2012 7:54 pm Post subject: |
| JerryMCarter1 wrote: | | how are you ever going to get it off? |
When I went to try to put the previous one back on it would not go on either....so I must have used heat on it too! It will come off. |
