Steering box, Tie rod ends replaced, now won't turn as sharp
Goto page 1, 2  Next
FrankRam
FrankRam is offline
PostPosted: Mon May 21, 2012 8:17 pm    Post subject: Steering box, Tie rod ends replaced, now won't turn as sharp Reply with quote
Replaced late steering box on '57 stock bug with another late steering box. Kept pittman arm the same. Replaced tie rod ends. Now, the wheels do not turn near as far. Furthermore, the inside turning wheel doesn't turn as far as the outside wheel. Turn it the other way and the same is true. The outside wheel turns further than the inside wheel. What happened?
The inside wheel should always turn at a greater angle than the outside but somehow it is not happening. Any ideas? Help Confused
slalombuggy
slalombuggy is offline
PostPosted: Mon May 21, 2012 8:30 pm    Post subject: Reply with quote
Did you have a wheel alignment done after changing the tie rod ends? The steering boxes will move the pitman arm way further than they can move once in the car so I wouldn't suspect the box. I think your toe in is out of adjustment.
brad
BB Buggy 121.253mph @ Bonneville 2012
http://www.youtube.com/watch?v=57hMyJmIU10
Raisin cookies that look like chocolate chip cookies are the main reason I have trust issues
FrankRam
FrankRam is offline
PostPosted: Tue May 22, 2012 7:16 pm    Post subject: Adjust steering Reply with quote
Will an allignment with proper toe-in increase and allow the wheels to turn farther? Appreciate the insight!
andk5591 Premium Member
andk5591 is offline
PostPosted: Wed May 23, 2012 4:14 am    Post subject: Re: Adjust steering Reply with quote
yeah - if the toe is way out (as in wider in the front instead of narrower by 1/8"). You can set it yourself with a couple tape measures and some flat pieces of wood or metal. Theres lots of threads on home aligmnents already on here if you search.
D-Dubya Manx clone - 63 Short pan,1776.
Max - 73 standard project at wife's request and your gonna die when you see this one.
Joey
Joey is offline
PostPosted: Wed May 23, 2012 6:09 am    Post subject: Reply with quote
Did you measure the lengths of the tie rods before you took them apart and re-assemble using those measurements?
Joey
'56 Beetle
'65 Beetle
'74 Bus
'79 Panel
vintagevdubbers.ca
johnnypan wrote:
US safety standards, a product of our government, created the fatchick out of the beetle.
FrankRam
FrankRam is offline
PostPosted: Wed May 23, 2012 11:31 am    Post subject: hindsight Reply with quote
That would have been the way but unfortunately, of course, not. Would the angle the steering box is attached to the beam make a difference as well?
Joey
Joey is offline
PostPosted: Wed May 23, 2012 2:00 pm    Post subject: Reply with quote
You need to find the center position of the steering box then adjust each tie rod so the wheels are going straight and then adjust the toe in.
Here's a good read on 'do it yourself' alignment...
http://www.thesamba.com/vw/forum/viewtopic.php?t=315644[url]
Joey
'56 Beetle
'65 Beetle
'74 Bus
'79 Panel
vintagevdubbers.ca
slalombuggy
PostPosted: Wed May 23, 2012 2:38 pm    Post subject: Re: hindsight Reply with quote
It won't make a difference on the travel of the arm. Make sure your pitman arm is 90* to the beam when you do your initial toe setting.
brad
FrankRam
FrankRam is offline
PostPosted: Wed May 23, 2012 4:32 pm    Post subject: pittman angle Reply with quote
Right now the pittman arm is angled up about 10-15 degrees from box towards rear. Nowhere near the 90 degress from beam. Is this what's throwing me off and loosing some turn? (was never much good at geometry).
Thanks
FrankRam
FrankRam is offline
PostPosted: Wed May 23, 2012 4:35 pm    Post subject: Toe- In Reply with quote
Will definitely check the Toe In --Thanx
FrankRam
FrankRam is offline
PostPosted: Wed May 23, 2012 4:56 pm    Post subject: too much Toe Reply with quote
Well, using an ordinary tape measure, accross the front of the tires it measures 45 1/2 inches. Measuring accross the back of the tires it's 47 1/2 inches ! Talk about too much Toe - In. Will an allignment alone fix this?
slalombuggy
PostPosted: Wed May 23, 2012 5:37 pm    Post subject: Reply with quote
Sorry, I should have said that the pitman arm should be 90* to the length of the beam on the horizontal axis. This will make sure the box is centered internally. To make sure you have the correct vertical angle simply attach your steering shaft to the coupler and center the shaft in the steering column tube and make sure the shaft and input shaft on the steering box are in line. You can cheat it a bitup and down for clearance on the long tierod if needed but it should be as close to inline as possible.
brad
FrankRam
FrankRam is offline
PostPosted: Wed May 23, 2012 6:15 pm    Post subject: Reply with quote
Right. Thanks Brad.
andk5591 is offline
PostPosted: Thu May 24, 2012 5:13 am    Post subject: Reply with quote
Toe is set 1/8" narrower in the front. I think and inch and change is definately gonna mess you up, plus it will drive really weird.
slalombuggy
PostPosted: Thu May 24, 2012 5:27 am    Post subject: Reply with quote
Yes simply setting the toe will fix your problem.
brad
FrankRam
FrankRam is offline
PostPosted: Thu May 24, 2012 5:59 pm    Post subject: tie rods Reply with quote
I appreciate the help and the links. The string method and the stick with cards are ingenius. One last question - Any trick or simple advice on adjusting those tie-rods mechanically?
Thanks again.
66brm
66brm is offline
PostPosted: Thu May 24, 2012 6:22 pm    Post subject: Reply with quote
Use a pipe wrench or vice grips to rotate the centre tubes, as they are L/R threaded adjusting the length is a breeze, don't forget to retighten the clamps once the adjusting is done and reconfirm the toe adjustment once you have driven around the block as things will "settle"
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
[email protected] wrote:
Kadrons are horrible excuses for carburetors.
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
slalombuggy
PostPosted: Thu May 24, 2012 7:09 pm    Post subject: Reply with quote
Before you get to carried away put some antiseize or grease on the threads of the tierods. this will really help now and in the future should you have to change any part or reset your toe. Do not use a pipe wrench. They did into the metal and weaken tierod. I have seen them bend at points where people have used this method to adjust and crushed the tube. If they are siezed up either try and get some heat on them and then lube them up or or soak them with WD-40. I have always been able to adjust mine with just a bare hand.
brad
66brm
66brm is offline
PostPosted: Thu May 24, 2012 7:33 pm    Post subject: Reply with quote
Go to a wheel alignment place and see what tool is most often used to adjust the rods.......
Aust. RHD 66 Type 1
slalombuggy
PostPosted: Fri May 25, 2012 5:38 am    Post subject: Reply with quote
I know, I have a drawer full of the propper tools to do my wheel alignments with. I can use a 5lb sledge to adjust camber but it doesn't make it the tool for the job Wink
brad
Goto page 1, 2  Next
