BeetleBobby Samba Member
Joined: January 25, 2011 Posts: 38 Location: Mayberry, USA
Posted: Fri Apr 06, 2012 5:59 pm Post subject: |
GREAT WORKMANSHIP
Can't wait for the next phase. _________________ 1974 SB Sedan (original unrestored)
Bob |
super72beetle Samba Member
Joined: November 21, 2011 Posts: 469 Location: Wisconsin
Posted: Fri Apr 06, 2012 7:01 pm Post subject: |
| your car is awesome keep up the good work |
poomwah Samba Member
Joined: February 02, 2011 Posts: 1116 Location: NW ohio
b1pig Samba Member
Joined: March 06, 2012 Posts: 283 Location: Ray City, Ga
Posted: Sat Apr 07, 2012 11:20 am Post subject: |
i have to agree that i like that look. the whole thing looks clean as well.
my car has enough rust and crappy "repairs" done that i don't think i can afford to restore my super. was thinking a sort of baja look... but the lack of any front fenders had me considering a similar move to what you have here. it certainly is thought provoking to say the least.
i'm looking forward to see the paint work. |
DROPPEDATBIRTH Samba Member
Joined: March 30, 2012 Posts: 32 Location: Blairsville, PA
Posted: Sat Apr 07, 2012 1:45 pm Post subject: |
Great work man, waiting on pictures of the painted product. _________________ Click to view image |
blue72! Samba Member
Joined: February 14, 2012 Posts: 29 Location: Around the sound, WA
Posted: Sat Apr 07, 2012 3:47 pm Post subject: |
| Looks to me like your taking something that would have been scrapped and turning it into an amazing car. Great looking volksrod and very tasteful (so far)! You've got some great skills. I, like others, are waiting to see what else you do. |
enfamy Samba Member
Joined: June 09, 2010 Posts: 40 Location: Florence, SC
Posted: Sat Apr 07, 2012 6:00 pm Post subject: |
| love it. what are the plans for where the running boards used to go |
modelmakerinc Samba Member
Joined: November 03, 2010 Posts: 126 Location: outh Florida
Posted: Mon Apr 09, 2012 3:35 pm Post subject: |
thanks guys nice to hear the kind words, To answer a couple of questions:
The speaker housings under the dash are simple sheet metal cut bent and fitted into the corners, welded, filled and painted, the carpet will need to be adjusted around them.
The steering is a couple of steps. you need two u-joints and a long piece of splined shaft like these on pages 312/313.(http://www.empius.com/vwcatalog/2011/312.html http://www.empius.com/vwcatalog/2011/313.html)
My 70 had 5/8" shaft. measure yours, before purchasing parts. Take the splined female part off the steering box and undo the "rubber coupler" Cut the steering column just above the the crash tube, section that looks like mesh. This will leave it as a hollow tube. Drill a couple holes through the tube a inch or so above the cut, Cut a segment of the splined shaft, the splines will be used with one new u-joint, the other side gets slid up the steering column, and plug welded through the holes and a weld along the end of the tube. this finishes the steering column side.
The other u-joint gets one side cut off and welded to the female coupling which was on the steering box. These parts need to be aligned through the centerline of the coupler and u-joint. other wise it will look funcky when it is being turned. and not really work properly.
the remaining segment of the purchased shaft gets cut to fit between the u joints and then welded to the u-joints. this makes a new segment which is removable. the spline on the steering column and a spline on the steering box are fastened with the clamping bolt with the correct spline count. remember to phase the u-joints in the same oreintation.
the area where the running boards were gets a neat treatment but it will have to wait till I get to it to show you. |
Posted: Sun May 06, 2012 5:25 pm Post subject: |
well, just a small update. car is primed and blocked just needs a little touches before paint so it can come home.
mattintheboxx Samba Member
Joined: July 02, 2011 Posts: 24 Location: bakersfield,ca
Posted: Tue May 15, 2012 9:27 am Post subject: |
Any new up dates??? I' m excited to see how it looks  |
Posted: Fri May 25, 2012 7:51 pm Post subject: |
its coming home tomorrow. here is a couple teaser pics
Posted: Fri May 25, 2012 7:53 pm Post subject: |
| looking good. |
Wideopen Samba Member
Joined: May 17, 2012 Posts: 256 Location: N. California
Posted: Fri May 25, 2012 8:20 pm Post subject: |
So far, great job. I looks like it will turn out very nice!
I am not much of a purist so what ever suits you! I have learned some folks will not understand the reason or desire to mod a product(car, firearm or whatever) Do what you want it is yours, that is what I think!
Can't wait to see the end result! |
Tompkins Samba Member
Joined: January 17, 2011 Posts: 192 Location: Beeville Tx
Posted: Fri May 25, 2012 9:41 pm Post subject: |
| Man what are those rims you are running? I want exactly those! And what is the width of the back ones? |
allsidius Samba Member
Joined: February 02, 2010 Posts: 600 Location: Norway
Posted: Sat May 26, 2012 12:20 am Post subject: |
| Tompkins wrote: |
With those rear wheels it should really pack a punch! Hope you won't be running that single carb 1600 for long.. Are you sure the engine will be able to pull them loose from the street if parked on a hot day?  _________________ 1973 1303S w sunroof
1978 1303 convertible (sold)
1966 1300 RIP |
green73 Samba Member
Posted: Sat May 26, 2012 4:05 am Post subject: |
I want your car man! Thats gona be very cool. I would bring the front down a little bit if it were mine  _________________ ~Tim~
Own now. 1973 bright green standard Beetle daliy driver
Owned. 1977 yellow AMC Gremlin
1974 Lincoln Continental mark IV
1986 4X4 Nissan pickup |
Posted: Sat May 26, 2012 5:48 pm Post subject: |
home from paint. It isn't flawless but its perfect. the color is awesome, my custom mix of charcoal even has a ever so slight tinge of green.
Last edited by modelmakerinc on Sat May 26, 2012 6:41 pm; edited 1 time in total |
Posted: Sat May 26, 2012 5:51 pm Post subject: |
The front will come down a little more with a 145-15 tire on a 3-1/2" centerline, the rear are 15x 10 w/ 295-50-15 coopers.
