Inexpensive Front Disc Brake Kit
thefladge
thefladge is offline
PostPosted: Mon May 28, 2012 1:25 pm    Post subject: Inexpensive Front Disc Brake Kit Reply with quote
I recently installed a wide 5 disc brake kit from AC Industries on my Baja Bug.
So why am I posting this information here? My Baja Bug has Porsche 356B spindles and only some minor modifications had to be made to the kit to make it fit.
I figured this would be helpful to those who don't want to spend a fortune converting a 356. The kit costs about $380.
See here:
http://www.thesamba.com/vw/forum/viewtopic.php?p=6054817&highlight=#6054817
1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate.
foamcar
foamcar is offline
PostPosted: Mon May 28, 2012 6:48 pm    Post subject: Reply with quote
Thanks for the great tip. As they claim these are stock vw parts possibly the right manual would show the pad installation. Need to know what model they are from.
thefladge
PostPosted: Mon May 28, 2012 9:20 pm    Post subject: Reply with quote
Pads and calipers are VW Rabbit. Late 70's / early 80's era.
Erik G
Erik G is offline
PostPosted: Tue May 29, 2012 8:19 am    Post subject: Reply with quote
Is this without question? The type 3 folks have lately been starting to use the AC Ind. or Empi ball joint wide 5 disc kit, as with a few mods it will work on the front of a type 3, and the wide 5 type 3 parts are pretty much non-existant.
We have been trying to narrow it down to exactly which caliper and pads the kit uses. I have heard rabbit, GTI, but never the exact year or model. Suppliers have been contacted with not much for results yet.
Thanks
Erik
MoPor
MoPor is offline
PostPosted: Tue May 29, 2012 8:28 am    Post subject: Reply with quote
It looks pretty cheap as compared to $1100 for this however the Wilwood stuff should be great
http://airkewld.com/index.php?option=com_virtuemar...Itemid=252
Matt
'58 356A coupe
'00 Boxster S
dawerks
dawerks is offline
PostPosted: Tue May 29, 2012 10:51 pm    Post subject: Reply with quote
I have that kit on my 356. EMPI makes it. Basically you can use any 'king and link' pin bug disc brake kit.
Personally if I had to redo the brakes, I would go with Vdbubengineerings kit;
http://www.thesamba.com/vw/classifieds/detail.php?id=1124224
"There is only one sin; disconnection from self."
MoPor
MoPor is offline
PostPosted: Wed May 30, 2012 1:32 pm    Post subject: Reply with quote
Another one http://www.autoatlanta.com/Porsche-Bolt-on-Ball-jo...22880.html
Matt
'58 356A coupe
'00 Boxster S
dawerks
dawerks is offline
PostPosted: Wed May 30, 2012 1:44 pm    Post subject: Reply with quote
The 'wide 5' disc brake kits have one huge drawback in that they are insanely heavy. The rotors are bricks! Smile Well about 5 bricks each.
MMW
MMW is offline
PostPosted: Wed May 30, 2012 3:42 pm    Post subject: Reply with quote
I really don't see the need for disc brakes on a street driven 356. If your drum brakes are adjusted correctly they should stop just fine. These cars are light weight.
Mic
1959 356 coupe
Missing the original engine 72488
Update - third pc. found!
Now just need the case halves.
1965 fenderless beetle
MoPor
MoPor is offline
PostPosted: Wed May 30, 2012 5:24 pm    Post subject: Reply with quote
I thought people generally upgraded to front discs because it is easier and less expensive than refurbishing drums. If you have to send your drums out for relining and possibly replacement due to bad splines it isn't going to be cheap or quick. Perhaps I'm wrong here. Non-power discs are great.
Matt
'58 356A coupe
'00 Boxster S
MMW
MMW is offline
PostPosted: Wed May 30, 2012 7:10 pm    Post subject: Reply with quote
Didn't think of it that way. You are right that a disc kit is cheaper than buying new drums or a refurb.
Mic
1959 356 coupe
Jacks
Jacks is offline
PostPosted: Wed May 30, 2012 8:49 pm    Post subject: Reply with quote
Often times "upgrade" can be confused with "change". The two are quite different. As is the constant in life, everything is a trade-off.
Jack Staggs
Actual name
MoPor
MoPor is offline
PostPosted: Thu May 31, 2012 6:47 am    Post subject: Reply with quote
I imagine a disc brake "change" is an upgrade for some and a downgrade for others. Smile Each to their own.
Matt
'58 356A coupe
'00 Boxster S
356JAEGER
356JAEGER is offline
PostPosted: Thu May 31, 2012 11:21 am    Post subject: Reply with quote
For my money, the original drums work very well when properly maintained.
Attractive as discs may be, the gain in weight, the cost, replacement cost for the hub/disc unit and, for myself, the clincher, longevity. I also use type 5 silicone brake fluid. Some cite failed brake light switches and soft pedals using it. I have never had an issue in 10 years and when performing a bleed of the system, after 10 years had zip to purge. I think many of the 'problems' that seem to occur, are caused by the failure to replace any component that can retain trace of the old fluid. The pedal is a little softer than the discs in my 912 but that makes them easier to modulate, at least for myself. Just one more set of opinions from a 28 year owner/driver.
Regards,
Joel Jensen
When in doubt, think about it..
The outcome of a project is directly proportional to its preparation.
dawerks
dawerks is offline
PostPosted: Thu May 31, 2012 2:44 pm    Post subject: Reply with quote
How much do new 356 front drums cost?
I tried to find an online supplier but I didn't really see anything listed (but I didn't search too hard).
I have a set of NOS drums, but I went with discs because I wanted to lower the front of my car as well. Pedal pressure is slightly higher, but it's a good time to replace the master cylinder with a modified dual circuit one for disc brakes.
MMW
MMW is offline
PostPosted: Thu May 31, 2012 3:22 pm    Post subject: Reply with quote
Why did you have to go with discs to lower your car? I put drop spindles on my 59a & kept the drums. Also the bars are adjustable.
Mic
1959 356 coupe
356JAEGER
PostPosted: Thu May 31, 2012 3:51 pm    Post subject: Reply with quote
The front of a 356 can be lowered or raised easily using the adjusting screws on the torsion bars, disc brakes are not a requirement. A dual circuit master cylinder will work on a drum or disc system, discs however, require an air bleed to allow the pads to retract. A single cylinder will not fail if properly maintained, and you do keep your emergency brake adjusted I hope ? That is also a 'dual circuit ' system, albeit manually operated. True, good used drums or having them relined is not inexpensive, but you'll only do it once.
Regards,
Joel Jensen
dawerks
dawerks is offline
PostPosted: Thu May 31, 2012 4:36 pm    Post subject: Reply with quote
Free bonus! Smile The adjustment on the beam is 'not enough'.
I guess with how little 356's are actually driven, the drums should last forever.
thefladge
PostPosted: Thu May 31, 2012 7:05 pm    Post subject: Reply with quote
Thanks
Erik
The calipers came in boxes with the following part numbers:
171-615-423B Left
171-615-424B Right
The 171 indicates a VW Rabbit origin, although when I do a web search using those complete part numbers, all I get are websites about Chinese made Beetle parts.
I suspect they have altered the part numbers to throw us off the trail. I believe the real VW part numbers should be 171-615-123B and 171-615-124B.
These fit numerous late '70's to early '80's water cooled VWs including the Rabbit.
As for the pads, there was no part number on the box.
Erik G
Erik G is offline
PostPosted: Thu May 31, 2012 8:03 pm    Post subject: Reply with quote
Thanks
Erik
171-615-423B Left
171-615-424B Right
Well, that's an awesome start. I suppose the easiest thing would be to buy the set, and take the pads in and start looking for a match in the 80's rabbit era
This is good news, because almost all the 80's jetta/golf based cars are upgradeable, G60 brakes could probably be used.
Thanks much for the insight
As to drums, again Im a type3 guy, and i have never had an issue with single circuit drum brakes. Type 3's are very similar to 356 in that its a much larger drum and shoe, twin brakes cylinders on each wheel, etc. I even run a semi metallic top shoe and organic lower, for a little better performance. But, alas, our cars are not so popular, parts are not made, and where it makes sense to do 100pt or at least correct as possible on a 356, not so much on a type 3...yet.
