heronm Samba Member
Posted: Thu Jun 02, 2005 9:57 am Post subject: Aftermarket A/C units |
I've looked at http://www.vintageair.com/ for a kit to go into the VW bus. Living in Florida, it gets smoking in the summer. I would like to drive the bus year round and not have my clothes glued to my body from sweat.
Anyone had luck in researching this option? |
David Hopkins Samba Member
Joined: March 13, 2004 Posts: 29 Location: Raleigh NC
Posted: Thu Jun 02, 2005 12:17 pm Post subject: |
Im in the same boat. I even went so far as to buy a parts bus cause it had a factory installed AC in it. the overhead one. i'd much rather havea nice hidden thing someplace.
im still looking myself, found the vintage air also found this one from hotrodair.com
http://www.hotrodair.com/vwpage.cfm
still waiting for them to get back with me on options.
more later.
David. |
knoren Samba Member
Posted: Thu Jun 02, 2005 3:50 pm Post subject: A/C |
I may be able to help? I just bought a 78 Westy that has an A/C system installed. The vent system in front is installed under original dash and has blower and stuff on it. I'm not sure if this is VW or aftermarket? Previous owner (last 5 years) said they never tried using the A/C and I don't think it is currently running. Since I live in the great Pacific NW there is not much need for A/C so I am going to uninstall. Anyone interested in buying the system? No guarantees it will work (but I don't see why it wouldn't?)? I can take pics if your're interested? |
SixVolt Samba Member
Joined: January 04, 2004 Posts: 1136 Location: Cleveland, Ohio
Posted: Thu Jun 02, 2005 6:47 pm Post subject: |
Same as above. I'm going to pull an air conditioning unit out of a '79 Bay in the next couple of weeks. I don't want money, but I'd love to trade it for a brown middle seat. It's the T shaped ceiling mounted unit. It has the compressor (condtion unknown) all the lines and the evaporator and condensor are there. Everything looks to be in very good shape. (The compressors on these things are suspect however) I think my unit is the "DPD Over head unit, ZVW 805 5020". Check out Ratwell's spin on air cond. on "Bay Window Facts" 3.1. I think the modern compressors are much more efficient and may work with these old units. Ask Ratwell his thoughts. The shippping on this stuff would probably be steep! |
Posted: Thu Jun 02, 2005 7:27 pm Post subject: |
I have that same Headliner mounted T shaped unit, all evaperators, pump, hoses, etc. all still installed on my parts bus at the moment. I have it on good authority (Mark) that everything works well, it just needs to be charged.
Anyone interested in this system can contact me directly.
David |
fastfred Samba Member
Posted: Thu Jul 01, 2010 8:19 am Post subject: any pictures of this set up ? |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
chabanais Samba Member
Posted: Thu Jul 01, 2010 11:13 am Post subject: |
Over 30 years in the biz heard good things... they're in San Diego:
http://www.iceac.com/
Specifically for VWs, too! _________________ "I spud therefore I yam." |
onion456 Samba Member
Joined: September 09, 2006 Posts: 674 Location: Houston, TX
Posted: Thu Jul 01, 2010 1:08 pm Post subject: |
ive got a gilmore installed in one bus and a non-functional dealer installed AC in another... some pics and info in my thread here if youre interested:
http://www.thesamba.com/vw/forum/viewtopic.php?t=285432&highlight=crusty
around pages 4,5,6. _________________ '76 Sage Green Westy 2.0 FI
'76 Creamsicle 7-passenger 2.0 CS FI
'85 Tan Westy |
johnciacci Samba Member
Joined: April 02, 2006 Posts: 38 Location: Fairfax Village
Posted: Wed May 30, 2012 8:29 pm Post subject: 1978 Bus Aftermarket AC |
My mechanic want to rip out my AC say it is just dead weight, if i do so, is there any one interested in this system? Is this a good idea? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed May 30, 2012 9:52 pm Post subject: Re: 1978 Bus Aftermarket AC |
Welcome.
johnciacci wrote: |
Possibly, what year is your bus?
Your mechanic sounds scary though _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu May 31, 2012 8:52 am Post subject: Re: 1978 Bus Aftermarket AC |
It is a 1978 vw camp mobile with manual with fuel injection.
My Southern californianmechanic says it is not worth the hassle, but my central californian says its dead weight and no resale value.
The ac does work there just no freon and not sure if I can refill it in California.
The bus goes slow enough uphill 40-45mph and max 75-80 downhill with wind.
I think the mechanics rate is 87.50/hour so it would probably be 100$ for removal and leave the dash in the inside. |
Desertbusman Samba Member
Posted: Thu May 31, 2012 9:00 am Post subject: |
KMMcDonald has a '77 with A/C. When it was rebuilt they replaced to orig. compressor with one of the late good ones. I think he says it draws very little engine power. The original compressor draws a lot of power and it's not good to overheat the engine. The difference here in the summer is burning up an engine with demanding extra load on the engine. _________________ 71 Superbug
71 Westy |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Thu May 31, 2012 9:17 am Post subject: |
Upgrade the compressor, replace all the o-rings, the receiver and the expansion valve, have a shop pull vacuum on the system. If it holds vacuum at that point, charge it. Look into RedTek or Envirotek as R12 replacements, or road-trip outside California (AZ, NV, Mexico) to get the real deal.
Modern rotary style compressors use 1-3HP, the old York uses closer to 8-10HP .. and it's a lot heavier too. |
Posted: Thu May 31, 2012 9:45 am Post subject: Re: 1978 Bus Aftermarket AC |
johnciacci wrote: |
It adds more than that to the resale value to most collectors as a complete system even if it's discharged, it robs no power just sitting there.
Now lets discuss why your bus is such a toad on hills, maybe your mechanic doesn't know what he's doing and is grasping for straws? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu May 31, 2012 11:15 am Post subject: Re: 1978 Bus Aftermarket AC |
okay, ill leave it, its not hurting anything.
i thought 45-50 was standard for vw bus uphill!
the local mechanic SoCal wouldn't really search to see what the problem is going uphills he is just a go to and fix it guy but a fully loaded camper with two adults and a baby and luggage is probable 3750lbs total.
I'm taking the bus back to SLO to Broad Street VPA they are Go Westys #1 go to. They installed the fuel pump/filter, starter/solenoid and changed the main lead from the battery to the starter and added a pertronix electronic ignition 2 weeks ago.
Now i will go back to get the gas tank removed and cleaned, replace the clutch kit, throttle and clutch cables and inspect the FI system.
I might have a vacuum problem based on my copper fuel line broke 3 weeks ago on the left side and i replace it with fuel pressure grade hose that was 2.5" long now it's 1" long. |
vw76westy Samba Member
Posted: Thu May 31, 2012 1:07 pm Post subject: Re: 1978 Bus Aftermarket AC |
johnciacci wrote: |
well 45-50 mph if your in a 71 or older bus with a stock type-1 motor
but your bus should have a 2.0 motor and with the fi you should have no
problem going 75 all day long anywhere you go
the hill needs to be at least a 6%grade for a long time
to go that slow (basicly a mountain not a hill)
here is my bus with the exact same set up you have on yours
stock 2.0 type-4 motor with stock fuel injection
stock 091 trans
_________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
quote from bay window bus buyers guide........
The Type 4 engine is considered by many to be VW's finest air-cooled motor, |
SGKent Samba Member
Posted: Thu May 31, 2012 1:52 pm Post subject: Re: 1978 Bus Aftermarket AC |
vw76westy wrote: |
johnciacci wrote: |
stock 091 trans
don't forget to mention that speed burned a hole in the piston if I recall.... _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
white74westy Samba Member
Posted: Thu May 31, 2012 2:21 pm Post subject: 1974 bay window a/c stuff |
Posted: Today 2:18 pm Post subject: a/c cabin parts for a 1974 bay
Ladies and Gents,
I hope I've done this correctly. It's the first time I've uploaded an image. I'm posting the same image in a couple of different threads, in the hopes that someone may have this part. I don't know the exact name for it. It's for the interior of the cabin on the 1974 and 1975 models. I'm interested in keeping the stock setup, minus the old york compressor.
Not sure if rolling around in the bus (sans a/c) in Florida in the middle of the summer is going to go over well with the ladies of the house. |
