thefladge Samba Member
Joined: July 25, 2005 Posts: 1290 Location: Anaheim, CA
Posted: Mon May 28, 2012 1:25 pm Post subject: Inexpensive Front Disc Brake Kit |
I recently installed a wide 5 disc brake kit from AC Industries on my Baja Bug.
So why am I posting this information here? My Baja Bug has Porsche 356B spindles and only some minor modifications had to be made to the kit to make it fit.
I figured this would be helpful to those who don't want to spend a fortune converting a 356. The kit costs about $380.
See here:
http://www.thesamba.com/vw/forum/viewtopic.php?p=6054817&highlight=#6054817 _________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate. |
foamcar Samba Member
Posted: Mon May 28, 2012 6:48 pm Post subject: |
Thanks for the great tip. As they claim these are stock vw parts possibly the right manual would show the pad installation. Need to know what model they are from. |
Posted: Mon May 28, 2012 9:20 pm Post subject: |
Pads and calipers are VW Rabbit. Late 70's / early 80's era. _________________ 1957 Vintage Baja Bug.
Erik G Samba Member
Joined: October 16, 2002 Posts: 13283 Location: Tejas!
Posted: Tue May 29, 2012 8:19 am Post subject: |
thefladge wrote: |
Pads and calipers are VW Rabbit. Late 70's / early 80's era. |
Is this without question? The type 3 folks have lately been starting to use the AC Ind. or Empi ball joint wide 5 disc kit, as with a few mods it will work on the front of a type 3, and the wide 5 type 3 parts are pretty much non-existant.
We have been trying to narrow it down to exactly which caliper and pads the kit uses. I have heard rabbit, GTI, but never the exact year or model. Suppliers have been contacted with not much for results yet.
Thanks
Erik _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
MoPor Samba Member
Joined: December 03, 2010 Posts: 292 Location: Canada
dawerks Samba Member
Posted: Tue May 29, 2012 10:51 pm Post subject: |
I have that kit on my 356. EMPI makes it. Basically you can use any 'king and link' pin bug disc brake kit.
Personally if I had to redo the brakes, I would go with Vdbubengineerings kit;
http://www.thesamba.com/vw/classifieds/detail.php?id=1124224 _________________ "There is only one sin; disconnection from self." |
MoPor Samba Member
Posted: Wed May 30, 2012 1:44 pm Post subject: |
The 'wide 5' disc brake kits have one huge drawback in that they are insanely heavy. The rotors are bricks! Well about 5 bricks each. _________________ "There is only one sin; disconnection from self." |
MMW Samba Member
Joined: April 30, 2012 Posts: 846 Location: northern NJ
Posted: Wed May 30, 2012 3:42 pm Post subject: |
I really don't see the need for disc brakes on a street driven 356. If your drum brakes are adjusted correctly they should stop just fine. These cars are light weight. _________________ Mic
1959 356 coupe
Missing the original engine 72488
Update - third pc. found!
Now just need the case halves.
1965 fenderless beetle |
MoPor Samba Member
Posted: Wed May 30, 2012 5:24 pm Post subject: |
I thought people generally upgraded to front discs because it is easier and less expensive than refurbishing drums. If you have to send your drums out for relining and possibly replacement due to bad splines it isn't going to be cheap or quick. Perhaps I'm wrong here. Non-power discs are great. _________________ Matt
'58 356A coupe
'00 Boxster S |
MMW Samba Member
Posted: Wed May 30, 2012 7:10 pm Post subject: |
MoPor wrote: |
I thought people generally upgraded to front discs because it is easier and less expensive than refurbishing drums. If you have to send your drums out for relining and possibly replacement due to bad splines it isn't going to be cheap or quick. Perhaps I'm wrong here. Non-power discs are great. |
Didn't think of it that way. You are right that a disc kit is cheaper than buying new drums or a refurb. _________________ Mic
1959 356 coupe
Jacks Samba Member
Joined: July 15, 2006 Posts: 2348 Location: San Clemente, Ca.
Posted: Wed May 30, 2012 8:49 pm Post subject: |
MoPor wrote: |
Often times "upgrade" can be confused with "change". The two are quite different. As is the constant in life, everything is a trade-off. _________________ Jack Staggs
Actual name |
MoPor Samba Member
Posted: Thu May 31, 2012 6:47 am Post subject: |
Jacks wrote: |
Often times "upgrade" can be confused with "change". The two are quite different. As is the constant in life, everything is a trade-off. |
I imagine a disc brake "change" is an upgrade for some and a downgrade for others. Each to their own. _________________ Matt
'58 356A coupe
'00 Boxster S |
356JAEGER Samba Member
Joined: May 19, 2007 Posts: 444 Location: Norte California
Posted: Thu May 31, 2012 11:21 am Post subject: |
For my money, the original drums work very well when properly maintained.
Attractive as discs may be, the gain in weight, the cost, replacement cost for the hub/disc unit and, for myself, the clincher, longevity. I also use type 5 silicone brake fluid. Some cite failed brake light switches and soft pedals using it. I have never had an issue in 10 years and when performing a bleed of the system, after 10 years had zip to purge. I think many of the 'problems' that seem to occur, are caused by the failure to replace any component that can retain trace of the old fluid. The pedal is a little softer than the discs in my 912 but that makes them easier to modulate, at least for myself. Just one more set of opinions from a 28 year owner/driver. _________________ Regards,
Joel Jensen
When in doubt, think about it..
The outcome of a project is directly proportional to its preparation. |
Posted: Thu May 31, 2012 2:44 pm Post subject: |
How much do new 356 front drums cost?
I tried to find an online supplier but I didn't really see anything listed (but I didn't search too hard).
I have a set of NOS drums, but I went with discs because I wanted to lower the front of my car as well. Pedal pressure is slightly higher, but it's a good time to replace the master cylinder with a modified dual circuit one for disc brakes. _________________ "There is only one sin; disconnection from self." |
MMW Samba Member
Posted: Thu May 31, 2012 3:22 pm Post subject: |
Why did you have to go with discs to lower your car? I put drop spindles on my 59a & kept the drums. Also the bars are adjustable. _________________ Mic
1959 356 coupe
Posted: Thu May 31, 2012 3:51 pm Post subject: |
The front of a 356 can be lowered or raised easily using the adjusting screws on the torsion bars, disc brakes are not a requirement. A dual circuit master cylinder will work on a drum or disc system, discs however, require an air bleed to allow the pads to retract. A single cylinder will not fail if properly maintained, and you do keep your emergency brake adjusted I hope ? That is also a 'dual circuit ' system, albeit manually operated. True, good used drums or having them relined is not inexpensive, but you'll only do it once. _________________ Regards,
Joel Jensen
Posted: Thu May 31, 2012 4:36 pm Post subject: |
MMW wrote: |
Why did you have to go with discs to lower your car? I put drop spindles on my 59a & kept the drums. Also the bars are adjustable. |
Free bonus! The adjustment on the beam is 'not enough'.
I guess with how little 356's are actually driven, the drums should last forever. _________________ "There is only one sin; disconnection from self." |
Posted: Thu May 31, 2012 7:05 pm Post subject: |
Erik G wrote: |
thefladge wrote: |
Thanks
Erik |
The calipers came in boxes with the following part numbers:
171-615-423B Left
171-615-424B Right
The 171 indicates a VW Rabbit origin, although when I do a web search using those complete part numbers, all I get are websites about Chinese made Beetle parts.
I suspect they have altered the part numbers to throw us off the trail. I believe the real VW part numbers should be 171-615-123B and 171-615-124B.
These fit numerous late '70's to early '80's water cooled VWs including the Rabbit.
As for the pads, there was no part number on the box. _________________ 1957 Vintage Baja Bug.
Erik G Samba Member
Posted: Thu May 31, 2012 8:03 pm Post subject: |
thefladge wrote: |
Erik G wrote: |
thefladge wrote: |
Thanks
Erik |
171-615-423B Left
171-615-424B Right
As for the pads, there was no part number on the box. |
Well, that's an awesome start. I suppose the easiest thing would be to buy the set, and take the pads in and start looking for a match in the 80's rabbit era
This is good news, because almost all the 80's jetta/golf based cars are upgradeable, G60 brakes could probably be used.
Thanks much for the insight
As to drums, again Im a type3 guy, and i have never had an issue with single circuit drum brakes. Type 3's are very similar to 356 in that its a much larger drum and shoe, twin brakes cylinders on each wheel, etc. I even run a semi metallic top shoe and organic lower, for a little better performance. But, alas, our cars are not so popular, parts are not made, and where it makes sense to do 100pt or at least correct as possible on a 356, not so much on a type 3...yet. _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
