Aloha Bob Samba Member
Joined: March 25, 2012 Posts: 62 Location: Madera, California
Posted: Mon Jun 04, 2012 9:08 am Post subject: GoldWing Motor swap |
I was cleaning my GoldWing last night and was thinking.
It has a compact 1800 cc boxer motor that is fuel injected and has 180 hp.
Anyone ever try putting one of those in a Bug?
FYI....because the motor is a component of the frame and when they get laid down or (heaven forbid) run into something..the insurance companies don't fix them, they total them out and I have seen them go for $500 .
With all the crap that I have on mine , it has to weigh 1100 pounds...and I can smoke a corvette from a standing start up to about 90 when the motor stops pulling hard.
Any thoughts (other than agreeing with my wife that I am too old to be riding a motorcycle) ? |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Mon Jun 04, 2012 9:16 am Post subject: |
That's an interesting idea! What is the bore and stroke on those engines? What about clutch issues with a heavier VW? _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
Posted: Mon Jun 04, 2012 10:07 am Post subject: |
I have not a clue on boar and stroke....I will need to google it.
As far as clutch goes....I actually tow a little trailer that weighs about 500# when it is fully loaded down (we do wine rides and the Boss loads it down at each stop we make).
I had a clutch put in it at 87,000 miles and the guy at Wingworks said it would have gone another 20k or so.
What could be sweet would be some place like McCloud to take a VW blank fly wheel and put a GoldWing crank bolt pattern on it and have plate to go between the motor and trans.
I have a Atlantic in boxes that has a Hewland transaxle that is based on a VW style case....with a adapter plate that bolts the Holbay engine on.
I will have to find the box with that and see. |
Posted: Mon Jun 04, 2012 10:11 am Post subject: |
About 20 years ago, I put a 903 Kawasaki in a bug eyed sprite by making a longer drive shaft an hooking it up to the output shaft on the Kawi trans (long detailed story on how it was done).
That car would scream. No clutch problems ....and no reverse. |
windsoreight Samba Member
Joined: February 25, 2012 Posts: 148 Location: Tavares, Fl
Posted: Mon Jun 04, 2012 10:33 am Post subject: |
At the last VW show I went ,there a vendor there with a kit to install a Harley v-twin using the stovk VW trans. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7210 Location: Videbaek Denmark
Posted: Mon Jun 04, 2012 10:35 am Post subject: |
That engine is actually an Alfa Romeo engine.
- I think the 180 hp is........ slightly positive. Most of them produce about 155-160 IRL.
Anyway. It is not a problem Adapters are produced several places. I even think KEP have them in their program.
T |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76897 Location: Sneaking up behind you
Posted: Mon Jun 04, 2012 10:54 am Post subject: |
Torque is what will push a VW down the road. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Jun 04, 2012 11:28 am Post subject: |
Great info.
Thank you.
The 180 hp is what the people at WingWorks told me after they charged me $250 for some part and installation.
The Wing does scare me sometimes when I am riding down the road and wondering why everyone else is going so slow.
The Boss whacks my helmet and says unkindly things on the intercom. |
supersuk Samba Member
Joined: December 20, 2010 Posts: 958 Location: Honolulu, Hawaii
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Mon Jun 04, 2012 12:14 pm Post subject: |
supersuk wrote: |
6 cyl boxer engine
74mm x 74mm
118hp 5500rpm
123 lb/ft 4000rpm |
Thats enough power and torque to make it worthwhile to give er a go - but I think the Subaru transplant would be a better investment since all the parts needed are available over the counter. Even a small Subaru motor will provide more power. Want more? Go with one of the turbo versions. Can you buy an 1800 GW motor for $500? _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13846 Location: White Mountains Arizona
Posted: Mon Jun 04, 2012 1:25 pm Post subject: |
This is interesting and never heard of it but man what an idea. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Mon Jun 04, 2012 9:00 pm Post subject: |
Glenn wrote: |
Torque is what will push a VW down the road. |
Torque is what pushes my long bed, 4 door, 4wd, powerstroke pulling 26000 lb trailer with a vw inside of it down the road |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Tue Jun 05, 2012 4:21 am Post subject: |
OLD VW NUT wrote: |
supersuk wrote: |
6 cyl boxer engine
74mm x 74mm
118hp 5500rpm
123 lb/ft 4000rpm |
Thats enough power and torque to make it worthwhile to give er a go - but I think the Subaru transplant would be a better investment since all the parts needed are available over the counter. Even a small Subaru motor will provide more power. Want more? Go with one of the turbo versions. Can you buy an 1800 GW motor for $500? |
I'm sure the Honda engine will not have the head gasket and timing belt issues that the Subi's have. _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Tue Jun 05, 2012 7:49 am Post subject: |
looks like a lotta stuff hanging below the crankshaft.........
_________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
mark tucker Samba Member
Posted: Tue Jun 05, 2012 7:58 am Post subject: |
MURZI wrote: |
not realy, justlook at where the cam on a vw would be, and then the sump and then the added sump, looks great to me, and with some work probably a lot more power.and of corse the honda brand with it's superrior casting&machining, manufacture,desine, reliabilty,etc. bore it to 94 stick some 450f pistons in it,have jose stroke it a bit ,bore out the throttle bores and go have fun. |
Posted: Tue Jun 05, 2012 12:32 pm Post subject: |
I asked a friend who is a buyer for a company called "CoPart" to look and see what the 6cyl Wings were going for .
He said that a couple that had been in front end wrecks went for $350.
There is soooo much ABS plastic on these things that is soooo expensive...that no body wants them.
I asked him to keep an eye out for me.
People in the GoldWing club think that I am nuts.
They say that my problem will be the electronics.
Along with putting a 903 in a sprite, I have done things like putting a 350 chevy in a TR-6 and a 260 Z...a 302 in a Plymouth Arrow mini pick up, a 215 olds aluminum V-8 from a 64 into a Datsun 510....and some other "different" combinations.
Maybe it is because I drink too much beer and end up staring at stuff in my little shop too long. |
Posted: Tue Jun 05, 2012 2:18 pm Post subject: |
I am going to a pre auction on Friday to see a wrecked Wing. |
bugger101 Samba Member
Joined: September 04, 2010 Posts: 1559 Location: orlando
JustBuggy Samba Member
Joined: August 01, 2010 Posts: 849 Location: SF Bay Area, Ca.
Posted: Tue Jun 05, 2012 9:58 pm Post subject: |
That 215 into a 510 was a popular swap back in the good ol' days! |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Wed Jun 06, 2012 7:48 am Post subject: |
Buick aluminum V8's have been swapped into mid engine Crovairs, makes a nice light powerpack. I'd be interested to see if the Honda engine fit width-wise into an unmolested VW engine bay, would be an interesting swap. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
