Panel removal help
Lohe
Lohe is offline
PostPosted: Tue Jun 05, 2012 8:29 am    Post subject: Panel removal help Reply with quote
Ok I need a quick 'schooling' please!
I have a 59 panel which has been SERIOUSLY bondo'd and has SERIOUS frame rust (basically the entire frame is falling apart, it has huge amounts of bondo on every panel except the upper half of the bus and even panels of sheet metal riveted all over the place.. it's totally not saveable without MAJOR work and cash).
I also have a 60 panel which has a good frame and just your normal rust in the normal places.
What I want to do is remove the upper side sheet metal from the 59 and weld them on the 60.
I have some spot weld removal 'bits' from Harbor Freight and a mig welder. Is there an easier way to do this?
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Tue Jun 05, 2012 8:33 am    Post subject: Reply with quote
is the top of the 60 wasted? if not why not just repair the 60?
1958 custom camper
http://www.thesamba.com/vw/forum/viewtopic.php?t=483656
1958 deluxe Parts needed
1 rear hatch
2 rear pressed bumper trim
3 locking t handle
4 safaris
5 front hurst
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Tue Jun 05, 2012 8:40 am    Post subject: Reply with quote
I try not to drill through both panels if possible. Sometimes I will use a small angle grinder to remove just the back side of a spot weld, if I can sacrifice the back piece. Sometimes I just use a center punch and a regular drill bit.
werksberg Premium Member
werksberg is offline
PostPosted: Tue Jun 05, 2012 10:54 am    Post subject: Reply with quote
Eastwood & other tool suppliers has a special spot weld hole saw bit....has a live center on it.
Werksberg Products....Products that work!
Free shipping on sale items this weekend until 5/28/13 listed in my feedback on here.
Follow my new products on my Facebook Werks Berg
Click the below ADs link for products & feedback.
Search "werksberg" on Photobucket for products photos & Please remember to buy "American made products!"
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Tue Jun 05, 2012 1:54 pm    Post subject: Reply with quote
http://www.ebay.com/itm/Spot-Weld-Cutter-Drill-Bit..._500wt_922
these are the ones i use. with a panel knife in the joint for tension the welds pop easily and have minimal drill through.
1958 custom camper
1 rear hatch
3 locking t handle
4 safaris
5 front hurst
Z
Z is online now
PostPosted: Tue Jun 05, 2012 9:50 pm    Post subject: Reply with quote
I found the HF bits too soft - they dulled VERY quickly. Bought a set from the Snap-On truck and they were awesome.
PostPosted: Tue Jun 05, 2012 10:00 pm    Post subject: Reply with quote
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Wed Jun 06, 2012 12:20 pm    Post subject: Reply with quote
For sure get cobalt if you can as spot welds are harder than plain steel
1958 custom camper
1 rear hatch
3 locking t handle
4 safaris
5 front hurst
Lohe
Lohe is offline
PostPosted: Wed Jun 06, 2012 8:05 pm    Post subject: Reply with quote
Thanks guys, I'm going to try an angle grinder since the lower panels are absolutely shot. The only reason I'm swapping out the panels is I got a KILLER deal on the 59 and if you wanted to rebuild it you would literally have to rebuild the entire 'frame' and the floor and most of the other metal, basically just make an entire bus out of green panels and put the plate on it.. and the 60 has windows cut in it and I really want factory side panels!
KevinAlbrecht
KevinAlbrecht is offline
PostPosted: Wed Jun 06, 2012 9:14 pm    Post subject: Reply with quote
Seems like you could patch it easier (and cleaner). Then swapping the belt line up?
Kevin Albrecht
WideFive wrote:
Single carbs are for lawn mowers!
Don't forget those seat-belts!
Click to view image
Lohe
Lohe is offline
PostPosted: Thu Jun 07, 2012 6:03 am    Post subject: Reply with quote
I think the end result of swapping the outer shell is going to be cleaner, but yes, probably a lot easier just to patch it. So much less fun though!
KevinAlbrecht
PostPosted: Thu Jun 07, 2012 6:55 pm    Post subject: Reply with quote
I would think lining up an upper sectioned half is fraught with complications a "non-professional" would not have the experience to be able to recover from completely, and and then you would be left with a hack job that you would need help fixing.
Vs.. Patching some windows that could be worked on after the fact, as time facilities and budget permits.
Now, I you may have mad skills, so more power to you.. but I would hate for you. I get yourself in a situation that no one wants to be in.
Kevin Albrecht
Click to view image
KevinAlbrecht
PostPosted: Thu Jun 07, 2012 6:56 pm    Post subject: Reply with quote
Kevin Albrecht
Click to view image
