Removing exhaust manifold
JSalzillo
JSalzillo is offline
PostPosted: Thu Jun 07, 2012 9:57 am    Post subject: Removing exhaust manifold Reply with quote
Can you remove the exhaust manifold from a 72' 1600 without removing the engine?
65'1300Deluxe
65'1300Deluxe is offline
PostPosted: Thu Jun 07, 2012 10:05 am    Post subject: Reply with quote
Do you mean the muffler portion or the heat riser section under the carburetor?
1965 Deluxe Beetle "Camilla"
1972 Super Beetle Barnfind "Roland"
2001 GTI 1.8L Turbo
JSalzillo
PostPosted: Thu Jun 07, 2012 10:11 am    Post subject: Reply with quote
I meant the heat riser below the carb. It is a dual port.
CaffeineJunky
CaffeineJunky is offline
PostPosted: Thu Jun 07, 2012 10:17 am    Post subject: Reply with quote
I've removed the entire intake manifold from my single port engine including the heat riser without pulling the engine. It was a pain, but it was doable. You'll have to remove your generator/alternator, the gen/alt pulley stand, and possibly some of the other components. Can't remember if I "had" to remove the fuel pump and distributor, but I did because I was replacing a bunch of stuff.
I assume it would actually be slightly easier on a DP engine because of the rubber boots on the intake.
1969 VW Bug - 1600 on a 5" narrowed beam
JSalzillo
PostPosted: Thu Jun 07, 2012 11:21 am    Post subject: Reply with quote
I think it would be easier with the boots also. I have a small leak which I've heard is a common problem with older cars. Not a big deal but something that needs to be addressed. Thanks
