bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Sun Jun 10, 2012 10:50 am Post subject: Cast 82mm Crank |
I've owned an 82mm Cast Porsche journal crank that I've been planning to use for a 2110. It was turned to .020 and wrapped up a few years ago. I located a set of Porsche rods and had them rebuilt so the set is ready to go.
I chose an Engle 120 because its' powerband peak is the same or close to the max rpm limits of the crank. I also am using a Bosch SVDA with a 5400 RPM rotor so over-revving will not be an issue.
Question is has anyone ever heard of or had a cast crank problem before? _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Sun Jun 10, 2012 11:33 am Post subject: |
My opinion......... Take your 82 cast crank, sell it, get what you can for it and buy a quality DPR crank. But don't mind my opinion (I'm a cast crank Haterrrr ) you'll get plenty of guys here to tell you cast cranks are great, go right ahead and use it. _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Sun Jun 10, 2012 11:41 am Post subject: |
If you're going to put a 5400 rpm rotor in it, why not use a W110 to more closely match that rpm ceiling? Why have something that will rev to 6000 rpm if you're not going to use it? _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Sun Jun 10, 2012 2:28 pm Post subject: |
I've had a 78 cast crank engine and broke it at the drags. I've had two 69 cast crank engines both with less then 100 HP and neither have had any problems after hundreds of drag strip passes. RPM is not what is going to kill your cast crank. HP and torque will. You can turn it to 8000 RPM, you just can't use in an an engine that makes over 100 HP. I totally agree with darth, sell the cast crank and rods and get a new forged crank and H beam rods. The China junk today is still good to 200 HP without any problems.
Have you see the price of Porsche rod bearings? There is a reason nobody uses them any more. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
