harpua Samba Member
Posted: Mon Jun 04, 2007 1:36 pm Post subject: engine squeak/whistle |
| Something amskeptic wrote the other day has me wondering... He mentioned a canary chirp indicating a head gasket leak. I've always thought aircooled vdubs always have sort of a charactertistic high pitch squeaky, squealy sort of sound; canary chirping wouldn't be my first description but maybe it fits. Even as a kid I recall esp. typeI's having this sound. Is this what he is talking about? Could that sound I know and love as a characteristic of aircooled VW's (and hear in my own '77 westy) actually be a head gasket leak? |
wangdang Samba Member
Joined: October 21, 2003 Posts: 95 Location: So. Lake Tahoe, CA
Posted: Mon Jun 04, 2007 1:40 pm Post subject: |
| it could be, but it could also be an intake leak. |
JMazier Samba Member
Joined: February 20, 2006 Posts: 902 Location: In my garage, Georgetown, Ontario, Canada...
Posted: Mon Jun 04, 2007 1:49 pm Post subject: |
Maybe the sound that you know and love is the "fweem" thing which is a normal VW sound, mainly from Type 1 engines… If so then nothing to worry about. I am not familiar with the sound of a head leaking however a leaky exhaust is a high pitched intermittent sound. _________________ Cheers!
Jérôme
’79 Cali Westy 2.0 F.I.
'74 Honda CB 350 Four
'78 Honda CB 750 K
'12 Golf GTI
'11 Ural Patrol |
busman78 Samba Member
Joined: August 17, 2004 Posts: 3255 Location: ALbuquerque, NM
Posted: Mon Jun 04, 2007 8:19 pm Post subject: |
| Could also be the altenator cover plate vibrating against the alternator or the lack of oil below the felt pad in the center shaft of the distributor. Plug the exhaust pipe and that will answer whether it is an exhaust leak. |
phoneguy Samba Member
Joined: March 14, 2008 Posts: 155 Location: Long Island
Posted: Mon Jun 11, 2012 4:13 pm Post subject: |
I have this same problem,I removed the Alt belt and the squeak/chirp is still there. Sounds like it's coming from the pulley. What was the resolution here ? _________________ "When my ship comes in I'll be at the airport"
1971 Supervert
1977 Westfalia |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 23891 Location: Surrey B.C. Canada, Land of the giant flying moose!
Posted: Mon Jun 11, 2012 4:48 pm Post subject: |
Either the shroud is loose and the fan is rubbing or the distributor needs a lube. _________________ Rust NEVER sleeps and stock never goes out of style.
Wanted, 68-73 westy OG plaid curtains, singles OK. |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 8551 Location: Syracuse, NY
Posted: Mon Jun 11, 2012 5:21 pm Post subject: |
Sounds like vid #3 but a little bit more like metal squeak from the fan pulley, I recently (about a month ago) lubed the distributor. BD , when you say the shroud could be loose are we talking alternator shroud or fan pulley shroud ? _________________ "When my ship comes in I'll be at the airport"
1971 Supervert
1977 Westfalia |
Posted: Mon Jun 11, 2012 5:34 pm Post subject: |
Fan shroud, especially if it's got A/C, pull the fan and look for fresh shiny parts. _________________ Rust NEVER sleeps and stock never goes out of style.
Posted: Mon Jun 11, 2012 5:52 pm Post subject: |
| busdaddy wrote: | | Fan shroud, especially if it's got A/C, pull the fan and look for fresh shiny parts. |
Will do , by the way it does have AC but there is no belt. _________________ "When my ship comes in I'll be at the airport"
1971 Supervert
1977 Westfalia |
Posted: Mon Jun 11, 2012 6:21 pm Post subject: |
| phoneguy wrote: | | busdaddy wrote: | | Fan shroud, especially if it's got A/C, pull the fan and look for fresh shiny parts. |
Will do , by the way it does have AC but there is no belt. |
doesn't have to work, just the added weight and years of stress can sometimes make the shroud sag. _________________ Rust NEVER sleeps and stock never goes out of style.
Posted: Tue Jun 12, 2012 5:24 pm Post subject: |
No shiney parts. Am I looking at a head replacement or retorqueing the heads ? _________________ "When my ship comes in I'll be at the airport"
1971 Supervert
1977 Westfalia |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 5406 Location: Edmonds, WA.
Posted: Tue Jun 12, 2012 5:28 pm Post subject: |
the chirp from types ones is a non even fire distributor (the 3rd cam lobe is retarded a bit to lower head temps)
...i think. _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
DAD's - 1972 Westfalia ~ Sticky ~ 1.7(?) 914 motor, allison electronic ignition, electric fuel pump, dual webers w/o choke.
“Don't cry because it's over, smile because it happened.”
“Those who mind don't matter, and those who matter don't mind.” |
Posted: Tue Jun 12, 2012 5:46 pm Post subject: |
This is a type 4 _________________ "When my ship comes in I'll be at the airport"
1971 Supervert
1977 Westfalia |
Posted: Tue Jun 12, 2012 9:42 pm Post subject: |
| phoneguy wrote: | | This is a type 4 |
got that, but you mentioned a type one earlier. just ignore me... it works out best when people do most of the time  _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
ccpalmer  Samba Member
Joined: September 17, 2006 Posts: 3518 Location: Ann Arbor, Michigan
Posted: Wed Jun 13, 2012 5:03 am Post subject: |
| Stuartzickefoose wrote: | the chirp from types ones is a non even fire distributor (the 3rd cam lobe is retarded a bit to lower head temps)
...i think. |
wrong _________________ '71 Westy
'77 Bay/rusty shed on wheels
Chris Palmer
Cocobolo Co., LLC
ccpalmer.com |
Posted: Wed Jun 13, 2012 5:55 am Post subject: |
| ccpalmer wrote: | | Stuartzickefoose wrote: | the chirp from types ones is a non even fire distributor (the 3rd cam lobe is retarded a bit to lower head temps)
...i think. |
wrong |
okay...-1 for me... _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
Posted: Wed Jun 13, 2012 6:13 am Post subject: |
Just reread this thread and I didn't realize that type 4's have head gaskets as type 1's don't. I guess I need to replace them ? _________________ "When my ship comes in I'll be at the airport"
1971 Supervert
1977 Westfalia |
SGKent Samba Member
Joined: October 30, 2007 Posts: 17550 Location: State Capitol CA (Sacramento)
Posted: Wed Jun 13, 2012 1:24 pm Post subject: |
| phoneguy wrote: | | Just reread this thread and I didn't realize that type 4's have head gaskets as type 1's don't. I guess I need to replace them ? |
actually VW recommends removing them on the next rebuild and shimming under the cylinder to make up the loss. _________________ Steve aka Merlin the Wrench
formerly Steve's Racing and Engine Blueprinting. Wrenching since 1967.
bdamico on GF wrote | Quote: | | "When I was your age I'd plan out all sorts of stuff for the future and almost none of them came true. Just wonder if it's worth trying to be a crystal ball. " |
Posted: Wed Jun 13, 2012 7:04 pm Post subject: |
I don't know it even has them, I'm going to try torqueing the heads again and go from there. _________________ "When my ship comes in I'll be at the airport"
1971 Supervert
1977 Westfalia |
