Electrical problems, seriously done with this! Help!
Goto page 1, 2  Next
Adee24
Adee24 is offline
PostPosted: Sat Jun 16, 2012 8:23 pm    Post subject: Electrical problems, seriously done with this! Help! Reply with quote
Alright people , so 62 bug doesn't want to start, didn't have any problems until recently.. I've been posting forums and getting Feed back and still nothing. BRAND new 6v starter, BRAND new 12v battery, BRAND new 12v bosch coil, BRAND new alternator, and looks to be a brand new ignition switch ... The motor turns.. But doesn't have enough to start.. Did the load test on the brand new battery which I just bought today and it passed by far.. Need help.
w3lfd
w3lfd is offline
PostPosted: Sat Jun 16, 2012 8:40 pm    Post subject: Reply with quote
Did you replace the starter bushing?
Cusser
Cusser is offline
PostPosted: Sat Jun 16, 2012 8:42 pm    Post subject: Reply with quote
Does the engine spin at the right speed when you try to start? You've replaced starter AND ignition, muddying the water, instead of logically troubleshooting.
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2004 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
Adee24
Adee24 is offline
PostPosted: Sat Jun 16, 2012 9:00 pm    Post subject: Reply with quote
Starter yes, ignition no, but it looks like its new ... Since the person I bought it from.. I've cleaned up all connections too.. The motor turns, but seems like it doesn't crank enough to turn it over completely . Starter solinoid go out so soon ? I've only had it for about 2montha.
w3lfd
w3lfd is offline
PostPosted: Sat Jun 16, 2012 9:12 pm    Post subject: Reply with quote
The bushing in the transmission that the armature of the starter rests in.... Did you replace it? If not, the worn old bushing could be causing the starter to turn slow.
Adee24
Adee24 is offline
PostPosted: Sat Jun 16, 2012 9:17 pm    Post subject: Reply with quote
Yeah I replaced it ... I have no idea what can be the problem..
agh19
agh19 is offline
PostPosted: Sat Jun 16, 2012 9:44 pm    Post subject: Reply with quote
Check the connections of the ground strap (front of the trans). If that connection is weak, it could explain your problem.
agh19
agh19 is offline
PostPosted: Sat Jun 16, 2012 9:54 pm    Post subject: Reply with quote
Adee24
Adee24 is offline
PostPosted: Sat Jun 16, 2012 11:07 pm    Post subject: Reply with quote
Whats the easiest way of accessing it ? Any pictures ? Please ? Any other suggestions ?
65'1300Deluxe
65'1300Deluxe is offline
PostPosted: Sat Jun 16, 2012 11:12 pm    Post subject: Reply with quote
Jack up the rear of the car, the strap should be hanging down slightly between the front of the transmission and the mount it attaches to, on the passenger's side if I remember right.
1965 Deluxe Beetle "Camilla"
1972 Super Beetle Barnfind "Roland"
"I will finish the car(s) when I feel like it!"
I bet the idle sounded like Optimus Prime punching a sperm whale in the face.[/quote]
Adee24
Adee24 is offline
PostPosted: Sat Jun 16, 2012 11:14 pm    Post subject: Reply with quote
What is it connected to? Because I followed all the wires , and none of them lead to a transmission strap, I'm new with the electrical part..
65'1300Deluxe
PostPosted: Sat Jun 16, 2012 11:27 pm    Post subject: Reply with quote
They won't. The strap is only attached to a bolt on the transmission and one of the two front transmission mount studs on the car body.
65'1300Deluxe
PostPosted: Sat Jun 16, 2012 11:29 pm    Post subject: Reply with quote
It should look like this more or less.
Adee24
Adee24 is offline
PostPosted: Sat Jun 16, 2012 11:51 pm    Post subject: Reply with quote
Alright I'll look into it tomorrow morning . Thanks ! Sorry to ask but what is THAT ground strap for ? It isn't hooked up to the battery, or starter ? Or ?
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Sun Jun 17, 2012 2:32 am    Post subject: Reply with quote
It's there because the transmission is mounted on rubber mounts! The only direct metal-to-metal connections without a dedicated ground strap would be the axle tubes/wheel bearings and the clutch cable - both of which are not exactly great places to have high current flowing through them. Factory photo... it's on the left (driver) side.
Also, just wanted to ask, what kind of condition where the actual teeth of the flywheel in?
-Andy
sixfootdan
Samba Smartass
Location: \Lo*ca"tion\, n. 1. The act or process of locating.
sixfootdan is offline
PostPosted: Sun Jun 17, 2012 6:25 am    Post subject: Reply with quote
X2 on that, 90 percent of all electrical problems are bad grounds IMO.
There are 3 kinds of people in this world, The kind that can count and the kind that can't.
GO SEAHAWKS!!!
Adee24
Adee24 is offline
PostPosted: Sun Jun 17, 2012 8:27 am    Post subject: Reply with quote
It's a brand new flywheel and starter, so the teeth should be good , ima check out the ground strap right now, and pull out the starter to check it out. Anything else I should check? I'm just trying to get this thing going.. It's almost there !
andk5591 Premium Member
andk5591 is offline
PostPosted: Sun Jun 17, 2012 8:47 am    Post subject: Reply with quote
Well - you did not confirm that your ignition has no problems. Check for spark and if not strong, test coil and then check points and condensor. Just had a condensor crap out on the way to a car show yesterday. Hard start, hardly would run.......
D-Dubya Manx clone - 63 Short pan,1776.
Max - 73 standard project at wife's request and your gonna die when you see this one.
Adee24
Adee24 is offline
PostPosted: Sun Jun 17, 2012 9:59 am    Post subject: Reply with quote
Alright guys, I cleaned up the transmission ground strap, and all the connections once again and nothing so I said ima just take the starter out and check it out, (3 months old) I took it back to the shop, because I have a life time warranty Smile and put it in, and boom! Starts up like a champ !
KTPhil
KTPhil is offline
PostPosted: Sun Jun 17, 2012 10:54 am    Post subject: Reply with quote
Block the wheels, OUT of gear, ebrake firmly on... ignition switch off. Crawl under the car with a big (and insulated!) beat up old screwdriver, and short from the push-on terminal to the big stud/nut on the solenoid. If it cranks fast now, but not with the ignitionn/starter switch, then either the starter wiring or your switch is bad.
If it's still slow, then it's battery wires, solenoid or starter.
Goto page 1, 2  Next
