Dual 28 PICT on 1200
Goto page 1, 2  Next
DONGKG
The Araneta Boys
Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
DONGKG is offline
PostPosted: Tue Jun 12, 2012 9:27 am    Post subject: Dual 28 PICT on 1200 Reply with quote
I have a 65 bug that I am planning to install dual 28 PICT Solex. As far as I know, there was never a dual 28 PICT carbs aftermarket kit. If anyone has ever done this set up, I would like to know how do I do it particularly the custom manifolds, linkages and other essential parts that are needed to complete it. Thanks a lot in advance for your replies. Enjoy your vee-dubs daily.. Thanks.
'67 KG Cabrio (Mickey) ;
'66 Type 3 (Sharky 2)
'72 Type 2 Homey
'67 Splitty Bus
'65 beetle;'69 Country Buggy; TOOB MEMBER #20
aryue
aryue is offline
PostPosted: Tue Jun 12, 2012 9:40 am    Post subject: Reply with quote
For a 1200cc, I'm only aware of the dual 32 PBIC kit that mimics the old Okrasa set up.
http://www.wolfsburgwest.com/wolfsburg_new/engine/25-36hp/WW_dual_port_carb.cfm
The whole kt, to include new heads, looks like the one below.
http://www.wolfsburgwest.com/wolfsburg_new/engine/25-36hp/WW_dual_port_kit.cfm
- Andrew in Austin, TX -
OldandSlow - but still chuggin.
http://www.ph.utexas.edu/~yue/VW/VWBus.html
DONGKG
The Araneta Boys
DONGKG is offline
PostPosted: Tue Jun 12, 2012 9:47 am    Post subject: Reply with quote
Thanks for the reply. I have checked those repro okrasa kit, but it is too expensive besides, it may not fit on a '65 vw engine with a later block design. I was thinking of the idea of customizing the manifolds, etc., for the 2 stock 28 PICT Solex carbs. And in this set up, the manifolds and linkages are of paramount consideration. Hence, I need some informations on how it is being customized.
Thanks so much.
DONGKG
'72 Type 2 Homey
'67 Splitty Bus
Steve22
Steve22 is offline
PostPosted: Tue Jun 12, 2012 10:07 am    Post subject: Reply with quote
Here's some pics of my dual 28 PCI setup in my old '64 ghia, currently the motor is sitting in my garage awaiting rebirth in my '65 ghia 'vert.
The manifolds are made from regular 40hp manifolds.
perhaps might get more/better responses in vintage speed forum?
'65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
DONGKG
The Araneta Boys
DONGKG is offline
PostPosted: Tue Jun 12, 2012 10:14 am    Post subject: Reply with quote
Thanks so much for those pictures. Surely, it will help me on my project. Did you re-jet these carbs for proper air/fuel mixture to match the engine? Thanks again.
DONGKG
'72 Type 2 Homey
'67 Splitty Bus
Steve22
Steve22 is offline
PostPosted: Tue Jun 12, 2012 10:16 am    Post subject: Reply with quote
DONGKG
I have not re-jetted them yet, as i have a 83mm big bore kit to put in first, then jets as needed.
'73 Super Beetle
'59 Beetle ragtop
Braukuche Premium Member
Braukuche is offline
PostPosted: Tue Jun 12, 2012 11:46 am    Post subject: Reply with quote
I am running dual 28 PCIs on my vintage Rethwish kit on a stroked 36hp.
Go Reds! Smash state!
My retirement plan:
1958 PG/SG Standard
1959 SO-23 Westfalia
1960 crusty double cab
1960 convertible bug
1962 So-22 Mosaic Westfalia
1963 356 B coupe runner
1963 356 B coupe in pieces
1965 standard sunroof bus
1967 912
Steve22
Steve22 is offline
PostPosted: Tue Jun 12, 2012 6:29 pm    Post subject: Reply with quote
pics or it didn't happen! Laughing
'73 Super Beetle
'59 Beetle ragtop
DONGKG
The Araneta Boys
DONGKG is offline
PostPosted: Wed Jun 13, 2012 1:36 am    Post subject: Reply with quote
Steve22 wrote:
DONGKG
Thanks for that info. Please let me know as soon as your engine is running.
thanks.
'72 Type 2 Homey
'67 Splitty Bus
DONGKG
The Araneta Boys
DONGKG is offline
PostPosted: Wed Jun 13, 2012 1:54 am    Post subject: Reply with quote
I just bought a NOS Borg Wagner vintage linkage (circa early 70's) for vws. I will use this for my dual 28 PICT Solex project...
this is the Manual that came from the set:
I hope this works.... Any inputs, comments or suggestions, are very much welcome.. Thanks
'72 Type 2 Homey
'67 Splitty Bus
Richard Roth
Richard Roth is offline
PostPosted: Sun Jun 17, 2012 6:26 am    Post subject: Reply with quote
here is an nos Empi dual carburetor kit I just purchased.
It is designed to use dual stock carburetors on 36 or 40 hp motors.
The problem with reality is that there's no background music !
1966 Empi GTV MKIV
1954 Kabriolett Beetle
1953 Porsche 356 1500S
1957 Cable brake standard model
1962 cable brake standard model
1956 23 window Samba
1960 Austin Healey 3000
1961 Corvair Greenbrier
PostPosted: Sun Jun 17, 2012 6:36 am    Post subject: Reply with quote
very cool. It appears the heat riser block offs have an "R" stamped on them, and judging by the looks it appears to be a Rethwish kit which EMPI carried before they carried the Okrasa kit. I have the same Rethwish kit on my '58 bus. It appears that you have two of the brackets for the carb linkage, that's odd. Where did you find it? Do you have other pictures? Any directions? I found mine under an old guys house already installed. Did yours come with air cleaners or indicate what cleaners were used?
My retirement plan:
1958 PG/SG Standard
1967 912
Richard Roth
PostPosted: Sun Jun 17, 2012 8:19 am    Post subject: Reply with quote
Here is the ad which I scanned from one of my Empi catalogs.
I believe the reason there are two brackets included are because one may be for the 36hp and the other for the 40hp ?
They are slightly different.
1966 Empi GTV MKIV
PostPosted: Sun Jun 17, 2012 8:36 am    Post subject: Reply with quote
Thanks Richard, very cool ad, answers my question about the air filters. I am running a pair of original Knecht early Porsche filters right now. I think you are right about the linkage one for the 36 and one for the 40.
My retirement plan:
1958 PG/SG Standard
1967 912
Richard Roth
PostPosted: Sun Jun 17, 2012 8:41 am    Post subject: Reply with quote
Notice the kit in the ad is built on a "Bastard" motor !
1966 Empi GTV MKIV
PostPosted: Sun Jun 17, 2012 10:08 am    Post subject: Reply with quote
Which means it is probably only good on the bastard engine and not later 40hp engines, which means it was likely not made after '60? Is there any year on your lit or the box?
Come to think of it, when I pulled all this stuff out of the guy's house there was a bastard 40 engine amongst the heap of engines, but I also found a 36hp engine with an original EMPI 69.5 crank which is also pre-Okrasa.
My retirement plan:
1958 PG/SG Standard
1967 912
Richard Roth
PostPosted: Sun Jun 17, 2012 10:19 am    Post subject: Reply with quote
The box is post marked 1965.
The catalog the ad came from is dated 1963.
So it will work on 40hp motors.
The Okrasa kits were available in the late 1950's.
1966 Empi GTV MKIV
DONGKG
The Araneta Boys
DONGKG is offline
PostPosted: Sun Jun 17, 2012 9:01 pm    Post subject: Reply with quote
I recently customized a dual 30 PICT Solex (instead of dual 28 PICT) and these are the process as shown on the pictures:
The donor parts: two 1200 K manifolds and two 30 PICT carbs plus the Borg Warner NOS Linkage I bought.
The removed the end castings of the intake and exhaust manifolds.
Preparing for the proper alignments of the manifolds to get the correct angels.
Welding together the intake and exhaust manifolds.
Checking the fitments whether the carbs snags correctly in the intake manifold.
I bought a tubing for the balances and had it bended to mimic the Okrasa style.
I also bought this tubing for the fuel system and had it welded too to again imitate the Okrasa style.
Welding the balancer onto the manifold.
The finished manifolds. I placed the dual carbs to see if the alignments and angels are in order.
The initial checking for the parts to be needed prior to the installation.
I painted the manifolds using pilox easy spray paints.
Installing the manifolds, the dual 30 PICT Solex carbs and the balancer.
I placed the fuel lines onto the engine after installing the carbs and had it bended accordingly to its proper positions.
Finally, finished, expect for the vintage style air cleaners.
The video of the engine running. I think I need to re-jet these carbs.
Thanks a lot.
Dongkg
'72 Type 2 Homey
'67 Splitty Bus
DONGKG
The Araneta Boys
DONGKG is offline
PostPosted: Sun Jun 17, 2012 9:19 pm    Post subject: Reply with quote
I am planning to customize an Okrasa Style exhaust systems. I would like to have some pictures of the construction of the inside of the exhaust systems. If anyone of you has it, I would highly appreciate if you would share it with me. Thanks a lot.
'72 Type 2 Homey
'67 Splitty Bus
Kjell Roar
Kjell Roar is offline
PostPosted: Sun Jun 17, 2012 10:07 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=375343&start=100
Smile
I got a historic car, every scratch got a history...
My car, aug. 55 / a 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438
Goto page 1, 2  Next
