Glenn73 Samba Member
Joined: May 30, 2011 Posts: 816 Location: West Jordan UT
Posted: Wed Jun 13, 2012 9:55 pm Post subject: Is my compression too high? |
Ok. So I had to get a new motor due to a ruined crank and using
http://www.csgnetwork.com/compcalc.html I get 11.4-1.
Its a 1776cc with AA P&Cs, Stock crank, rods, rockers, heads, and a mild cam (an ACE 262 special grind).
Also running 34-3 carb with a 009 (I know not the best combo) and a stock muffler. _________________ 1973 SB 1776cc
Sat from 93-2008
Work in progress. |
KopfenJager Samba Member
Joined: December 09, 2011 Posts: 586 Location: Oregon
Posted: Wed Jun 13, 2012 9:58 pm Post subject: |
post your measurments, that seems realy high for a 1776. _________________ SI VIS PACEM PARA BELLUM |
Posted: Wed Jun 13, 2012 10:04 pm Post subject: |
It has a 0.060 base shim and a 0.040 copper head shim.
So it is at about 0.10 deck. _________________ 1973 SB 1776cc
Sat from 93-2008
Work in progress. |
Posted: Wed Jun 13, 2012 10:15 pm Post subject: |
what do the heads cc out to be? _________________ SI VIS PACEM PARA BELLUM |
Posted: Wed Jun 13, 2012 10:22 pm Post subject: |
43cc I dont know how I missed that part
Sat from 93-2008
Work in progress.
SRP1 Samba Member
Joined: January 06, 2007 Posts: 3918 Location: Escondido, CA
Posted: Wed Jun 13, 2012 10:26 pm Post subject: |
So .100" deck, what head cc?
With a head cc of around say 54cc's, your at 7.3:1
I would shoot for a deck of .050-.070" for a compression ratio of 7.7-8.1:1
depending on your build criteria.
Like I said "what head cc?" is the key question in determining your actual
deck height and final comp ratio. _________________ www.srpengines.com
Bugless.......
GDOG57 Samba Member
Joined: March 19, 2006 Posts: 981 Location: Gilbert,Arizona
Posted: Wed Jun 13, 2012 10:29 pm Post subject: |
Just punch in your numbers here:
http://www.cbperformance.com/enginecalc.html _________________ '57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
'57 type 2 panel ( L31 dove blue) project daily driver,Singleport 1955cc |
SRP1 Samba Member
Posted: Wed Jun 13, 2012 10:30 pm Post subject: |
| Glenn73 wrote: | | 42cc I dont know how I missed that part |
Ahhh your at 8.6:1 right now, and your deck height is ridiculously huge.
I would have your pistons dished, then bring the deck height down as close to .060" as you can. .100" deck and it will be a ping monster. _________________ www.srpengines.com
Bugless.......
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 2835 Location: Planet VW
Posted: Wed Jun 13, 2012 10:33 pm Post subject: |
Perfect. _________________ CH3NO2.
Der Blitzkrieg Kafers |
Oh thank you I must have punched the numbers in wrong to get 11.4-1  _________________ 1973 SB 1776cc
Sat from 93-2008
Work in progress. |
Posted: Wed Jun 13, 2012 10:59 pm Post subject: |
If I plug in 90.5mm bore, 69mm stroke 42cc heads and .010 deckheight I get 11.2 to 1 CR. So the question is, what is the final deck height after all the shims and gaskets etc. How far do the pistons sit down in the bore? .010 is EXTREMELY tight deck . At .040 deck your still pushing 10-1CR. At .060 deckheight you about 9.6-1 CR. Those chambers seem pretty small to me to run on pump fuel. _________________ SI VIS PACEM PARA BELLUM |
modok Samba Member
Joined: October 30, 2009 Posts: 8632 Location: Colorado Springs
Posted: Thu Jun 14, 2012 12:30 am Post subject: |
| "stock" 113 heads with the step cut out are usually around 47cc, are you sure your heads are 42? that's small! |
66brm Samba Member
Joined: January 25, 2010 Posts: 2527 Location: Perth Western Australia
Posted: Thu Jun 14, 2012 12:35 am Post subject: |
Perhaps the anti Berg creator has struck again!!!!!! _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
| modok wrote: | | I am an expert at fitting things in holes, been doing it a long time |
Posted: Thu Jun 14, 2012 11:06 am Post subject: |
| Quote: | KopfenJager
So the question is, what is the final deck height after all the shims and gaskets etc. How far do the pistons sit down in the bore? .010 is EXTREMELY tight deck |
It sits at .100" deck.
| Quote: | modok
They were on a 1600cc that bummed out on me and left impressions where the cylinders were. When they got cut for 90.5's they got cut a lil deep.
| Quote: | | I would have your pistons dished, then bring the deck height down as close to .060" as you can. .100" deck and it will be a ping monster. |
Actually it doesn't ping. I run nothing under 91 octane. _________________ 1973 SB 1776cc
Sat from 93-2008
Work in progress.
Posted: Thu Jun 14, 2012 3:12 pm Post subject: |
Ok 8.6 Cr. _________________ SI VIS PACEM PARA BELLUM |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 1006 Location: Videbaek Denmark
Posted: Thu Jun 14, 2012 3:19 pm Post subject: |
Get your deck height down to 0,043 - 0,050" and find yourself another set of heads.
Runing that much deck (0,100) makes for a lazy running hot running, polluting SOB.
T |
Posted: Thu Jun 14, 2012 3:21 pm Post subject: |
PS. that cam can handle a tad more CR. if needed, as long a s the timing is under control. 8,4 is no problem.
T |
Posted: Mon Jun 18, 2012 2:11 am Post subject: |
Ok. So now that its been noted that it is an ok CR What kind of carb and distributor combo should I use?
I am open to going to Dual carb. _________________ 1973 SB 1776cc
Sat from 93-2008
Work in progress. |
Posted: Mon Jun 18, 2012 9:08 am Post subject: |
If you ever think that someday you will want a bigger engine with bigger heads , cam etc. Go duals. Weber 44Idf's can cover most engine combo's if jetted right with the proper venturi. Other carbs can work well, but none work as good as a set of properly tuned duals. _________________ SI VIS PACEM PARA BELLUM |
