cdennisg Samba Member
Joined: November 02, 2004 Posts: 10112 Location: Sandpoint, ID
Posted: Fri Jun 22, 2012 8:06 am Post subject: |
| Gary wrote: |
| cdennisg wrote: |
| Gary wrote: |
| WD-40 is worthless and will never be found in my garage. |
Gary, maybe not in your garage, but in the basement workshop? Kitchen junk drawer? Cleaning closet? |
No basements in Oklahoma  |
Where do you go when the twister is looming on the horizon? We always had basements in MN. _________________
| Olddog52 wrote: |
| horn test. one tab to ground, the other to a 12 volt source. Listen intently for a sound. |
Gary Person of Interest
Joined: November 01, 2002 Posts: 16982 Location: 'Murrica
Posted: Fri Jun 22, 2012 8:09 am Post subject: |
| cdennisg wrote: |
| Gary wrote: |
| cdennisg wrote: |
| Gary wrote: |
Where do you go when the twister is looming on the horizon? We always had basements in MN. |
Protocol down here is to run outside and photograph or take video. Thought you knew? _________________ -
Download this spreadsheet for NOS/OE parts inquiries--> http://vwjudsonregister.tripod.com/IMAGES/2013-parts-spreadshhet.xls |
Posted: Fri Jun 22, 2012 8:18 am Post subject: |
| Gary wrote: |
| cdennisg wrote: |
| Gary wrote: |
| cdennisg wrote: |
| Gary wrote: |
Protocol down here is to run outside and photograph or take video. Thought you knew? |
As a kid, I could only stand outside to watch until things got really hairy, then mom would yell at me. My dad was a State trooper, so he was always out spotting tornadoes. He has some great pictures. As I got older, I was able to watch a few twisters first hand. They are a beautiful thing. _________________
| Olddog52 wrote: |
drscope Samba Member
Joined: February 19, 2007 Posts: 13524 Location: Baltimore, Maryland USA
Posted: Fri Jun 22, 2012 9:26 am Post subject: |
| Gary wrote: |
Tornado celler? _________________ Mother Nature is a Mean Evil Bitch! |
ritchiet002 Samba Member
Joined: January 27, 2003 Posts: 1351 Location: Kaneohe, HI
Posted: Sat Jun 23, 2012 10:20 am Post subject: |
| doc1369 wrote: |
| blankmange wrote: |
| everybody for the discussion on how WD-40 is not a lubricant, so should not be compared to something that is advertised as a lube? |
True, WD-40 is not a lube. A tomato is not a vegetable. We all forget ourselfs sometimes . My point stands that "generic" products are just that. |
It is a hell of a cleaner on duct tape residue! It worked like magic! _________________ Somewhere there is a jar with your name on it!
From now on, I'm gonna connect the dots my own way!______________________________________ |
barrysmith Samba Member
Joined: July 14, 2006 Posts: 263 Location: wilburton oklahoma
Posted: Sat Jun 23, 2012 12:14 pm Post subject: |
| I have been using an oil can lately with great success. |
Dave24 Samba Hack Purist
Joined: April 14, 2004 Posts: 7720 Location: Hablamos Ingles, So. Cal.
Posted: Sat Jun 23, 2012 1:58 pm Post subject: |
| The TinMan wrote: |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 8646 Location: SHALIMAR ,FLORIDA
Posted: Sat Jun 23, 2012 10:08 pm Post subject: |
| just dont use a wd 40 type of product on any bearing or bearing serface, such as roller bearing, main bearings rod bearings,cam bearings, crankshaft, needel bearings etc. it is a dispersant, and forms a barrier. witch can keep the oil from doing it,s job. and in the end you have burnt up bearings& parts. mecury marine learned this the hard expensive way, and thus the tsb on it. if you dont beleave it just spray a nice machined part then try to get the oil to stick to it. I knew a guy that rinced all his bearings with wd , he had a lot of junk motors. was it the wd?? or just dumb luck? I probably would not of thought about the affects of it if I did not do warranty work for mercurry marine, mercurry racing,mercrusier, (and others) |
doc1369 Samba Member
Joined: March 31, 2010 Posts: 3087 Location: Las Vegas, NV, again
Posted: Sun Jun 24, 2012 9:33 am Post subject: |
My boss showed me how to remove tape that had ben dried on a 10k paint job by spending months in the desert sun. WD-40 The expensive adhisive remover we had didn't even soften it up but with the WD and three times as much elbo grease it came off. This is on a bike that is worth more than most of you make in a year. I don't think the watered down cheap stuff would have done the job and there is no way I would put my job on the line to find out.
For lube, my choice is the Wurth HHS 2000. _________________ Fatchicks: Daily drivers, donor cars, collectibles. What can't they do? |
