MY lifted '58 DD Panel build
Goto page Previous  1, 2, 3 ... 7, 8, 9, 10, 11  Next
plane_ben
plane_ben is offline
PostPosted: Thu Apr 05, 2012 1:30 pm    Post subject: Reply with quote
Have you performed all the required modifications to make that shroud work correctly?
Maybe. Fill me in on what you know. I was just making sure all my tin was modified for a close fit, and making sure all air gaps in my cutouts were sealed.
Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. ~Dr. Seuss
AlteWagen
Troll
AlteWagen is offline
PostPosted: Fri Apr 06, 2012 11:19 am    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=372579
Like I said earlier, sell the shroud and buy floor panels and belly pans especially if you really plan on taking it off road.
DubStyle
SBS Hit Squad
DubStyle is offline
PostPosted: Fri Apr 06, 2012 7:10 pm    Post subject: Reply with quote
Interesting...
Anthony
SBS #1
"The original & best lowered Split Bus website/club"
plane_ben
PostPosted: Sat Apr 07, 2012 2:23 pm    Post subject: Reply with quote
OK, I read the whole post. I didn't see anything on the guy losing his engine. As far as his tests go, he doesn't say what his head temp is, just the differences between cylinders. At the most, I think he said a 50 degree difference between the 1-2 bank and the 3-4 bank. That disparity isn't even worth chasing. I have a Yamaha XS650 that has a 45 degree difference between left and right cylinders, Doesn't hurt anything. Yamaha engineers new this, didn't bother with it. Why? Because it just doesn't matter. The guy is also dealing with a highbred engine and running fuel injection, not a type 1,2 block like I am. I have cool tins on mine too, something he was beginning to experiment with.
KCW just finished a low light ghia for a customer last year. Big block type 1 with the same setup. Owner has taken it to Denver, Moab, and several other long hauls; plus drives it daily in Grand Junction. No indication of any problems. Just had it in the shop for a tune-up this past week, a 6000 mile check up so to speak.
I think if you pay attention to carb jetting and don't go to lean, keep the compression around 9 : 1, that you can't burn up a VW engine. That being said, am I going to do my due diligence and monitor the hell out of this engine? You betcha!
As far as the floors go. I do have belly pans already. I'm thinking I'll put some metal in the cargo floors too. Then some wood over that.
SO33
SO33 is offline
PostPosted: Sun Apr 08, 2012 12:02 am    Post subject: Reply with quote
Amazing job. Keep it up !
Mark19
Mark19 is offline
PostPosted: Fri Apr 20, 2012 8:25 am    Post subject: Reply with quote
Well Ben, I did it.... 1 more Scott Hall project to get finished by a new owner.
What should I do first???
Did you put it all together then take it apart to paint it? OR did you paint it and go from there?
Mark Reega
480-221-8385
plane_ben
PostPosted: Fri Apr 20, 2012 5:08 pm    Post subject: Reply with quote
Hi Mark, I stripped mine down, did all the rust repair, then body worked and painted the shell. Reassembled the shell, just have to body work all the removeables and paint now. If I had the bucks for a clutch and ignition, I could have it running.
Congrats on your purchase. Lets see a thread started soon. Very Happy
plane_ben
PostPosted: Sat Jun 02, 2012 5:30 pm    Post subject: Reply with quote
It has been some time since my last post. I was working on a friends SC for the last few months. Finally got that out of the way.
Today, I put in the bay window gas tank. Messaged the middle to fit the tranny hump, then made som extender straps. After I finished that I installed my engine. Had some interference with the throttle bar and the tank seam, so bent those down some and now I'm golden. Wouldn't of had this problem with standard tin, but because of the Bergman unit the carbs have to mount with throttle bar to the rear.
Tomarrow I will get the exhaust going.
joe cool
joe cool is offline
PostPosted: Sat Jun 02, 2012 9:22 pm    Post subject: Reply with quote
Beautiful job denting the bay tank. Aren't you concerned about the oil filter in harms way? A hit there and you won't be driving home.
plane_ben
PostPosted: Sat Jun 02, 2012 9:40 pm    Post subject: Reply with quote
Oil filter is actually above the sump by two inches. Plus the exhaust will provide some deflection.
RPGreg2600
RPGreg2600 is offline
PostPosted: Sun Jun 03, 2012 9:45 am    Post subject: Reply with quote
I've run those filters on every Vw I've owned. They are not in harms way. I do like to make a heat shield for them though.us
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Sun Jun 03, 2012 1:48 pm    Post subject: Reply with quote
even though i am sure they are fine those pump filters have some small oil galleys. i bought one and didnt use it once i saw them. regular full flow is way bigger.
cant wait to see this thing up and going
1958 custom camper
http://www.thesamba.com/vw/forum/viewtopic.php?t=483656
1958 deluxe Parts needed
1 rear hatch
2 rear pressed bumper trim
3 locking t handle
4 safaris
5 front hurst
Mark19
Mark19 is offline
PostPosted: Thu Jun 14, 2012 10:29 am    Post subject: Reply with quote
how many gallons is the bay window fuel tank?
Mark Reega
480-221-8385
plane_ben
PostPosted: Thu Jun 14, 2012 4:10 pm    Post subject: Reply with quote
I think it's about 14-16 gallons. There were different bay window tanks and I don't know witch one I have.
SingleWheel
SingleWheel is offline
PostPosted: Thu Jun 14, 2012 4:51 pm    Post subject: Reply with quote
Keep up the good work Ben, Still plenty of us lurking your thread as you proceed.
Visit http://www.singlewheel.com
drnewman
drnewman is offline
PostPosted: Thu Jun 14, 2012 6:19 pm    Post subject: Reply with quote
I really like this build, nice to see something different!
'70 bug -never ending baja project
plane_ben
PostPosted: Sun Jun 24, 2012 1:58 pm    Post subject: Reply with quote
Engine is running. Took the bus up and down the street today. Other than a reverse lockout problem, everything is working great. Need to get busy with bodyworking the doors.
garagecat
garagecat is offline
PostPosted: Sun Jun 24, 2012 7:48 pm    Post subject: Reply with quote
Great thread read the whole thing and I'm looking forward to more updates.
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Sun Jun 24, 2012 8:07 pm    Post subject: Reply with quote
that thing looks great the stance is mean.
1958 custom camper
1 rear hatch
3 locking t handle
4 safaris
5 front hurst
plane_ben
PostPosted: Sun Jun 24, 2012 9:53 pm    Post subject: Reply with quote
Thanks guys. I'm beginning to see the light at the end of the tunnel. Very Happy
Page 8 of 11
