Maddog209 Samba Member
Joined: November 03, 2011 Posts: 291 Location: Central Valley, Ca.
Posted: Fri Jun 29, 2012 2:53 pm Post subject: Axle nut removal? |
Does anyone have a trick or suggestion on how to easily remove the rear axle nut on a Bug? Would PB Blaster or similar product help? I'm using a breaker bar and still no luck other than damn near lifting the rear of the car off the stand. _________________ Current VW's= 2013 Tiguan, 1968 Bug |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2765 Location: The World's Motor Capital
Posted: Fri Jun 29, 2012 3:22 pm Post subject: |
This subject comes up pretty regularly.
Personally, I'm a big fan of the "torque tool".
Whacking on it (and your wheel bearings) with a hammer might remove the nut, but you probably will want to put it back on; at the correct torque setting.
Buy or borrow the "torque tool".
This thing will make the job 9 times easier.
Since you live in California, there are probably a bunch of these tools within a 20 mile radius of your house; maybe somebody close will chime in.
Good luck, Mondshine
GA_Boy Samba Member
Joined: October 10, 2006 Posts: 1405 Location: Jefferson, GA
Posted: Fri Jun 29, 2012 3:26 pm Post subject: |
There are numerous ways-------Did you use the Search engine?
You can take it to a truck tire repair facility and have them loosen with a huge impact wrench and tighten back enough to get you home.
Regular (conventional)threads on both sides------counterclockwise to loosen.
Just remember to tighten to the proper torque when you go back with it.
Marvin |
Vinnems Samba Member
Joined: December 23, 2008 Posts: 1181 Location: Simi Valley, CA
Posted: Fri Jun 29, 2012 4:23 pm Post subject: |
You can borrow my Torque Tool if you find yourself around my neighborhood, but I figure you're a bit too north. |
RDbugger Samba Member
Joined: January 10, 2012 Posts: 157 Location: Sydney,Australia
Posted: Fri Jun 29, 2012 5:26 pm Post subject: |
Removing my one as well. Using blow torch, wax and w40. Soaking it now with W40, wash the w40 off because if you heat it up again.You will get a ball of fire. |
Dismas Samba Member
Joined: September 16, 2010 Posts: 184 Location: Reno, NV
Posted: Fri Jun 29, 2012 5:32 pm Post subject: |
I welded a socket onto the end of a 5' chunk of pipe . . did the job admirably _________________ 69/70 chop refurbed from a 70 baja |
Posted: Fri Jun 29, 2012 6:14 pm Post subject: |
GA_Boy wrote: |
Marvin |
DON"T ask me if I used the search engine? I was looking for help in the moment. This isn't my first post or first time on a forum.
I managed to remove the seized nuts with PB Blaster and an impact gun.
Thanks to all for the advice. BTW, the "torque tool" is awesome looking. I will be adding one to my tool collection. _________________ Current VW's= 2013 Tiguan, 1968 Bug |
Posted: Fri Jun 29, 2012 6:15 pm Post subject: |
Vinnems wrote: |
Thank you for the offer!! _________________ Current VW's= 2013 Tiguan, 1968 Bug |
Cadaver Samba Member
Posted: Sat Jun 30, 2012 10:55 am Post subject: |
John Muir says
a large pipe wrench (or cold chisel ) and a BFH.
that sets one end. for the cheap skate spectrum.
there are 10 ways
which way depends on
your cash flow.
your time line, or down time..
none of which we know.
the right torque wrench is $600 from Proto.
the torque Meister is $60 and beats them all hands down. YES 9 TIMES>
only John wins in the hippy domain./ zero bucks, and fatherinlaws tools.
or better, he gets his "freeloaders to do it" my all time fav, in his book....
getting off is easy ((no pun ,)
back on , a whole other issue.
if done wrong the drums will crack.
and if you look close, do it., imagine if said crack hit a wheel bolt hole.
dont ask. (but lots of photos here to bare witness)
the $5 way < hand drill in hand,
the long angle irons. x2
comes off.
then back on:
a bathroom scale and a Archimedes rule set.
then you weigh your self, (no guessing or fibbing) the placing hands
on the pre marked 300 lbs points.
you drop your body on the bar , exactly THERE. fun yet?
the second locking bar can be skipped (left side example)
with 3 fat chicks in back seat of your FAT CHICK, brakes set, 4 wheels chocked,
nose up hill going off
nose down going on.
it's is urban rumor, the chick way, YFCMV, your fat chicks may vary.
some weekly. _________________ for sale now.
in Samba classifieds....1968 T1. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31270 Location: Hot Arizona
Posted: Sat Jun 30, 2012 6:09 pm Post subject: Re: Axle nut removal? |
Maddog209 wrote: |
Does anyone have a trick or suggestion on how to easily remove the rear axle nut on a Bug? Would PB Blaster or similar product help? I'm using a breaker bar and still no luck other than damn near lifting the rear of the car off the stand. |
You loosen these with the wheel and tire on the ground. Same for tightening. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
jhvw1976 Samba Member
Joined: August 14, 2009 Posts: 152 Location: Joplin, MO
Posted: Sat Jun 30, 2012 6:18 pm Post subject: |
*hijacking for a moment..sorry* if anyone near Joplin, MO has one of the torque meister and a torque wrench to let me borrow, barter (I have a 73 seat I'd trade), or rent let me know it would help me out a ton. I lost that stuff a year ago and haven't had $ to replace it. _________________ 1976 standard stock FI beetle daily driver |
buggy2430 Samba Member
Posted: Sat Jun 30, 2012 6:29 pm Post subject: Air Impact |
Use a impact wrench. It will NOT hurt your car. I've used it for years with NO problems. I even put my flywheel gland nut on with one. I know there are many who will say this is the WRONG thing to do. But it works for me. |
Posted: Sat Jun 30, 2012 9:24 pm Post subject: Re: Axle nut removal? |
Cusser wrote: |
Maddog209 wrote: |
You loosen these with the wheel and tire on the ground. Same for tightening. |
NOT an option with custom wheels.
And, as mentioned above, I was able to get both sides removed with PB Blaster and an impact gun. Upon inspection of the left rear brake I found a 2' piece of the shoe lining broken off and rattling around inside the drum. New shoes purchased and will be installed tomorrow. _________________ Current VW's= 2013 Tiguan, 1968 Bug |
Posted: Sun Jul 01, 2012 6:08 am Post subject: |
see, the easy part
now to put it back on. _________________ for sale now.
Cusser Samba Member
Posted: Sun Jul 01, 2012 9:05 am Post subject: Re: Axle nut removal? |
Maddog209 wrote: |
Cusser wrote: |
Maddog209 wrote: |
Oh. I can remove the axle nut on my aftermarket wheels with the wheel on.
But first I have to remove the wheel, take off the cotter pin, and remount the wheel. So usually nowadays I just use my electric impact wrench. Note that I'm in Arizona, no rust, and I've owned mine for 38 years, so very few surprises.
Maddog209 wrote: |
I found a 2' piece of the shoe lining broken off and rattling around inside the drum. New shoes purchased and will be installed tomorrow. |
Great. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
DrummerDaveB Samba Member
Joined: March 25, 2005 Posts: 504 Location: Louisville, KY Area
Posted: Thu Jul 05, 2012 1:11 pm Post subject: |
Or you can do what I did - Put a ratchet on the nut w/ a 2 foot cheater bar.
Then put in one lug nut to the right side of that.
Then put a big lug wrench on that lug nut,
Then jump up and down on both at the same time, whilst holding your nuts hoping you dont get a cheater bar through them.
_________________ 79 SB Vert, in pieces.
Kadrons, SVDA. |
71superAS Samba Member
Joined: February 02, 2012 Posts: 223 Location: New York
Posted: Thu Jul 05, 2012 1:15 pm Post subject: |
DrummerDaveB wrote: |
Buy a cup! [Or athletic protector, or whatever they are called now] _________________ Ahoy! |
Posted: Fri Jul 06, 2012 6:06 pm Post subject: |
I remember on my 74 trying to get the castle nut off. Had a 36mm socket, two foot breaker bar, and a five foot steel pipe over it. Me and my buddy just ended up bending the pipe That's when I bought the torque tool posted here, and even with that, I still have to use the cheater bar and a lot of force. The nut wasn't even rusted when I pulled it, just the PO hired a gorilla to put it on, apparently. I used a torque wrench to put them back on. One lined up perfectly, other I had to still do another 1/4 of a turn to get teh cotter pin in. YMMV.
Don't even get me started on the engine gland nut. I had two guys standing on the case and three guys on the five foot pipe to no avail |
AggieDave Samba Member
Posted: Fri Jul 06, 2012 6:15 pm Post subject: |
I punch through it with my impact wrench.
If you're rebuilding a car or doing any amount of custom car work you should invest in a decent air compressor and some basic air tools. It will make your life much better. Sure you can do a complete resto on a VW with nothing but a 13mm wrench and some foul German language, but why not make it easier by having tools that help. |
flyboat Samba Member
Posted: Fri Jul 06, 2012 7:07 pm Post subject: |
With the wheel off and the car on stands, place a crow bar thru 2 of the lug bolts and locked against the ground, then place a 1 7/16 or 36 mm socket and a breaker bar on the nut. Now stand on it. It will come off. If you happen to weigh about 250 lbs, re-install the nut with all your weight placed on the breaker bar at 12" from the socket to get 250 ft lb torque. _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car |
