2276 cc engine with dual 48 IDF Webber Carbs
luismemo21
luismemo21 is offline
PostPosted: Mon Jul 02, 2012 1:42 pm    Post subject: 2276 cc engine with dual 48 IDF Webber Carbs Reply with quote
Is it possible to convert this engine from a dual carb to a single carb?
Its a 2276 cc engine with dual 48 IDF Webber Carbs
jfats808
jfats808 is offline
PostPosted: Mon Jul 02, 2012 1:45 pm    Post subject: Reply with quote
Answer to your question is yes. My question is why? 48 idfs are good carbs especially for that size engine, assumming that the combo matches. If your having tuning issues, list your combo so we may attempt to help u. Or is there something else?
2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote:
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick
You can always learn something new, even from a fool.
Check your oil levels routinely!
krusher
krusher is offline
PostPosted: Mon Jul 02, 2012 1:53 pm    Post subject: Reply with quote
http://vwparts.aircooled.net/Deluxe-Centermount-Intake-Manifold-Kit-Weber-IDF-p/99004-315.htm
(06:31:07) RoachGhia: "i drink dick way too fast"
luismemo21
PostPosted: Mon Jul 02, 2012 2:05 pm    Post subject: Reply with quote
Well Im using this 1970 Fasty as a daily driver, and I want to remove a carb in an attempt to save a little more gas, since its ridiculous nowadays. I understand when driving a car like this, you can't really expect fuel effeciency, but things are tight, and anything helps.
jfats808
jfats808 is offline
PostPosted: Mon Jul 02, 2012 2:27 pm    Post subject: Reply with quote
Gotta realize that removing one carb doesn't necessarily mean less fuel consumption. Dependant on the rest of the combo by just judging on the size and carb size/type, I don't think the engine is really designed to be a fuel sipper. The best of both worlds is to look for someone who's willing to trade up your 48s for 40s and maybe cash. Otherwise a well tuned engine can get you 18-28 mpg depending on driving style.
vwracerdave
vwracerdave is offline
Believe it or not, you can actually get better milage with dual carbs then a single when they are set up corectly.
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
Joel Mohr
Joel Mohr is offline
PostPosted: Mon Jul 02, 2012 2:39 pm    Post subject: Reply with quote
I get 27 on the highway with my 2442 and dual 49s....yes, 49s. Duals are much more efficiant than a single....[/quote]
SEE YOU AT THE RACES!!!!
luismemo21
PostPosted: Mon Jul 02, 2012 2:40 pm    Post subject: Reply with quote
So when you say, "set up correctly", what exactly should I be looking for? Im not extremely knowledgable with engines, so anything helps really.
Patrickvw
Patrickvw is offline
PostPosted: Mon Jul 02, 2012 2:47 pm    Post subject: Reply with quote
I once traveled 800 miles with a friend. He was in a 63 beetle with a 1776cc with dual single barrel solex's and I was in a 68 beetle with a 1904cc with dual 2 barrel dellorto 40's. He kept bragging about getting way better millage than me. but after the round trip I calculated that I got 44 mpg and he only got 30 mpg. I also spent less money on fuel and filled up less. He had to down shift going up hills and passing and I didn't, therefore keeping the RPM's down.
vwracerdave
PostPosted: Mon Jul 02, 2012 2:52 pm    Post subject: Reply with quote
Here's a few articles to read to get you started.
http://www.aircooled.net/vw-carburetor-tech/
vwracerdave
PostPosted: Mon Jul 02, 2012 2:54 pm    Post subject: Reply with quote
If he had the stock geared 63 transaxle and you had the stock geared 68 transaxle YOU SHOULD have gotten better milage them he did.
Patrickvw
PostPosted: Mon Jul 02, 2012 3:00 pm    Post subject: Reply with quote
He had and still has a freeway flyer transaxle. Mine is a stock 68 transaxle
krusher
krusher is offline
PostPosted: Mon Jul 02, 2012 3:52 pm    Post subject: Reply with quote
44mpg is very high, was this calculated of your speedo/odometer that was tested as accurate?
luismemo21
PostPosted: Mon Jul 02, 2012 4:18 pm    Post subject: Reply with quote
My engine only has 67K miles, and those 48s were brand new when the engine was built. Coming from someone with experience, how much do you think they're worth? And roughly how much should 40s cost?
Patrickvw
PostPosted: Mon Jul 02, 2012 4:22 pm    Post subject: Reply with quote
I know 44mpg is high. I didn't believe it myself. This was my first time travelling with this car. we drove down to the Great Canadian VW Show in vancouver. I live about 400 miles north. I made it about 300 miles before I filled up (I wasn't empty yet, and he only made it about 150 miles (he was completely empty). I drove into vancouver (about a 100 more miles), filled up the day I left, And then drove back home (another 400 miles). I actually probably drove a bit more than 800 miles with the driving I did in Vancouver. I remember only filling the car 3 times on the trip and then when I got back home. yes, this was using the odometer.
jfats808
jfats808 is offline
PostPosted: Mon Jul 02, 2012 4:58 pm    Post subject: Reply with quote
Get your carbs dialed in first and get a shop to show you how. Or, go and read up on how to do it. You can get over 25+ mpg once u get them tuned up. Last ditch effort you can easily get 150$ + a set of 40s from the right person. But I implore u to get it tumed and synched first. There is reading material and thereafter a you tube video.
[email protected]
john@aircooled.net is offline
PostPosted: Mon Jul 02, 2012 5:42 pm    Post subject: Reply with quote
carb sizing is the SAME for duals or center mount. A 48 IDF is HUGE and too big for most applications.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
DarthWeber
DarthWeber is offline
PostPosted: Mon Jul 02, 2012 5:49 pm    Post subject: Reply with quote
Guys, he's trying to convert his Fastback, Type 3, to a single carb.
In a word.......no.
Dual carbs, in this application, are orders of magnitude better than a single centermount carb. BTW, with a 2276 and Dual 48IDF's what kind of fuel mileage were you expecting to achieve? Not being sarcastic here, just a straight up question.
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
luismemo21
PostPosted: Mon Jul 02, 2012 6:09 pm    Post subject: Reply with quote
In a word.......no.
The person I bought this from put this engine in it. I was more interested in the car itself than the power, and the opportunity was just to good to pass up. I'm just trying to find ways to help my MPG out thats all. Anything helps.
DarthWeber
PostPosted: Mon Jul 02, 2012 6:12 pm    Post subject: Reply with quote
Do you know anything about this engine? Like, what cam it has in it? Type of heads, exhaust? I'm sure there's someone out there who would swap you some 44IDF's or Dellorto 40DRLA's for your 48IDF's - providing it's possible with your engine combo.
