Oil interior heater, anyone have good luck with these?
Buzdrum
Buzdrum is offline
PostPosted: Mon Jul 02, 2012 10:25 am    Post subject: Oil interior heater, anyone have good luck with these? Reply with quote
I want to put a oil heated heater in the bus. I'm also putting in a full flow oil system. Has anybody ever used one? It's the last one on the bottom of the link page...
http://www.vwheaters.com/
busdaddy
busdaddy is offline
PostPosted: Mon Jul 02, 2012 12:10 pm    Post subject: Reply with quote
Oh my, not this question again Shocked
Short answer is no.
http://www.thesamba.com/vw/forum/search.php?search..._chars=200
Wanted, 68-73 westy OG plaid curtains, singles OK.
Wildthings
Wildthings is offline
PostPosted: Mon Jul 02, 2012 5:03 pm    Post subject: Reply with quote
Should work great during a Seattle summer if June isn't too cold.
dwill49965
dwill49965 is offline
PostPosted: Mon Jul 02, 2012 5:48 pm    Post subject: Reply with quote
Short answer is no.
The funniest one from busdaddy's list was this one - started by dcdubs -
http://www.thesamba.com/vw/forum/viewtopic.php?t=258281&postdays=0&postorder=asc&start=0
- especially the first two pages. 5 years later - no results yet. That alone should tell you something .....
Darryl
'78 Westy, Boston Bob built 2.0 L, FI, Pertronix, MSD 6
Meyer wrote:
Lastly, you just referred to US citizens as 'Americans'. Exactly what kind of Canadian are you? From what continent?
aryue
aryue is offline
PostPosted: Mon Jul 02, 2012 7:23 pm    Post subject: Reply with quote
I kind of like that wood stove idea. These days you'd be pulled over for sure, if it was fired up while on the highway.
- Andrew in Austin, TX -
OldandSlow - but still chuggin.
http://www.ph.utexas.edu/~yue/VW/VWBus.html
Desertbusman
Desertbusman is offline
PostPosted: Mon Jul 02, 2012 9:42 pm    Post subject: Reply with quote
What you are thinking about is very similar to the opposite situation.
Original air conditioning worked great but it ate up a lot of engine power. So in cold weather you could run the A/C and there was no problem for the engine. But in hot weather when you wanted A/C it will overheat the engine. For hot weather engine survival you wouldn't want to turn on the A/C.
In your casae it would be nice for the engine to run your heater in the hot summer. But not to turn it on in the winter.
The best thing that anyone can do for their Bay is get the Volkswagen of America Official Service Manual published by Robert Bentley. Without it the bus is pretty much doomed.
73kombi wrote:
when that red light goes on, you have to make a choice.
Amskeptic wrote:
I am not answering that.
Respectfully,
GoBuyABentley
71 Superbug
71 Westy
Wildthings
PostPosted: Mon Jul 02, 2012 9:48 pm    Post subject: Reply with quote
Maybe he could make a blanket for the underneath side of the engine. This would prevent cold winter air from cooling the block and would leave more heat available in the oil. My oil barely runs hot enough at 30°F to evaporate all the water out on a long run, I sure wouldn't want the oil to run any cooler.
Busdriver79
Busdriver79 is offline
PostPosted: Tue Jul 03, 2012 11:26 am    Post subject: bus heater Reply with quote
Since bus heaters really suck even when they are working well,I just decided to use one of those Heater Buddy heaters....It's mounted on the floor between the front seats and works very well....It gets nice and comfortable within minutes and stays that way....When it gets too cold outside, anything below freezing, I park the bus and drive a modern car with lots of heat !! Very Happy
