Type 4 airboat
Forum Index -> Other VW Vehicles Share: Facebook Twitter
maximumken
maximumken is offline
PostPosted: Wed May 30, 2012 10:57 am    Post subject: Type 4 airboat Reply with quote
This will be direct drive. To move the boat I need 140 ft/lb of torque at 2800 rpm or less. I'd like wide open throttle at no more than 3200 rpm so I can keep the prop diameter big. (Faster prop means the tips get inefficient)
I'd like to keep the costs down. I'm thinking about a single two-barrel carb and new spanish heads redone by Rimco or one of the other good shops. 42/36 valves should be plenty for those rpms. And I like Raby's Camper Special cam. 8/1 compression is about all I can do.
Any recommendations on stroke x bore? It would be great if I can stay small enough (2.0) not to need expensive aluminum cylinders. But it may be impossible to make that much torque at that low rpm without more cubes.
Thoughts?
brettsvw Premium Member
brettsvw is offline
PostPosted: Thu Jul 05, 2012 4:08 pm    Post subject: Reply with quote
IIRC props should only spin art certain rpms.
Unless you use an engine with very high torque you will need a reducer to lower prop speeds. Reducers also take care of main bearing problems.
The main bearing on crank where prop would bolt on needs a lot more surface area to handle a direct drive prop.
I am no expert but have ridden in a small airboat with a large cc dualport bug engine and it used a reducer.
If you search the web there are companies that design do-it- yourself kits.
BL3Manx
BL3Manx is offline
PostPosted: Fri Jul 06, 2012 12:03 pm    Post subject: Reply with quote
200 ft/lbs at 2500 rpm
http://www.n56ml.com/corvair/
maximumken
PostPosted: Fri Nov 02, 2012 11:02 am    Post subject: t4 airboat Reply with quote
Read down that link and you'll see he's on his third crank.
Now I'm thinking a 2332 with single-port heads might work and be a bit cheaper than the t4. I'll clean up the ports and build a long intake manifold.
Any thoughts on what the cam should look like to put out peak torque at about 2800 rpm or less?
Looks like Jake Raby liked the FK-41 but I need much fewer rpms (and peak torque much lower) than his engines.
BL3Manx
BL3Manx is offline
PostPosted: Mon Nov 19, 2012 8:48 am    Post subject: Re: t4 airboat Reply with quote
maximumken wrote:
Read down that link and you'll see he's on his third crank. .
You say you're building a boat. The worst thing that would happen to you if the crank breaks is it will get quiet, the boat won't sink. The engines he broke the crank on were overbored to 3100cc and he did some fairly serious yanking and banking putting extra gyroscopic forces on the crank, stuff you just can't do in an air boat. The stock 110hp Corvair got 145 lbs torque at 2800 RPM and the crank/engine would out last any VW of equivalent power you could build for thousands of $. Even if you snap a crank you can buy Corvair engines all day long for a couple hundred dollars.
http://www.n56ml.com/corvair/110curve.jpg
trik3r
trik3r is offline
PostPosted: Thu Apr 18, 2013 10:43 am    Post subject: Reply with quote
http://www.southernairboat.com/phpBB3/viewforum.php?f=57
Have a look in here for some mini airboat ideas, my suggestion would be to find a PE60 Continental which is designed to spin a prop but was a ground power unit.
brettsvw is offline
PostPosted: Tue May 07, 2013 5:03 pm    Post subject: Reply with quote
Pau atl JB Bugs in Jensen Beach FL has or had some odd ball VW cases with a oversize crank bearing at the pully end that appears to be a 4in wide bearing surface.
I do not know if he has the crank to go with the case.
Reply to topic    Forum Index -> Other VW Vehicles All times are Mountain Standard Time/Pacific Daylight Savings Time
