Voltage regulator wiring
Mmuller994
Mmuller994 is offline
PostPosted: Fri Jul 06, 2012 6:12 pm    Post subject: Voltage regulator wiring Reply with quote
How do I tell how too wire the vr on my buggy. 12v 1973
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Jul 06, 2012 6:15 pm    Post subject: Reply with quote
Glenn
Member #1009
#BlueSquare
Mmuller994
PostPosted: Fri Jul 06, 2012 6:21 pm    Post subject: Reply with quote
It's not a super beetle
Mr. 010
Glenn is offline
Doesn't matter.. the wiring is the same.
Glenn
Member #1009
#BlueSquare
Mmuller994
PostPosted: Fri Jul 06, 2012 6:23 pm    Post subject: Reply with quote
And it's a sand rail so how do I wire the voltage reg not a vw wiring diagram
Mmuller994
PostPosted: Fri Jul 06, 2012 6:25 pm    Post subject: Reply with quote
Where does the roped wire go on the diagram you posted
Mmuller994
PostPosted: Fri Jul 06, 2012 6:26 pm    Post subject: Reply with quote
And the blue wire where does that go
Mr. 010
Glenn is offline
PostPosted: Fri Jul 06, 2012 6:28 pm    Post subject: Reply with quote
Generator D+ to regulator D+
Generator DF to regulator DF
Regulator B+ to Batter and to starter
Regulator terminal 61 to idiot light
Glenn
Member #1009
#BlueSquare
Dale M.
Dale M. is offline
PostPosted: Fri Jul 06, 2012 8:53 pm    Post subject: Reply with quote
some what simpler.... And better graphic...
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Mmuller994
PostPosted: Sun Jul 08, 2012 1:08 pm    Post subject: Reply with quote
on my new regulator there is a mark for d+ the terminal that is a double with bigger connecters goes the batterey?
Dale M.
Dale M. is offline
PostPosted: Sun Jul 08, 2012 1:46 pm    Post subject: Reply with quote
Better look at it again, the large (.250) connectors should say B+ and yes they do go to battery possible to fuse panel...
