hvlp won't atomize under 90 psi @ the gun?
fugazi885
fugazi885 is offline
PostPosted: Wed Jul 04, 2012 10:43 am    Post subject: hvlp won't atomize under 90 psi @ the gun? Reply with quote
Long story short, after I screwed up my sealer coat and had to resand the entire car I need to figure out why my paint is flowing like a freaking garden sprinkler rather than a proper mist. I have a 60 gallon compressor rated at 11.5 cfm @ 90 psi, my gun is a sharpe fx300 rated at 11.4 cfm. I have eliminated as much air line and fittings as possible to free up as much air flow as possible and bought a cheap can of duplicolor paint shop paint to practice on some messed up panels that I won't be using. Even with a brand new 3/8 air hose mounted directly at the compressor with a disconnect only at the gun end and a single dessicant filter at the gun it seems I'm having to run a minimum 90 psi gun pressure (regulator at gun with trigger pulled) to get nice atomization. At that pressure it does spray beautifully but that's 3 times what the gun calls for. If it's spraying nice sould I just run with it or am I missing something here? WTF
skills@eurocarsplus
PostPosted: Wed Jul 04, 2012 7:03 pm    Post subject: Reply with quote
what are you trying to spray? what is your tip size? all of this comes into play...
you can't blast on a fill and sand with a 1.0 tip and you don't want to paint with a 2.5 tip
different guns have different purposes in the process. some guys have paint only, clear only, primer only etc guns
VWsArent4Hippies wrote:
Whenever I click on the baywindow forum I feel like I'm entering a place where most people have no sense of reality
schell '59 wrote:
The honor system works for boy scouts..not in real business
modok wrote:
It was in the instructions back when stuff came with instructions
curtis4085 wrote:
as most your information you give is crap anyway
bugger101 wrote:
skills, you never win with cheap vw people
spook
spook is offline
PostPosted: Thu Jul 05, 2012 2:51 am    Post subject: Reply with quote
sounds like you have a dirty gun
www.airkooledkustoms.com
SBS US #10
feedback on the shop : http://tinyurl.com/yc7jgkl
Welcome to he darkside, its lower here.
View user's profile Send private message Visit poster's website Facebook Twitter Classifieds Feedback
CanadianBug
CanadianBug is offline
PostPosted: Thu Jul 05, 2012 5:07 pm    Post subject: Reply with quote
Or your gun settings are way out of whack...
fugazi885
PostPosted: Thu Jul 05, 2012 5:08 pm    Post subject: Reply with quote
I was shooting my sealer coat with a 1.5 tip, I use a cheap primer gun but decided to use my finex for the sealer just because I thought it would do a better job. I cleaned and inspected the gun before use but just for shits I took it apart after my little disaster and have it soaking in laquer thinner for the last few days. Honestly I think it's an air spply issue, could even one standard coupler choke the air supply enough to cause me to have to run the pressure up so high? Maybe I need high flow couplers or my inline dessicant filter is choking me? If the gun was dirty woudn't that cause a poor spray pattern? I really need to figure this out before a second attempt. Maybe LVLP would be a better coice for my compressor size? I'm just sepeculating at this point, maybe someone else has seen this happen and knows what's up. Thanks for reading.
skills@eurocarsplus
PostPosted: Thu Jul 05, 2012 7:27 pm    Post subject: Reply with quote
it sounds like your gun, not your compressor
tmb077
tmb077 is offline
PostPosted: Fri Jul 06, 2012 7:10 am    Post subject: Reply with quote
your couplers shouldn't be causing you any issues. Once you are sure everything in your gun is spotless, orifices and all, reassemble it and then play around with each and every adjustment you can. I have a Sharpe that I spray non-metallic base and clear with, and spent a LOT of time making it spray the way I want it to. The Finex is a fairly decent gun (especially for the money)...I'd have to lean towards something with your gun settings or the material is simply to thick for the tip size.
What exactly are you spraying anyway? 'Sealer' includes a lot of different products these days...
got two H2O, but gasping for air...
eshan2
eshan2 is online now
PostPosted: Fri Jul 06, 2012 2:34 pm    Post subject: Reply with quote
Your compressor is rated at 11.5 cfm and a gun that needs 11.4cfm @ what pressure?Will your regulator flow the same or is it choking the air flow down?Are you using 1/4 inch hose or 3/8 hose? 1/4 inch does not flow as much as 3/8.This may be of some help too.
http://www.sharpe1.com/sharpe/sharpe.nsf/Files/BKFEBKFF/$File/310746F.pdf?OpenElement
I love the smell of nitro in the morning.
1963 Beetle currently under reconstruction.
Ernest.
Mike Fisher
Mike Fisher is offline
PostPosted: Fri Jul 06, 2012 3:51 pm    Post subject: Reply with quote
You can spray good primer/paint with a siphon spray gun!
http://s169.photobucket.com/albums/u236/mr_bojangles500/
69 FI/AT square Daily Driver
66 sunroof,67,71,71,71 AT,72,72 AT Parts
56 & 57 oval ragtop $2,500
fugazi885
PostPosted: Fri Jul 06, 2012 7:51 pm    Post subject: Reply with quote
Thanks for all the replies, the sealer I was shooting was Lusid Technoligies sp210 select prime mixed 4:1:1 with very slow reducer per the tech sheet. I am running a 3/8 air hose 25' long, air regulator is rated at 26CFM IIRC and the compressor is rated at 11.5 CFM@ 90 PSI. I cleaned the gun again, tore it all the way down and spent a good hour inspecting and cleaning. Didn't see anything wrong with it. Reassembled and tested again with the same result. I can make it spray really nice, but only with the pressure cranked way up. Is it really an issue to run it at such high pressure as long as the paint is going down nice? Any danger in running an HVLP gun at high pressure?
fugazi885
PostPosted: Sat Jul 07, 2012 3:10 pm    Post subject: Reply with quote
http://www.youtube.com/watch?feature=player_detailpage&v=k_8iDrLvP5s[youtube][/youtube]
maybe this helps explain my issue a little better, sorry the camera angle is a bit off.
fugazi885
PostPosted: Mon Jul 09, 2012 4:34 pm    Post subject: Reply with quote
I finally found the problem and thought it was interesting enough to share. I had a harbor freight inline dessicant dryer/filter (item# 68215) installed at the gun and it was causing a huge air restriction. It was brand new and the dessicant beads were all blue as they should be. I'm not sure if it was a defective item or if they are all restrictive but my gun is now spraying great. Maybe my mishap will be useful to someone else in the future. Thanks again for all the replies.
My project[img]Image may have been reduced in size. Click image to view fullscreen.[/img]
AZ65CalBug
AZ65CalBug is offline
PostPosted: Tue Jul 10, 2012 4:39 pm    Post subject: Reply with quote
OH CRAP! Really? I did a car not too long ago and I have the same gun. I tore that thing so far apart and clean it. It did have crap in it. It still doesn't spray right! Guess what I have on it!??!?!?
You guessed it! The HF inline dry filter!
Damn it!
Let me ask you this...
Did the gun work a few times after pulling the trigger and then stop and act stupid!? THen sometimes work and then not?!?!
My Current Project is at:
https://www.facebook.com/pages/1965-Cal-Bug/172194646214739
please like the page to get updates as they happen.
OR
http://1965calbug.homestead.com/
My Previous Project site is at:
http://1967calbug.homestead.com/
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger Facebook Gallery Classifieds Feedback
AZ65CalBug
PostPosted: Tue Jul 10, 2012 4:42 pm    Post subject: Reply with quote
Damn, just looked.. not the same thing... mine is more or less this..
OR
fugazi885
PostPosted: Wed Jul 11, 2012 3:09 pm    Post subject: Reply with quote
Kind of, it seemed like I was constantly fighting it. After I sprayed my sealer coat about half the car had a really bad texture and the other half had less texture (not quite what I would call orangepeel but similar).
If you suspect your inline flter here's how I finally found the problem.
1:Connect gun to air supply and set air pressure (30psi ish)
2:Adjust fluid knob to max flow position (all the way out then back in till you can feel it with trigger deprssed)
Adjust fan control all the way out then back in 1/4ish turn (for wide fan pattern)
3: Put a little water in the cup AIM AWAY FROM FACE and squeeze the trigger.
Look at how the water flows, whether it's atomizing into a fine mist or not. If it's spraying like crap,remove filter and recheck (make sure you check that your air pressure is the same for both tests.
If the problem is your filter it will be very obvious, at 30 psi you should be able to get about a 10" pattern if you have enough air.
hope that makes sense
eshan2
PostPosted: Wed Jul 11, 2012 5:09 pm    Post subject: Reply with quote
Those driers suck.Ive never used one that didnt cause more problems than it fixed.I got a devilbiss unit and never looked back.
Ernest.
