Adapting modern steering wheel?
crx81
crx81 is offline
PostPosted: Wed Aug 15, 2007 5:47 am    Post subject: Adapting modern steering wheel? Reply with quote
I was just wondering if anyone has adapted a more modern steering wheel from any other VW model to fit their Beetle? What did you use? How did you make it work?
I was thinking that it might be possible to bolt one up to the correct adapter for my car, but I'm afraid to just start buying wheels in a hit and miss fashion to see what works...
My site:
http://www.geocities.com/crx81/
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Aug 15, 2007 5:49 am    Post subject: Reply with quote
If your car is a 74 or newer you can mount any wheel that fits VW watercooled vehicles.
Glenn
Member #1009
#BlueSquare
crx81
crx81 is offline
PostPosted: Wed Aug 15, 2007 5:53 am    Post subject: Reply with quote
Guess I should have provided that info Rolling Eyes It's a '73 Standard.
My site:
chicagovw
chicagovw is offline
PostPosted: Wed Aug 15, 2007 1:23 pm    Post subject: Reply with quote
I would think you could use the column from a 74-up standard and then be able to use the water cooled wheel.
Mr. 010
Glenn is offline
PostPosted: Wed Aug 15, 2007 1:25 pm    Post subject: Reply with quote
Sure, you can switch it.
Glenn
Member #1009
#BlueSquare
davetaylor
davetaylor is offline
PostPosted: Wed Aug 15, 2007 2:38 pm    Post subject: Reply with quote
in my '79 i swapped in mk3 stuff and used a '92 steering wheel, but the column itself had to remain '79 to be the correct length. if you just use the steering wheel from 88+ cars you must also get the little collar from the column.
crx81
crx81 is offline
PostPosted: Wed Aug 15, 2007 10:35 pm    Post subject: Reply with quote
Any modding necessary to swap steering columns, or would it be a direct swap? That sounds like a plan if I don't have to custom fab anything to make it work.
My site:
Mr. 010
Glenn is offline
PostPosted: Thu Aug 16, 2007 2:58 am    Post subject: Reply with quote
A 73 column should bolt right in. You'll have to swap ignition locks.
Glenn
Member #1009
#BlueSquare
Charlie74Super
Charlie74Super is offline
PostPosted: Sat Jul 07, 2012 3:22 pm    Post subject: Reviving thread - steering & stalks from late WC for 74 Reply with quote
I'm looking at using a VW OEM steering wheel from a late model VW, as well as turn signal / wiper switch. Wiring isn't so much a concern (I can rewire and setup relay systems for the redux of my car) but I'm wondering what's a direct bolt-on replacement and what requires modification. I have a 74 Super Beetle with the stock steering column. Thanks in advance!!!
Webb
Antonio Trejo
VW Parts Dealer
Antonio Trejo is offline
PostPosted: Sat Jul 07, 2012 7:40 pm    Post subject: Reply with quote
The late mexican Beetles use VW steering wheels from late MK3 Jetta and Golf.
Parts VW
"From Volkswagen of Mexico factory..."
Genuine VW Sedan parts
Genuine VW Ultima Edition parts
Genuine VW Type 2 watercooled parts
Bruce
Bruce is offline
PostPosted: Sat Jul 07, 2012 11:32 pm    Post subject: Re: Reviving thread - steering & stalks from late WC for Reply with quote
Charlie74Super wrote:
.... what's a direct bolt-on replacement and what requires modification. I have a 74 Super Beetle with the stock steering column.
I installed a stock full leather 87 944 steering wheel onto my 75. No mods necessary.
Veedubaya
Veedubaya is offline
PostPosted: Wed Jul 11, 2012 4:39 pm    Post subject: Reply with quote
Man, I would love to see the bug that this steering wheel is bolted on....
