Weird groove scored on engine case
Wintybug
Wintybug is offline
PostPosted: Thu Jul 12, 2012 7:48 pm    Post subject: Weird groove scored on engine case Reply with quote
I've come across a weird groove scored in the case as I'm tearing down my spare engine for a rebuild. When I bought my car I knew its engine was in bad shape so I swapped it out almost immediately for the engine from my last car, which had been wrecked in an accident. What this means is that I have no history or info on the engine that came with the car, other than that one head turned out to be cracked, and it was hemorrhaging oil from somewhere when we got it.
We're getting ready to crack the case appart and I noticed this very odd and what looks to me to be accidental groove cut into the driver's side case half. What I'm wondering is
A) Anyone know where this came from or what purpose (if any) it may have served? It sure looks accidental to me.
B) does this look like a deal breaker for this case to you? I've never done an engine rebuild, but the engine currently in my car has developed a main bearing knock (at least that's what it sure seems like) so I need to decide soon if I'm going ahead on this rebuild or budgeting for a new engine.
Thanks folks, and there are pictures below
View user's profile Send private message Visit poster's website Facebook Twitter Classifieds Feedback
kevhum
kevhum is offline
PostPosted: Thu Jul 12, 2012 8:35 pm    Post subject: Reply with quote
Looks like part of the engine shroud was rubbing against it for quite awhile
Wintybug
Wintybug is offline
PostPosted: Thu Jul 12, 2012 10:09 pm    Post subject: Reply with quote
Interesting, that hadn't occurred to me. Do you think the damage is significant enough to make rebuilding with this case a bad idea?
FSFTS18Z
FSFTS18Z is offline
PostPosted: Thu Jul 12, 2012 11:05 pm    Post subject: Reply with quote
looks like someone got a little carried away with a die grinder and whatever was being cut was in front of that area
Multi69s
Multi69s is offline
PostPosted: Fri Jul 13, 2012 1:08 am    Post subject: Reply with quote
If you layed the 1 & 3 Cyl. tin there, you will see that it lines up with the groove. Case should be fine. when you put the tin back on, make sure and trim a litttle bit with snips
69 road Bug 2110
69 Baja Bug 2010 - 5 Rib Bus Transaxle
73 Squareback - 2L, T4, Automatic
Plus more toys then I have time for
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
johnnypan
johnnypan is offline
PostPosted: Fri Jul 13, 2012 5:39 am    Post subject: Reply with quote
Tin wear caused it,its not a stress crack...that often occurs on the other side of the case,by #3 cylinder
Id fill it with epoxy to provide some stability and roll it...the case/transaxle flange has a ridge that supports it so that slice shouldnt be an issue.
BG Brian
BG Brian is offline
PostPosted: Fri Jul 13, 2012 12:29 pm    Post subject: Reply with quote
ive got that same groove not quite as deep.Also have this lovely one down by the lifter bore.JB weld oughta fix itImage may have been reduced in size. Click image to view fullscreen.[/img]
